Anyone do a "MacGyver" Emergency Repair?
in General
Anyone have to get by and get home with a MacGyver-type of Jerry-rigged repair on your vehicle? Did you save anyone else with an ingenious temporary fix? Let's here about it...
and I did make a real jerry-rig on the choke of my 76 buick once to keep it in the middle half of its travel for a couple weeks, until I both found which of the vacuum motors was rotten, and had the scratch to buy a replacement. whole bunch of scraps of aluminum U-bar and angle with bolts all over Hell and gone. without that stinker, I couldn't pull the car out of park into gear without killing the motor.
Got a ride to a nearby gas station. Called the office and got a co-worker to bring me a gallon of water.
I had a screw driver and a knife and was wearing a suit. Took off the jacket, rolled up my sleeves and cut the broken end off the heater core. Bent it over itself and used the hose clamp to clamp it down.
Did the same to the other hose going to the heater.
Drove to work, freezing my .... off. Started the car every couple of hours to prevent the mostly water coolant mixture from freezing.
Drove home, really cold as well. Lots of stops a Cstores for cocoa and coffee.
Changed all the hoses the following weekend as I drove the "nice car" the remainder of the week.
TB
On a 4x4 trip a few weeks back, someone punctured the rear differential cover on his truck. Gear lube was running out, but it was a pretty small hole, maybe the size of a pencil.
I was chewing Wrigley's "Extra" gum. It plugged the hole just fine, even with the greasy gear lube all over it.
Some carb cleaner to clean off the cover, plus several layers of duct tape to hold the gum in place, and we were rolling again.
-Karl
TB
Returning home from a road trip in Atlanta-noticed car door lock was in open position-now this car lot had an Atlanta cop station about 50 feet away-opened door-clock stopped-then checked and battery flat - walked over to the cop station and asked them if they heard an alarm-"Yeah a couple of nights ago and damn was it loud". Sorry to disturb your evening officer. In a totally flat parking lot started it by putting it in neutral-pushing it backward and jumping in and popping clutch in reverse-started first time. Moral to the story-never ever park in Atlanta airport lots and avoid IA in the summer.
Since all I had was a knife and the screwdriver, that was pretty much all I could do.
TB
A big bump on another Carolina mountain road caused failure of a Ford exhaust system support. A coat hanger served to get the muffler and tailpipe back in place.
After thinking a while, I disconnected the fuel return line at the fender near the top of the right strut. It had a mechanical pump with a third small diameter line returning gas to the tank to prevent vapor lock. There was a short rubber hose between two steel lines at the spot I was disconnecting. After putting my thumb over the pump side of the disconnect, I blew into the return line, pressurizing the tank. When I had as much pressure as I could build up, I yelled to the wife, "Start it now!" It started, and ran until the next time we shut it off. Stopped for supper, refuelled again, then the campground, and Monday morning. Wife's comment was something about having to give the car a blow job before it would go for us. Monday morning the Chrysler dealer in (is is Rockville ?It's in Park County where all the covered bridges are.) Indiana put in a new fuel pump while we went out to breakfast.
When I was a kid, and most all cars had mechanical fuel pumps, my father had told me to put a new fuel pump on every 50,000 miles whether it needed it or not. Three times I neglected to heed that advice with my various vehicles, the other two times I had gas dripping from the pump after about 60,000, the third time I just told you about. Electric fuel pumps are more reliable.
Harry
In 1989 we drove this car to Florida to do the amusement park vacation with our young kids. The car had about 40,000 mile on it. While down there, it developed a tremendous clattering whenever the engine was idling or under no load conditions like going down hills. We took it to the local Chevy dealer, rented a loaner for a day, then called the dealer at noon. Dealer after analysis claimed it was a bad lower connecting rod bearing and would cost many $$$$$$ for repair. We really did not want to pay for a major repair or trade vehicles while on vacation far from home. After thinking it over, we decided to try to finish our vacation as is. After all, the worst that could happen is we got stranded somewhere and would have to rent a car to get home.
By carefully driving with one foot lightly on the gas and one on the brake when slowing down or stopping, we were able to finish our vacation, get the car all the way back to Wisconsin with minimal clatter. People in cars next to us would point at our noisy car(as if we couldn't hear it), with us nodding in agreement! (It was impossible to keep the clatter down under all conditions)
After our vacation, I took it to a service station near my home. They had seen the same problem before, and determined it was the three bolts holding the engine ring gear to the transmission had loosened up causing drivetrain backlash. They fixed it, total cost $50!
Otherwise, the car had been bad news, with many things happening that shouldn't (the vaunted GM sticky steering problem being one of many), so I dumped it the next year as it was not trustworthy.
Some funny stuff there.
I once poured a half box of Ivory Flakes into a leaking radiator and was able to limp home 200 miles. The car looked like a mad dog with the foam that dripped from the grille!
Except when I got there, there was this big golden/tan trail behind me. Seems in the rocks, I threw some at the fuel tank hard enough to puncture it in two places.
A couple of machine screws with little rubber "gaskets" fixed this in about 10 minutes.
Sold the car 5 years later with this repair, and perhaps a bit of undercoating added for good measure, still on the tank.
TB
Hey I traded in an old 85 chev blazer once. I was on way to dealer and I began hearing the unmistakeable sounds of lifters and valves going south. Pulled onto dealers lot, put it in park and right then noticed what looked like suds coming from under the hood up the windshield. I popped the hood and saw that the oil filler cap had blown off and foamed like a son of a gun. Definitely can picture the foaming mouth of a mad dog lol. Dealer still gave me 2500 for it though, couldnt complain.
