Jeep Grand Cherokee 60K service questions
I'm quickly rolling up on 60,000 miles on my (new/used) 2000 JGC Laredo 4X4 and local Jeep dealerships are licking their chops...($500+ and $610+ for nearby dealerships)I'm not a mechanic, but I think I can reduce my cost by taking care of a couple of things myself. I don't know if the 30K service was performed on this vehicle or not.
I think I'll have the dealership service handle;
1)Transmission service (flush & fill) - $100
2)Differentials/transfer case - $60 each (x3)
3)Coolant flush and fill - $40
4)Oil Change - $22
Total $342 Is that about what you've paid for these services?
Rather than spend $90 on a tune-up, I'm going to change the spark plugs myself. I can also inspect brakes/rotors since I can change pads myself. And the air filter should be easy enough to replace.
Is the PCV valve easy to replace? Dealership wants to charge $20-$25 for that one.
The alignment seems fine, don't need tire rotation yet, and everything else works perfectly.
Is there anything else I'm missing here?
4)Oil Change - $22
If it were me I'd have the fuel injectors cleaned and replace the fuel filter. Probably replace the O2 sensor too.
Have a good local shop check the alignment and do a rotate & balance.
Finally, spend $100 or so and have her detailed inside and out (unless you do this yourself) and she'll drive, look, and smell new.
transmission service - 139.62
tire rotation - 12.95
cooling system service - 49.95
differentials and transfer case - 187.24 (Sept 01)
This was at my local Jeep dealer. Hope this helps. Your prices seem reasonable to me.
Oil Change 24.00
Transmission 80.00
Differential/Transfer 180.00
Cooling System Service 50.00
This was done at Carmax and was very professional...
The nice thing is, if you go every 8-weeks like I do, you don't have to spend all that money at once. You can do some things a little early. Do others at recommend time and some of the less necessary things at the next trip.
Their pricing is really good also.
