Visitor Agreement.
Gregg
Jim
Back during the gasoline "shortage" and contrary to popular opinion, we were advised to drive with the air conditioning on and windows closed. It seems that the aerodynamic drag caused more fuel usage than the air conditioning. With todays more efficient air conditioning I expect that the mileage improvement is even more by using the A/C.
Rich
15 MPG average thus far
all city 10mpg
Who cares the company buys the gas!
My 5.4 F250 4X4 3.73 rear axle with 2,000 miles on it is getting 13 in the city and 16 on the highway, mostly city driving. I expect the mileage to get better as the engine breaks in even more.
Drove 1000 miles this weekend. Best mpg:19.6. Average for trip:18.03
Huntman
I started with 800 miles on the clock. I was driving about a steady 70-75 mph, maybe 30% on cruise control,. The road was flat, no wind and about 65 degrees outside. I am not driving a sports car so I am light on the throttle and know how to move through traffic without much fanfare and at a steady speed. I am amazed this truck can get such mileage. Where are you located? I will report my drive to work mileage when I have a bit more experience with the vehicle. I drive 40 miles to work and 40 back, all but 3 miles on the freeway...
11.5 to 12.5 Mixed driving with a somewhat heavy foot. Was hoping for 14 Oh well. Love it so far.
That is pretty good gas milage, but it is very believeable. On my truck I have been driving mostly five to twenty-mile trips usually about 65 MPH. Every engine is different and some losen up sooner or just get better gas milage. I have to say that my foot does tend to find some lead in it occasionally but not usually. I have also found in my previous car that what octane or even what brand of gas can make a two to three mpg difference. What octane and what brand of gas do you usually run. Thanks for the info.
Huntman
Have been using 87 octane Cheveron. The 6.0L seems to like it OK so far, no pings or knocks. I live in an area,(Houston- Galveston)that has MTBE additive gas for reduced emissions. I have found the gas to give about 10%- 15% less gas than non MTBE. The feds say 2%-5% less HA HA. Had a ford with a 302 that would get 15 mpg with gas from Houston. When I traveled to Corpus Cristi and filled up I started to notice better mileage like 17.25 with the non MTBE. This is about 100mi more range on the 43 Gals. So on the way home I always filled up both tanks at the last station that sold the good gas before the houston metro area. Also my ford ranger with a 3.0L went from 17.5 to 19.5. Have not gone far enought with the new truck to get the Non MBTE but I expect the same results. Have also found that higher octane rating has not increased MPG on any of my vechiles. Althought some do run better. Another intresting fact with the MBTE Reforumulated gas, the Higher the octane the leaner it runs,(more O2). This is real bad for 2 stroke engines and 4 strokes with carbs. The outboard boat engine manufactures now recommend using 87 octane RFG only.
P.S I think your right about the breaking in and the different mpg of the same motors.
SteveS
5.9L auto
1800 miles
50-50% city/highway driving
average about 16 mpg, up from 14 when brand new.
5.9 gas w/auto
200 miles
intown 14.5 mpg
up from 13.9 first 150 milse
i plan on going on vac. the first of May hopeing to have a 1000 miles on the truck so i'm able to change the oil at home myself, it looks like it will be a 3000 mile trip, when i strat the trip it will be the first time i will have the truck over 50 mph. what do you think? should the eng. be broke in enough to go over 50 mph and should i change the oil that soon?
Huntman
Do you really need the 6.0L, If you are going to get an automatic you might as well get a 5.3L and add helper air shocks for about $400 that are good for up to 5k lbs.
Best of luck
Huntman
I have 6500 miles on it now, and those numbers have improved. My last highway tank was 18.6, and my last city tank was 17.1 mpg.
I modified my cooling system thermostat to lower the operating temperature by 13 degrees from 204 to 191. Not sure if that helped the mileage, but it definitely runs smoother.
It seems though like something has helped the mileage, if not my thermostat mod, then maybe some seasonal factors, like re-formulated fuels, or perhaps it's just fully broken-in now. But I'm very happy. With my 34 gallon tank (standard on long box), I can go 600 miles before re-fueling.
'99 F-250 SC 7.3L PSD and 3.73 rear end.
Have a LT 4X4 5.3 and 4.10,s. 55mph is about 1750rpm. Am very happy with truck.
Best tank highway was 18.6 mpg. Worst tank city was 14.5 mpg. Last tank, went 498 miles, took 30.772 gallons, 16.2 mpg in the city with about a 50/50 mix of freeway cruise, stop 'n go.
Mileage improved after about 5000 miles.
Every time I bump into a Ram driver at the diesel pumps, they always throw 22 MPG at my 18 MPG '99 F-250 PSD.
Rich
Nebraksa and the dakota's being big corn states alcohol/gasahol is pushed for motor fuel year round so that may not be the difference.
My numbers for a F350 V10,CC,4.30 rear, with 8800 miles, has been 10-11 in town and 13-15 on the highway, but it is tough to keep it under 75 out on the wide open highway of Wyoming.
Cowpokes
