Paint Chipping is it the new softer paint or specific makes/models?
There has been much discussion as to the reason(s) for what seems to be a greater incidence of paint chipping on newer model cars. Some say it is the softer, more environment friendly paints being used by some makers. Some say it is the new aerodynamic car designs. Some say it is cost savings by some makers, putting a thinner coat of paints on their cars.
Are certain makers and/or models more prone to paint chipping? Let's help each other understand these issues and help future car buyers make better informed purchase decisions.
Thank you for your participation,
Curly
Curly
I understand the need to clean up the environment. But, since the paints are now less durable, more repairs will be necessary, so more paint will be sprayed. Where's the improvement?
In 8 months and 6000 miles, I have gotten only one tiny chip driving on US27 in Georgia at 80 miles an hour when a truck dropped a small piece of drywall. It also caused a minor scuff mark that was easily compounded out with an extremely fine polishing compound.
I can't say for sure the Japanese paint made the difference, but I have come to understand that it does.
Oh well. So much for that theory, huh?
Or do you mean the U.S.-painted cars are even worse?
John
As for the Forester having two chips on the bumper, it is obvious to me that any car will have chips if hit hard enough. It is a comparative matter as to whether some paints are more chip resistance, not that there are any that can not be chipped at all. And the bumper is a very likely place for a hard strike.
My old 88 Camry....barely any
inevitably at just shy of 84k I've had to go out and get some touch up for a small chip.
Color BTW is Melange, a metallic tan. Color may play a role. In my years of model building I've discovered that different pigments have different properties even if they're the same type of paint.
They really put good paint on Audis.
My sister has a 10 year old Escort with no chips - she drives on highways and gravel roads all the time. The guy she bought it from had it paint protected - I wonder if it acts like an extra coat of paint or if it just had better paint to start?
I was on the Mother's website and saw they have a new product that helps you apply touch up paint more evenly. Has anyone tried this? Any feedback on how 3M tape strips work long term?
NEW 2014 Corolla blizzard pearl (2k miles) - 3 chips right in the middle of the hood, several tiny spec chips on front bumper. So depressing to have such weak paint.
I tried touch up paint... at first, the color looked like a really good blend/match. Then I did another coat and now on my pearly white car they look like dull spots. The issue might be that I had to prod with the toothpick to get the color to settle into the chip, making the surface a little rough.
Should I sand these tiny chip-paint surfaces down, clean, and dry to drip again so that the surface is smoother and perhaps a better match?
To make matters more complex, I am looking to have a clear bra installed ASAP once I am satisfied with my touch up job. My idea was to try to fix my existing touch up work, let that dry a day or two, perhaps put on a clear coat of nail polish(??) and then have the dealer buff the car before they put on the clear bra. Does this sound at all like a good idea??
I need a super rookie solution to make this look as acceptable as possible.
I now own a pair of older BMWs and have found the paint to be quite durable with a few exceptions.
My 2000MY 528ia has over 150K on it and very few stone chips in the front. Every spring I touch up one or two on the front hood. The bumpers are more prone to chips as well as parking scrapes, in fact I've had the rear bumper repainted.
I also have a 2001 330ci cabrio with 86K that has hardly any scrapes or chips, in fact I've yet to acquire touch up for it. Oddly, the paint problems in this car show up on the interior where there is discoloration on some parts of the dashboard, perhaps due to the extreme heat in the Phoenix area.
There's also paint worn away on the steering wheel spokes (3-spoke M-Sport wheel) which oddly reveals white plastic underneath. I was trying to figure out what type of paint to use for touching up the wear spots, I even asked a body shop (they were no help).
I decided to use good old Testor's Enamel Gloss Black model kit paint. I figured if it was designed for plastic it should work. So far so good, it's a perfect match and even if it wears off quickly it's easy to reapply.
A lot of the pearl whites are multi-layer paints which involve layers of different shades, they can be very tricky to match. If you can get some touch-up paint from Toyota or an automotive supply store you should do that rather than attempting a match with nail polish. You can get the correct clear coat from them as well.
I've discovered the hard way that through mixing and shaking the paint is critical to getting a color match for metal-flake colors.
