Door noises on Chevy K1500 Extended cab LS Z71
wcasperson
Member Posts: 2
Here are the details:
2002 Chevy K1500 extended cab (2 regular doors, 2 inverted doors). Z71, LS model. 5.3 Vortec. I had the dealer add a Manik grill guard and Smittybilt "nerf" bars. Stainless steel for both.
The truck was purchased in Feb of 2002, and has about 3,500 miles on it now.
On Seattle roads (a touch bumpy), I get a creaking noise or squeak out of the driver side doors. The squeak is not heard on the passenger side. If I turn the radio up, it drowns out the squeak.
I took it in to the dealership at 3K miles. The dealer's solution was to lube the doors. Problem went away for a day, and now it is back again.
The inverted door on the drivers side needs to be shut hard in order to get it shut. Not slammed, but pushed all the way until it shuts. I was told be the dealer that this "is by design"
Any suggestions on how to resolve this? Has anyone else seen this problem?
It appears your door needs adjusting is the first problem. The second problem is getting your dealer to recognize this and adjust it. The answer to the adjustment is obvious. Getting the dealer to do anything is the real problem.
There is a Customer assistance request into GM on it.
(not holding my breath) In the meantime, you can
wrap black tape on the striker loop at the top and this should quit it down...
Pat
2001 LT extended cab, z-71
-David
It was cause by a loose door handle on the outside. The handle had about 1/2 inch of play before it would meet with resistance. Driving down the road it would catch some wind and rattle. I had taken it to the dealer more than 5 times trying to isolate the problem. Then one day I was getting out of my truck and noticed the play. Taped it on the way home and rattle gone. Took the tape off and adjusted the mirror so I can watch it and sure enough. The dealer felt really stupid on that one...
I live in Everett, maybe we should get together and try to isolate the problem ourselves if the wrapping of black tape on the striker loop at the top doesn't temporarily fix the problem.
There is a rubber dust cap that I removed that is located on the front side of the door. The slider moves in and out of this dust cap.
Upon removing the cap there are two guide rollers in the door that the slider moves on. I sprayed grease onto both of them and replaced the dust cap. The opening door squeak has never returned.
-David
pat
Now, if you haven't already, thoroughly lubricate the rubber in that area with silicon grease where metal meets rubber. Let us know the results.
Just visited the alldata.com site and found: TSB 01-08-64-015, Side Access Door - Squeak Or Scraping Noise.
Haven't read the text so don't know if it refers to our problem. Anyone know a source for the text?
- David
File In Section: 08 - Body and Accessories
Bulletin No.: 01-08-64-015
Date: October, 2001
TECHNICAL
Subject:
Front and Rear Side Access Door Noise
(Replace Door Check Link)
Models:
1999-2002 Chevrolet and GMC C/K Pickup Models (Silverado and Sierra)
2000-2002 Chevrolet and GMC C/K Utility Models (Avalanche, Suburban, Tahoe, Yukon, Yukon XL, Denali)
2001 GMC C3 Sierra
2002 Cadillac Escalade
Condition
Some customers may comment on a squeak or scraping type noise while opening the front and rear side access doors.
Correction
Replace the door check link on affected vehicles. Use the part numbers listed below. Refer to the Doors sub-section in the appropriate Service Manual for the Door Check Link Replacement procedure.
Parts Information
Parts are currently available from GMSPO.
Warranty Information
Labor operation Description Labor/time
B4050/B4051 Link or spring 0.5 hr.
front door hold open
replace right/left
B4490/B4491 Link or spring, rear 0.4 hr.
door hold open-replace
right/left
For vehicles repaired under warranty, use the table as shown
- David
pat
So I ended up adjusting the rear door latch inward using all the movement available, 11/64, which pretty much duplicates the door movement on the passenger side. Greased it up and left the cover off for the time being. I'll let you know the results next week. Thinking positive.
-David
i did actuallly break one of the black tabs. i saw it was two pieces, but one of the tabs on the lower half piece did in fact snp off. i went to the dealer to see if i could get a few, but they could not find any in the parts list. they believe they come with another part as in the headliner, which i dont plan on buying. i will just super glue it. so how does the 11/64 work out. you say you moved in the upper strike as far as it will go??
pat
-David
The latest test was to return the strike to the factory position and start over.
Having taken the plastic cover off the other side to compare them visually I noticed, (1) the rubber bumper at the back of the latch slot doesn't protrude out as far on the driver's side, allowing the strike to plunge deeper into the latch, actually rubbing the paint off the metal sandwich at the back. (2) the strike was also lower in the slot on the driver's side, low enough to rub the paint off the metal there as well. The first condition was 'corrected' by rotating the strike forward slightly. It appears now that the strike doesn't indeed plunge as deeply although still not matching the passenger side. The second condition was corrected with (don't laugh) a large hammer and a block of wood (not recommended, but effective). The strike is now positioned in the middle of the slot. I gave it a brief test and so far so good. Another week for a more thorough test and I'll report back.
Are these the same conditions you've found? Are you trying anything different?
BTW, Those plastic fasteners holding the covers on don't work the way they were designed. What a royal pain! Either that or they were never meant to be removed which I find doubtful. I took an Exacto knife and carefully trimmed the thickness of the tabs so they work more smoothly.
-David
Hope this helps.
-David
pat
-David
pat
We haven't talked before about that rear door window. I've heard sounds, a kind of tinny, ticking associated with body flex, that vaguely have the 'ring' of tempered glass. I think the gasket around it is vinyl which gives further cause for suspicion. Using a Q-Tip and that saturated cloth I covered all areas that touch. So far, good results, but as previously, the real test is cold weather. Keep in touch.
-David
