The loaners they have are mostly 05 Subaru's, base models but clean with low mileage.
File complaints with SOA and the BBB, then go to another dealer.
Mark
-juice
So a should I be concerned? Every car has it issues but head gaskets sound like something to be concerned about....
I don't know about a special wrench but I know that they are far easier to remove if the exhaust is still warm. be careful not to burn yourself, of course!
~Colin
I would!
~Colin
-juice
-juice
valve seals are good for well over 100k miles with minimal leaking. juice, the backside of the valve is in oil. it's probably not the full crankcase oil pressure, but it's definitely pressurized.
~Colin
I've helped a buddy manually adjust the valve clearance on an early Acura DOHC engine. That was laborious. Phew.
Any how, reinstalling the valve covers is nothing like the process you described for replace the heads.
-juice
I was trying to wait till I need to replace all 4 to give me a reason to replace the OEMs, but (unfortunately) they have served me fine. This is for a 2002 Outback VDC Wagon. Thanks.
Just let them alone until it is time to replace all. Rotating them helps them to age more evenly, but for this set just replace them all when the fronts are need of replacement (I am assuming the fronts will wear faster as they most commonly do).
I've done some homework searching existing posts but I haven't been able to find any info on the problem I'm having with my 2000 Legacy Outback Wagon, which I believe has the Phase II 4EAT transmission. Hopefully it doesn't become an X-file... I can't determine off-hand if it is a transmission or fuel delivery issue, so here goes:
PROBLEM DESCRIPTION:
When fully stopped, I put my foot on the accellerator and the car slightly hesitates (not the engine- the car moves forward when the RPMs rise) about 0.5 seconds and then catches and lurches forward. Significantly, this happens regardless of how much pressure I put on the accellerator. This is not of concern to me when it is just me in the car, but we have an infant and being a new parent I'm concerned about the jostling around.
MY CURRENT THEORIES ARE:
1) I'm screwed and this is normal for this vehicle.
2) There is a problem with the transmission or the torque converter.
3) The vehicle may have a "learning" or "thinking transmission" and it may in fact have a learning disability.
4) There may be a fuel delivery (i.e fuel injectors, filter) issue.
MY QUESTION IS:
Is anyone leaning toward any of these theories, and if so, why and what can I do to remedy my vehicle?
Any help is greatly appreciated!
Not sure if I read this correctly, but if the engine RPM's rise and then the transmission kicks in, it could be the transmission needing to build up enough line pressure to get moving. The fluid pressure is in proportion to the engine rpms.
A couple more questions - do you know if the transmission's been regularly serviced (fluid changed)? Second, if you pull the dipstick, is the fluid nice and red and/or does it smell burned?
If any of those is an issue, I'd go for a good transmission flush.
HTH
Larry
-juice
Gary
The RPMs and vehicle speed increase together. There is no difference in timing there that I can discern. The offset is between the time I press on the accelerator and when the RPMs/speed increases. From your description of building up the fluid pressure as a result of increasing the RPMs, which makes sense in my feeble mind, I'm not sure that this is the problem. I'll see if I can recognize that on my drive home tonight though.
The transmission was flushed in June to try and address the same problem but it did not change anything. Since then I have not changed the fluid but have made sure it is at the appropriate level and is still red and does not smell. I'm not sure that this is a fluid issue.
This is a very important troubleshooting question -- does the engine stumble when you rev it from idle with trans in park or neutral?
Craig
jim
Is the car jacked up when you're installing the FSB?
Best done with wheels on ground.
Other thing that comes to mind. You were issued the wrong FSB.
-Dave
The prominence of the lurch is quite dependent on the way the car is accelerated and the gradience.
A lazy nonchalant acceleration = very noticeable
A quick gradual acceleration = less noticeable
Is this a two driver car?
It's more often felt when it is - the 4EAT learns.
-Dave
ALso, if it happens in neitral or park, I think we can eliminate the transmission as a cause.
Finally, perhaps your knock sensor is bad. This can cause a hesitation coming off idle. If the knock sensor sends a wrong signal to the ECU, it will retard timing which can lead to an initial stumble.
CRaig
ps: do they have to replace the actual part or can the code just be reset to fix the problem? Dealership says it is $180 to replace part and would take 1 1/2 hours, but I was under the impression from the mechanic that it was simpler than this to fix. any advice to help me not get ripped off would be appreciated.
I bought my 05 FXT about a year ago after spending some time on this board. Haven't had any problems, so I haven't really been back! But lately I've noticed a wierd smell...sort of like a burning chemical? Some days worse than others....occasionally I think I can smell it in my car. I have smelled it with the windows open, but mostly at home when I pull it in the garage. Once I put my face down by the hood to smell...it was quite toxic smelling, and also hurt my eyes. Local mechanic says it smells like an antifreeze leak and I should run it up to the dealer. But dealer is an hour away and I have to sit there for hours to wait for service... I want to be informed before I arrive. Any thoughts?? How urgent is this? Or is it nothing??? TIA!!!
