Visitor Agreement.
I also have a '98 F150 with the 4.2L engine, and I still have the window sticker that came with it that says the DOE/EPA estimate is between 16 and 21 mpg. And that's about what I get. I had reported on this a couple of months ago when I just came back from a 5000-mile round trip (NJ-Arizona-NJ) and this weekend I did 447 miles of highway driving with 21.3 gallons which comes out just shy of 21 mpg. But my problem is that most of my driving is local, so I'm ususally either accelerating up to or braking down from 40-50 mph; therefore, I ususally get only 16-to-17 mpg. Mine's got an automatic, but the irony is I really would have preferred the standard transmission for a pickup and only selected the automatic because of the heavier towing capability. It would be interesting to hear from others with this engine and a manual transmission to see if they're having the same bad luck you have reported. If so, that might suggest it's the manual transmission, and that's something I would have never expected.
As far whether the 4.2L has too little power for this size pickup, I don't believe it. I gave that a lot of thought before I made my selection. We're talking about 205 vs 220 HP which is less that a 7-percent difference. I drove both before I bought and they felt pretty much the same to me. I know some will disagree with me on this, but I also think that many others, if they test drove both, wouldn't be able to discern a difference in power.
Rich
Gary
Gary
1. Is this typical mileage?
2. What's the "break-in" mileage for a RAM 1500?
3. I'm getting a Tonneau Cover should I expect gains in MPG?
Ed
1. You didn't say which engine or axle ratio you have, but for either the 5.2 or 5.9, you're in the ballpark. On the high side, a 5.2 might get 12-18, and on the low side, a 5.9 might get 10-14.
2. If you've had the first oil change and no problems were detected (excessive shavings, burnt oil, etc.), you're broken in pretty well. Another 5000 miles of shakeout and everything will be pretty much where it will always be.
3. The tonneau cover might gain 1 mpg, but don't expect Cummins-like numbers.
First oil change was at 2600 miles. I know that is early, but the next day I left on a 1500 mile trip through the mountains of Pennsylvania and New York and on up into Canada. Didn't want to deal with oil change on the trip nor wait till after.
I'm not expecting Cummins-like numbers, nor really any gain. I'm getting the cover so I can use my bed more like a trunk from day to day.
Mostly I'm making sure all is good and right with my truck. It's a big investment and I knew that gas mileage would be miserable compared to my old '93 Chevy S-10 with it's 2.8L V6. But then again look at that WIDE OPEN SPACE!
A taller tire will be like dropping down to a lower ratio say from a 4.10 to a 4.00. How much? depends on how much taller.
EPA ratings are based on GVWR. If you're at 8501 or higher, you're NOT rated.
Manufacturers are allowed to publicize road estimates of what they got in their own testing, but since it is not an apples-to-apples comparison like the EPA test, it's pretty useless in terms of comparing makes and models.
On the Dodge Ram page of the Cummins website, there's an FAQ section where the question is posted, "what's the mpg?" Cummins smartly responds by saying "drivers have reported" anywhere from 12 to 25, with most averaging 17-22, and major options like weight class (3500 over 2500), transmission type, and 2wd vs 4wd will affect mileage.
Me, I have a 96 Ram 3500 Club Cab, Cummins, 4x4, automatic, and 3.54 axles on stock (215/85) tires. My best tank is 22 mpg (on its first birthday), but if someone asked me my average, I would tell them 13-16 city and 18-20 highway.
The truck rags (Open Road is my personal fave now, wish it came out more than 4/year) are probably the only reasonable source for mpg of over-8500 trucks, as they will drive it the way most people would, and give a real-world figure. In fact, it was Open Road's test of the Ram/Cummins back in their premiere issue that solidified my engine decision.
The Silverado 2500 falls on both sides of the 8500 barrier. The 2wd trucks with the 6000 engine ARE, in fact, rated by the EPA, as their standard GVWR is 7200.
Anyway, because the Ford's tires are taller than the Dodge's, the Dodge with 3.54 and the Ford with 3.73 have the same effective ratio. Likewise the Ford 4.30 vs the Dodge 4.10.
With 500 lb-ft of torque at your disposal, the 3.73 will do just fine unless you are regularly dragging small buildings behind you.
Ford runs 215/85s on the 4x2 DRW and 235/85s on the 4x4 DRW, and 235/85 or 265/75 on the SRW (the 235/85 and 265/75 are the same height, and the 235s are optional on the 4x2 DRW).
question,
has anyone provided comparison information on the dodge v-10??? i still like that published torque curve much better than the curve for the ford. i wonder if the magnum is any better (or worse)than the triton. considering all the other disadvantages previously discussed on any of the diesels this has just about confirmed my decision on the benefits of the v-10's. thanks for your effort.....
I know the cost of parts and labor is about $940, but Them changing out the gears was part of the deal of me buying it. I payed $500 over invoice and had a $400 college incentive. So over all I payed $100 over invoice and the rearend did not cost me anything because if they did agree to change the gears I wasn't going to buy the truck.
I have had the new gears in about a week and I can tell a huge difference in how the truck runs. The rpm's run about 300-500 lower.
cw
Bogieman
I also tow a pop-up in the nort east with a truck and thinking of putting a stableizer on it for those curving back roads. Any thoughts?
Gregg
Bro in law with new 5.3 Silverado is claiming over 20 MPG on highway - I think he also practices new math!
gregg
I would like to know where and how you drive, what kind of gas you use, what kind of tires you got on. I have the same vehicle with 265/75r16 highway tires inflated at 45psi and the best I could do is about 17. I assume it is an automatic and 4WD.
