Visitor Agreement.
The reason I chose the WRX rims for winter was that I figured the snow would be less likely to collect among the simpler spoke design. The problem is that now that I have them on the car, I think I like the way they look better than I do the stock alloys :-) What to do...
Cheers,
-wdb
Cheers Pat.
We do have breakdowns in our cars. If we didn't, we wouldn't need our warranty department ;~}
It's unfortunate that it happened to your Subaru, but let us know if the repairs do not go well. Also, if your dealer needs to keep your car, make sure they supply you with a loaner/rental under warranty.
Once again - sorry for the dissappointment.
Patti
is wrong but I will wait until more 02 Beans get on the road and
see. I just don't think the car should accelerate unless you are
pressing the gas pedal. I have heard of steering with the throttle,
but throttling with the steering wheel is a new one!
Still I love this car!!!!!!
Thank you for the message. I know it isn't your fault personally. I have been flying under the radar for a couple of days, thinking I overreacted. Colonial Subaru in Feasterville, PA is handling the repair. The Forester is going in to have the work done on Monday; they will keep the car at least for all day. Colonial provides "shuttle service" in that they will drive you to your place of work in your own car, then drive it back for servicing. I'm not keen on that approach but given that I work on the same street as the dealership, albeit 5 miles away, it's not always the worst thing that could happen. I don't expect to have to travel out of the office on Monday but if the car's not done by COB I will need a loaner as I have to visit a client on Tuesday.
I will keep you all posted as it progresses. I am impressed with the quick turnaround and the personal attention; I just hope that the repairs are performed properly. I sincerely want to be a long-term owner; it's been such a fun car to drive and one that has served my needs very well thus far. It's been a long time since I've owned a car that makes me want to learn to be a better driver and take advantage of its capabilities - and this isn't even Subaru's "hottest" model!
Besides, I can't think of many other single-marque owner groups where the people are as unpretentious and honest about their cars, warts and all (the cars, that is). Try hanging around a group of Packard owners and you'll understand.
Patti, I do know how to reach you and I'll be in touch on Monday.
Ed
(a man who drives a Forester)
Ross (Another male forester)
You just have to accept that there are some jerks in all walks of life you just have to learn to ignore them, if they cannot bait you they usually go away.
Cheers Pat.(very happy GT owner.)
So, I think I'll swap front right to left and see if that cures it. While I had each of the wheels off, I noticed that the tread is wearing well and even, including the outer parts of the tread. (No I didn't measure it, I just eyeballed it and compared how the tread looked to the various wear bars.) So, the alignment is probably in good shape until spring.
-Brian
I traced the leak on our 626. It's actually axle grease, not engine oil. It was all over the right front wheel. Cleaned it up and found the rubber boot closest to the axle was torn, and all the grease spilled out.
I have a photos but PhotoPoint won't let me login. I'll put it up later today.
We have an appointment with the dealer to get it fixed tonight, so I hope it won't be too expensive. Any guesses as to the cost to replace it? FWD, Mazda 626.
-juice
Cheers Pat.
Cheers Pat.
Do they have to pull the wheel, brakes, and axle to get the new one on? That's quite a bit of labor, no?
-juice
Cheers Pat.
Cheers Pat.
Think about it, every time you turn the steering that rubber boot has to flex every which way, as well as being subjected to all the road crap.
Cheers Pat.
around here it's $150-200 including parts for most hondas, a bit higher for Subaru I would think due to parts if nothing else. yes Juice, they pull the axle and whatnot but it's a typical and oft-performed repair so it's no biggie.
-Colin
Juice: if it's that torn, I'd get it replaced asap. besides, if you go to trade it on a WRX (hint, hint), that'd be the first and easiest thing that the appraiser would check for when looking underneath the beast.
-Brian
You might want to check and see if such a thing is available tor your Mazda. Wish I could remember where I found it but it was a long time ago.
Good luck
Guy
The wife takes the Mazda in for anything but routine service (which I do). I don't really feel like taking on this project, given the cost shouldn't be high, but thanks.
-juice
At the time, I took this approach based on a mechanic's recommendation. I have since learned that it's a fairly common fix in cases where you don't want to have the whole half-shaft taken out for a boot replacement.
As long as the CV joint was not contaminated with sand or other abrasive debris, it should just require a boot replacement.
