-June 2024 Special Lease Deals-
Cheers Pat.
Question - how long does the Sube (or any car) have to sit before you can get a "cold" psi reading on the tires?
jg
Dennis
1) temp of the tire
2) compound of the tire
3) ambient temp, sunlight and temp of the ground where you park
It can take anywhere from 10 minutes (maybe less, if the tire was effectively "cold" to begin with) to over an hour.
I would definitely agree on the approximately 1 mile to keep a tire cold for accurate pressure readings. Keep the speed down and accelerate, brake and corner gently and you'll keep the temp down longer.
Do the reverse and summer tires will really be working. ;-)
-Colin
I agree, but thing is that I just had 1st gear replaced last year because it was popping out. I don't abuse my tranny so I can't imagine the problem is back again from wear and tear.
While it's not a situation you often encounter, it seems like a saftey issue to me. The first time it happened was when I was going down a snowy downhill road. Traffic was backed up and crawling. Rather than riding my brakes the whole way, I left my vehicle in 1st. It was kind of scary when the tranny suddenly pops out and your vehicle starts accelerating forward because it's in neutral.
jg: I believe it was 3 hours and not driven more than a mile.
Ken
-mike
Hey! Chat countdown! T-minus 35 minutes & counting!
Cheers!
Paul
Cheers Pat.
Cheers,
..Mike
..Mike
Did your "clunk" happen with every big bump you went over? From what area did the sound eminate from?
Ken
Ken
-juice
-Colin
Cheers Pat.
Is there a way I can get my contact info to the Senior Rep that you mentioned? I haven't heard from her yet. I thought it might make it easier for them if I left my phone number in addition to my e-mail address.
Ken
BTW -- how was the engine rebuild?
A side note worth mentioning: My salesman saw me come in... chatted me up for a bit, and when it came time to pick up the car, I found out the sales dept. had paid half the bill! ($20 out of 40) Guess he wants to sell me a few more cars... Patti, are you listening? This guy has customer satisfaction & service written all over him! One attaboy his direction!
Cheers!
Paul
-mike
Can you send me your number to PMICKEL@Subaru.com? It might speed things up!
Type/chat with you on Monday!
Patti
Patti
-juice
Cristina
The fluid has a much longer way to travel to get to the rear nozzle. Just use the rear washer a few more times to get the newer fluid through the lines, to replace the older mixture.
There is one reservoir, so let the rear one run for a while. If you used a different color washer fluid (i.e. orange instead of blue), you can even see that it will eventually change colors.
I looked the other day, and the blue stuff protects to about -20 degrees F. That's their claim. Others go to -30 or even -40.
I think the thing is that there is a windchill effect, so outside temps at around zero are still probably enough to freeze the fluid in those lines.
-juice
Dennis
-mike
KarenS
Owner's Club host
My friend used to have an old Montero, and the little hose came loose once. So his rear washer would shoot water out backwards, a few feet behind him.
It sure stopped tailgaters!
-juice
Vince14
P.S. I love my Donnely ECT mirror thought it does seem to have a noticable vibration to it.
-juice
Vince 14 is right on about the front and rear sharing one resivoir. I believe the rear washer feed is positioned higher in the resivoir so after a certain level, the rear stops working first -- a logical design.
Ken
My Impy OBS shares one reservoir too.
BTW, does the washer fluid destroy the paint?
-mike
My old Mustang had two resorvoirs. The rear one leaked all the time so I basically didn't have a rear one at all.
Some people say the fluid can harm the paint, but I've never seen any evidence of this. It's so watered down I doubt it would.
-juice
(\o/)'s
/_\
Thanks for the stroll down memory lane!!
Patti
I wonder if people are blowing it off? I have not heard any complaints about it at all. Not even one. The dealers will not change it when required unless you ask specifically and then you have to wait for the part to come in. Neither dealer near us had it in stock. I change ours every 10k miles. Its supposed to be done every 7500miles or 1 year. Its pretty dirty after 10 miles but its such a pain......I wonder what the dealer would charge. Probably quite a bit because it needs lots of hands-on time (at least 20min if you know what you are doing).
Has anyone else tried this in the OB????
nematode: it's much easier in the Forester and Impreza models. Check it out:
http://thejuiceman.homepage.com/air.html
Just loosen two screws, slide the single filter in (yes, there's only one), and reinstall the cover.
You get me back on the rear diffy protector, though. You can just screw it on Outbacks and Imprezas - while I had to remove the exhaust!
Guess the Impreza is the easiest to work on.
-juice
How is that explained?
-juice
I think because you have the liquid squirting onto a cold surface and a great surface area (kinda the way a thin layer of eggs on a hot frying pan will solidify faster than a large amount of eggs in a smaller frying pan)
-mike
Maybe my wind-chill idea wasn't so bad after all.
-juice
-mike
But noone has explained why mine doesn't freeze in the lines, but then freezes on the windshield while I'm in motion.
Calling all thermodynamics specialists!
-juice
Ross
FYI- the 2001's still have the sucky rear washer dribble/spit nozzle.
-Frank P.
Stephen
