-mike
-mike
-Tony
In the end, I think my bumper cost around $900 to replace. Good luck.
--> Andy
BTW. I agree with most of the sentiment expressed here that the estimate you have appears to be rather low, my advice would be to get a second estimate, remember the old saw, measure twice and cut once.
Cheers Pat.
I should have a photo up later on.
paisan - quick, I need some info. How much would it cost to rebuild an XT6 tranny? How much for a brand new one?
Some anti-Subie guy is slamming XT6s, claiming it's $6 grand for a new tranny, and that the AWD breaks driving on sand.
He's in the SUVs on sand topics. Or just share the info with me and I'll post.
-juice
-mike
Thanks for input,
Kevin
bit
Sorry to hear about the mishap and I'm glad no one was hurt and that as far as Sandy's concerned, glad to hear it's more in the category of a "broken finger'. Good luck with the repairs!
WDB:
Regarding your post 1736 (I've been gone for a few days) where you recommend switching gasolines, particularly for people in the Chicago area where they have local blends; I'm very intrigued!
I've been a little disappointed with the mileage I'm getting in my OB and have noticed that in the past two tankfulls it has jumped from averaging only 18.3 to 18.7 mpg this past winter to 19.7 and 22.4 gallons. I'm interested in any insight you can share about this "local northeast Illinois blend". Other than oxygentaed winter blend, I wasn't aware that there was a special regional blend.
Ron
Alan: if it's persistent, it should be easy to trace. Have someone else drive around and see if you can find the source just using your hearing.
Often times it's something loose in one of the many storage bins. My cassette tape boxes did that.
-juice
right now they are BF Goodrich Momenta P185/70R14. I wasn't smart enough to look at the chart on the car before I started writing this to see if that is what's actually supposed to be on the car.
Kevin
It's not a common size, though. Choices may be limited. Try Tirerack.com, do a search. Come back here and let us know what models you find - maybe someone here would have experience with that tire/brand.
Also check out their surveys. Pretty useful.
-juice
-mike
The estimate is for $285.00 and the car will be ready for pickup tomorrow, I had one days rental at $38.00 as I had a lot of running around today, miss my second car already.
Incidently my daughter left this morning with my 89 Accord and it is on the back of a trailer on its way to a new home in Tennessee as I write, It really broke my heart to see it go.
I decided to pay to fix the GT bumper out of my own pocket rather than have the insurance pay and screw up my safe driving rates.
Cheers Pat.
http://www.mobil.com/mobil_gas/us_fuels_map.pdf
http://www.mobil.com/mobil_gas/product_data.html
Ron - the U.S. Fuel Map might be of some help.
Kevin - I have the Michelin Energy MXV4s on my '98 OB and am very happy with them, however the $ may not make it <300. Only one odd experience with them last night which "juice" had pointed that my tires sidewall may have rolled under.
Isn't BFG a division of Michelin now?
-Colin
Patti
Sube's and sand being a problem? Bunk. I have never heard of a problem (and I look at a lot of our contacts) and found a problem with sand and our vehicles. Also, I've done a lot of "sand" driving w/o a problem.
Patti
Patti
Kevin
Michelin now owns BFG Tires? I like both, but Michelin needs a pricing reality check. It seems like they're about the most expensive tires you can buy.
-juice
-mike
-Colin
If the transmission is replaced, the entire AT was my case, would the repair manifest indicate if it is new or re-man'ufactured'?
My manifest indicated neither.
-juice
You can do something called plus-zero sizing where you can put on a slightly wider tire that has a lower profile compared to the stock tires. The benefit is a slightly wider tire but the down side is that your sidewalls will bulge a little more.
For example, a 215/60R-16 could be replaced with a 225/55R-16 on the same wheel. Note that the overall diameter needs to remain the same.
Ken
As a fatter of mact she does not plan to winter drive it even in Tennessee.
Cheers Pat.
PS. she took some photos of it when it was on the trailer she said she would send me the negatives when she gets them processed so I hope to eventually post them.
Let's see. Michelin purchased BF Goodrich tire division, and Michelin is partnering with Goodyear in developing the PAX system or something the likes. No mentioning 'bout Dunlop.
Cheers,
-wdb
Patti
Steve: I think the brights adjust along with the regular lights. On the Forester it's on the back side of the headlight assembly, but the Legacy's lights are different.
-juice
-wdb
RR
I'm driving my Forester in the Central Valley very often. It attracts so many bugs and little stone chips that I thought some protection would be nice. I don't like plastic deflectors mounted on the hood.
-juice
Basically what happens is that any road grime, sand etc. gets under the bra (between the bra and the paint) and then acts like sand paper filing away your paint (which is thin to begin with on the forester). I am personally lazy so I wouldn't want to take it off weekly to ensure my paint doesn't get sand-papered away.
-mike
Mike's right -- bras require a bit of maintenance on your part. You basically need to keep the underside of the bra and the paint that comes in contact with it clean at all times otherwise you'll get a abrasion where the two meet. You'll also not want to keep it on while the fabric is wet since the trapped moisture can also damage the paint in the long term (not that that's a problem in the summer in CA).
Ken
Kewl!
Ken
The guy said they now could order from Subaru, but still had problems shipping things out. I'll try to reach her and figure out what the deal is, but it may not be completely resolved yet.
-juice
-mike
-juice
-mike
http://albums.photopoint.com/j/View?u=1013602&a=7966143&p=33242600
Ken