Warranty Thermostat Housing Gasket
Al
Problem solved, however, it was the windshield.
It had been replaced just days b4 the noise started. There were 2 air leaks. Since this co. had put 2 windshields in w/i 2 weeks b/c of their error, I kindly asked for the $ back and took it elsewhere.
karlnic
Are all the fluid levels OK?
-juice
The only burning chemical smell I have had was when I was plowing through loose sand for 1000'.
My suspicion was the center diff (viscuous hydraulic coupling). I have not smelled it since.
Have you checked your tire pressures lately? Any unusual wear on one or more? Is the treadwear similar?
John
I haven't really noticed the smell on my 04XT, but was wondering if that could have contributed to the sorry state of my transmission fluid? :confuse: I just had it changed at 27K because it was brown and smelled burnt.
The car doesn't get abused, but the last two winters in New England have been pretty rotten, and the car's seen more than its fair share of awful road conditions.
I've put 1000 miles on it since the change and the fluid is still fresh.
Any ideas?
TIA
Larry
2) Tires : My car is around 47K miles and still has original tires (Bridgestone Potenza RE92 P205/55R16 89V
One of them blew out a big part on the sidewall.
a)disengaging the AWD - I read on the Subaru website that one must disengage the all wheel drive when using the temporary donut tire by putting a different fuse in the fuse box under the hood or something like that but there were not detailed instructions. Does anyone know how to do this in detail?
b) I went to SEARS and they told me that I had to get a V rated tire or higher for my model car. Is this true?
I am rather a slow poke and don't drive the car fast or race it.
Other tire dealers and the Subaru parts person locally seem to think that an H rated tire is fine for my driving needs.
C) I am more concerned with handling than speed. I live in a high rain and high snow, sleet and ice area (North East). I cannot afford to get separate winter tires.
Thus I want tires that have the best handling in all these weather conditions, especially the snow and ice but I don't want to compromise on the cars ability to maneuver.
Any advice on the this?
Consumer Reports gives top rating to Goodyear Assurance Triple Tread , Michelin X Radial, Hankook Mileage Plus II h725 and Yokohama Avid TRZ, Michelin Hydro Edge, and more.
THe Michelins seem great but most of them are over $100 per tire and I'd like to aim for $90/tire out the door (including balancing, stems, installation).
One dealer recommended Bridgestone FUsion HR.
First I need to find out if I have to get V rated or higher and why before I bother shopping around the H rated.
The Subaru Website says "it is essential for every tire to have a size construction as well as a speed symbol and load index matching those on the tire placard.
I already listed what it said on the tire placard.
Please help!
You may not go over 130mph, but a V-rated tire will resist heat better than an H-rated one even at 75mph.
In fact, when I got to ride along on a few hot laps at Las Vegas Motor Speedway in a Legacy GT, we hit about 125mph, and the tires were completely spent. Yes, V-rated ones!
-juice
Craig
The car runs like a champ...Always has. Never had a problem in 87,000 miles of hard driving....I change the oil myself....
I think if I took it to a mechanic, I may start to have problems...
$180 sounds like a RIP OFF......
Just my 2 cents....
Electrical tape over the CEL = bad idea. If it trips on you often, get an OBD II reader for $100+ dollars and read out the codes/reset the CEL on your own. Mine comes on quite frequently for various reasons and I used to have it read out once per year for $85. Sometimes there were real problems, sometimes not. But, I just took a chance that there were not for the 2-6-12 months it was on since the last read out. I purchased a reader just this past March and have already used it 6 times. At $140, it paid for itself by the end of April. None of the codes have been "fix now" problems, but it is nice to know when something new crops up (after all, the light only comes on for the FIRST problem). Invest a few more dollars, and you can get a diagnostic system that will patch to a laptop, etc., and give you full operating conditions, etc. They are very handy tools even in their most basic form.
I say donate it. Take the tax deduction.
-juice
I have a 2002 Forester S, bought it Aug. 2001, automatic, 42k miles. Wife's car, well maintained, never pushed. A couple of months ago when my wife left, I noticed blue smoke coming from the exhaust. When she returned there was no smoke so I thought maybe this was a one time event. Then 2 weeks ago the same thing happened. Since then I have kept an eye on the car. The blue smoke is quite noticeable and consistent after the car has been driven enough to fully warm up, and then sits for at least 20-24 hrs. When you start the car, there is no smoke at idle speeds, but as soon as you give it gas, blue smoke comes from the exhaust. In a few minutes, after the car warms up, the smoke dissapears. Dealer "could not replicate". I had asked my wife to drive the car and I videotaped it. Showed the tape to the mechanic at the dealership, they want to try it again tomorrow. Oil is dark, and at the low mark (it was at the full line when it was changed couple at months ago at 39k miles). What is the most likely cause for this smoke? How much would it cost to fix? I still have the drivetrain warranty - would that cover it?
Daniel
Thanks-JP
Our 626 has *exactly* the same symptom, chunk chunk chunk, speed dependent right?
Wheel bearing, I'm almost certain.
-juice
