1999 Lexus LS rolling backwards in Drive
I have just purchased a 1999 Lexus LS with 49K on the odometer. Had a safety check from the selling dealer AND had it looked at by the local Lexus dealer before purchasing it. I parked at my residence with the car's nose pointed uphill on a modest incline. On going to use the vehicle, I started the car with my foot on the brake and then shifted into drive. I took my foot off the brake. The car, in D, proceeded to roll backwards down the incline and almost into my garage doors! Only by applying the the brakes and then quickly moving to the gas peddle was I able to get it up the incline. Advice on the problem before I go to the Lexus dealer. Thanks.
A manual transmission, in the same instance, would cause the car to cough, sputter and die.
There's nothing wrong with the car, it's just an incorrect perception of the operation of the transmission.
Transmissions aren't a device to keep you planted on a hill - that's up to the braking system.
Cars are different.
Their rolling resistance, idle speed, power transmitted through the torque converter and transmission at idle speed, brake drag, etc, etc, etc are all variables here.
But, by golly, don't believe all us posters, take it to the Lexus dealer. The service people need to get their daily snicker, and you will be it.
if you have such a line in your Lexus manual, you know why now. you have to two-foot off a hill from a stop, I guess, but at least it's not two feet and three pedals, like you have in manual trannies.
oh, yes, that's manuals WITHOUT a hill-holder feature, which is most of them.
If they are, wouldn't that make it a lot easier for the car to roll backwards while in gear?
For myself, I can't think of any reason not to use the lockup mechanism in this manner.
This might also account for the throttle tip-in hesitation some Lexus owners are complaining about. In the past I have advised that this hesitation might be the result of the engine ecu delaying WOT activity until the "WOT" VVT-I and the intake plenum settings can be "finished". But it certainly could be that time is needed to release the lockup solenoid, or maybe all of the above.
Hmmm....
So, why doesn't an automatic transmission, especially today's version, with an ECU that "talks" to the engine ECU, automatically shift into neutral if the E-throttle is at the idle position?
Its all about fuel economy now!
At TC stall [the output turbine stopped] the entire excess power of the engine [a few HP at idle]is heating the ATF to hold a 4300 pound car on an incline [even a 10% one]
http://home.a-city.de/walter.fendt/physengl/inclplane.htm
would be between 15 and 20% or 860 lb/ft.
Not many engines put out this much extra [x 1st gear and diff say divided by 12 or 70 lb/ft] at idle when coupled thru a low efficiency TC.
If you raised the in gear idle speed to 1200 rpm it will hold before the TC explodes. But on a level road idle would make you travel at 13 mph with your foot off the gas!
