Visitor Agreement.
The last tank I checked mileage on was 89 octane and it seemed to be worse than using 87.
I agree. There is a lot of money wasted on premium fuels that are not needed. I've used only 87 reg and it runs fine. No pings at all.
Scott
Let me know how the 5spd auto feels. Ford built this transmission for one mission, hauling/towing.
I have different feelings about premium gas. I have tried all three 87,89,91 octane and it seems the 89 is the best for my truck. When I run 87 I do get some pinging on acceleration up hills or from a stoplight. When I use the 89 octane the pinging goes away and the engine seems to run smoother.
I used to have a superchip in my truck which required 91 octane. I only install it when I go into the mountains for the weekend. Premium is just to expensive to run all the time in a 4.0 4x4 Ranger.
One thing I do is purchase gas from well known retailer, Texaco, BP, or Chevron. I never use Arco, or a brand this is unknown.
Last tank was aprox 21mpg which included 300miles hwy, running in 4X high hauling 1300 lb H2O a bit and some climbs to the top of the Wet Mtns and running down 5 very rough 4X roads, partially in 4X low.
The engine will break in somewhere around 10k and you SHOULD see an increase in mpg
You said you had the superchip and need the higher octane.
Wish I had the camera last weekend, will take it next time to get some pics of the bad boy trails I was on.
He Vince or anyone else considering 4 wheeling in Colo. Try this site. The books are EXCELLENT, better than any others I have seen.
http://www.4wdbooks.com/
Fantastic, information packed, easy to read, and reasonably cheap. Plus its a local run mom/pop organization. Try the 800 number and you get the internet price.
Thanks for any info..........JLOCO
A few weeks ago, I rented a Ranger from Budget for a business trip (it was actually cheaper than an intermediate car). This became my first real drive in one besides a trip around the block. It was a 4x2 SuperCab 4-door with the power group. Pretty much what I was looking for in a truck. Although I thought the ride was great, it was comfortable and the dash board items were easy to reach, I did notice a few things that I would nit pick on and was wondering if anyone else noticed these things...
1. The visibility of the driver side "blind" spot. When peering over my left shoulder to check my blind spot, I sometimes found it hard to see because of the thickness of the B-column and the smallness of the back side window.
2. The air/vent controls. In order to turn off the air, you do not turn the air dial off, you turn the vent dial to an off position. As soon as you move the vent dial to a vent location, the air is turned on.
3. The fact that A/C is considered to be a vent location. On most cars I've been in, the A/C is a button you turn on, irrespective of the vent location. That way you can have the A/C on while defogging the windshield (the A/C dries the air out and thus helps to defog the window even if you have the air temperature set to hot).
4. If the truck is on, the keyless entry remote will not work. Kinda prevents you from starting up the truck on a cold morning and then when you come back out using the keyless entry remote to unlock the door.
5. On a great note, I loved that when the headlights were on the dashboard lights, including the clock, did not dim.
Anyone have any thoughts on this? Now don't get me wrong. I still loved the Ranger (that's why I ordered one).
- The Merg
2&3. In the owners manual it says that the A/C will be used depending on temperature in all settings except for the vent settings including the defrost for just the reason you mention. This seems to be a new Ford thing.
4. This also seems to be something more popular these days. I had a Sunfire that was the same way, traded that in for a Taurus that has the number pad under the drivers door handle. With the cost of keys for the 4.0L Ranger I really don't want to carry two just to warm it up.
But for any of the nitpicks I have with my truck, I wouldn't give it back. This is my first truck and it has been 2 months and 3000 miles of happiness.
JPC
Just looks kewl, keeps the leaves out of the bed, keeps dust/dirt out and it is a place to put luggage free from rain and free up the behind the seat area.
Thanks......Jloco
Driven it almost 900 miles now. I am starting to hear a "whiny" noise whenever I am in DRIVE, stopped at a stop light. Or whenever I am in REVERSE, moving or at a stop. Not sure where the noise is coming from, but it is annoying.
Has anyone experienced this ?
Is there something wrong ? Or is this a noise as a result of the "breaking-in period" ?
Just worried if there is something wrong...
-Frank (ftsui@earthlink.net)
There was a lot of mud up there and it was sure nice not getting stuck as with my old 2wd.
When you get the limited slip option I assume that is just the rear and not the front axle, anyone know that?
What tires and axle ratio do you have Trent? My 00 Ranger with 4.0, auto, off-road (4.10 limited slip and the 16X245 tires) is due in 10/18. Hope it gets better mileage than my 150 with 5.0l, auto, 3.55 limited slip - about 13 around town and a best of around 18 on the road if it stays under 60 MHP.
wannaranger
JLOCO
Do not know of a recall but they do it under warrenty. I would be changing suppliers. . .
Sounds fair on the bird and Ranger. But only V6's ar 3.0 and 4.0. Your talking about a 4cyl. If your just looking to bum around, no 4 wheeling/towing, it should work for you. Price should be in the neigborhood of 10K for what your wanting, 2X, 2.5L, regular cab depending on other options. Look for sales etc in the paper.
Does anyone have a recommendation on a particular brand of class III hitch for my 2000? I was happy with the old draw-tite but see that there are quite a few other brands out there. I don't pull a real heavy load, but do pull a motorcycle trailer and want the security of the class III.
If anyone is interested I will sell the old draw-tite class III for $50.00 plus shipping. It is a #75036. I called draw-tite and they said it fits an '83-'94. Please contact me offline at sblancard@logicon.com if you are interested.
Steve
I also had an extang tonneau cover installed. I'm very pleased with the quality and fit.
Whew...I'm glad that's done. No more accessaries for a while. I'm broke!!!!
JLOCO
JLOCO
I had the moulded color keyed installed and find that they don't provide enough and safe foothold going into or coming out of the truck.
- The Merg
I really want to be sure before I sell my Firebird. Help me out gang, I don't want to jump at anything before I am totally sure.
wannaranger
travisml
Personally, I feel the 3.0 is the way to go, with a 5spd. The MPG is only about 3-4MPG difference.
But once again, its your choice. Ever thought of ordering one the way you want it equipped?
wannaranger
Ford Ranger II.
Please continue this discussion there.
Front Porch Philosopher