Craig
-juice
Craig
-juice
Chuck
Pat and Vince's comments were especially relevant; I researched an awful lot before deciding on the Forester. I am trying to focus(no pun intended) on the dealership experience, turnaround time and, ultimately, the effectiveness of the repair. I am biting my lip, however, based on the number of i-club posts Colin referred me to which lead me to believe that mine is not an isolated occurrence and that head gasket failure occurs on Phase I and II EJ25 blocks.
Here's hoping this takes care of business...
Ed
PS: juice - FWIW I had CV joint/boot failure on my old Jetta almost too many times to count. It seemed as though both inner and outer joints failed at ~ 60-65K and since I had that car up to 146K I ended up replacing 8 joints.
Cv boots are easy to do. A bit time consuming depending on the model. But if the tear has been there for a while just replace the axle and that is easier to do. I am not so confident on the zipper boot. But, it seems folks have used them successfully. On my 90 Accord I replaced them 2 times by 165K miles. I think it may be more efficient to just replace the axle. I think they are around 120 bucks. Honda charged me 55 for the boot kit. Also, when replacing a cv boot always do both. The inner ones last a bit longer but why do it twice? And there are 2 types of grease-one for the inner and the other for the outer. Don't confuse them. And since you will need a sledge hammer to take the outer off the wheel assembly remember never to hit the tip of the axle directly otherwise you will crown the metal and it will not slide off the wheel or back in for that matter. Let us know how it goes.
8 joint replacements? Ouch. At least this one lasted 70k miles, and even then only one ripped.
Interesting, because I always park with the wheels straight and my wife doesn't. I've never had a boot fail...
-juice
Greg
Next time I think I'll just get the kit and do it myself.
The check engine light showed an O2 sensor shorting out, and to replace that was a more painful $366, with $212 just for the parts. He said it's a heated sensor, which I've never heard of, and that there were two of them. That includes diagnostic labor and labor for replacing the sensor.
I had been to Trak Auto and found an O2 sensor for $70, but I think that one's OK, it's the one farther down the exhaust that is bad.
Ouch, man, Mazda charged me $28 for a gas cap for the Miata (could not find an aftermarket one locally that fits) and now $212 for an O2 sensor? By comparison that makes Subaru parts seem cheap!
That puts the total repair tab for the 626 at $1200 over 6 years. Not too bad, I suppose, but it really makes you consider those long warranties.
-juice
About the heated sensor: yes, an oxygen sensor is nothing more than a fancy thermocouple. Basically it sees heat and interprets this as how rich/lean the fuel mix is.
-Colin
I did find a Bosch for my Miata, something like $25. Took me all of 15 minutes. I told the tech this but he said the heated sensor in the 626 is quite different that the one on the Miata. As in 10 times more expensive!
If it were my car I wouldn't even have taken it in, but the wife likes dealer service (and prices).
-juice
If you have not already had it done check some of the franchise,s for a quote on a replacement drive shaft you may get a pleasant surprise.
Cheers Pat.
Greg
..Mike
Oh well, I learned my lesson. No more dealer service for the Mazda. I really should have just done it myself. I bet it would not have been $100 for the boot kit and the O2 sensor. Instead it's $730.
I did need to read the OBD2 codes to find out what was wrong in the 1st place, but my guess was the O2 sensor anyway. Rats!
-juice
Wife is not stupid she knows my game, but like the good soul she is she lets me think otherwise.
Cheers Pat.
Greg
-juice
I see you're in NY. There's also a Tri-State Forum.
Dennis
..Mike
..Mike
Greg
-juice
juice: The rental Focus did handle well but is in need of at least another 40-50 hp and better tires. The seats were heinous, though - cushions way too flat and about 4 inches too short. While I had the Focus, the cover of the driver's side visor mirror fell off (yes, somebody does make lower-grade visors than Subaru) and the radio turned on and off of its own volition. Can you say possessed?
Ed
Look at the sunny side: you got a free coolant flush and oil change, and spakin' new gaskets in a few places. Oh, and a clean car to please any OCDer. :-)
-juice
PS When my brake master cylinder was recalled, that meant my brakes were bled for free!
Ed -- Glad to hear your Forester is back in action. Hope this repair fixed it once and for all.
juice -- Yeah, the visors need improvement. My S visors have vanity mirrors in them, but they still feel flimsy -- especially the clip that allows it to swing to the side. The visors in my wife's Jetta are made much better. They have a great sturdy feel and the clip is magnetized.
Ken
