Splitfire plugs
Any experience/oppinions out there about the usage
of splitfire plugs and wires. They also sell
platinum plugs now. My '97 Vortec 5.7L will reach
50K soon and I am looking to do a "tune up".
I've heard they're worth the extra$$ on a car or truck you plan to keep for awhile.
Currently I am in the mood to push the darn thing over a cliff, the oxigen sensors and the egr valve is failing and trying to have GM fix it under the emissions warranty.
I'm sure that the claims we see on TV are true for that particular testimonial. What we don's see on TV is that it's an older vehicle that gets tuned up every 50,000 miles, needed or not. Maybe at the Split Fire tuneup, the carburator is adjusted too. So the claim of the large percentage in mileage increase is probably true, in that one particular case.
The advantage to a larger ground electrode is two fold. (The split sort of puts more metal closer to the center electrode.) First, more ground electrode material closer to the center electrode means that the plug will retain the correct gap for a longer firing time. (Less burn off and carbon build up.) The larger ground electrode over the center electrode means more surface area with the correct gap between electrodes.
In today's modern, high secondary voltage, ignition systems, I seriously doubt there is much of an advantage, especially on a well tuned vehicle. I personally do not think that the SF plugs justify the added expense.
Rich
DS#1 Gee, I put new plugs in my vehicle and in a very uncontrolled experiment, and got better gas mileage.
DS#2 Were the plugs splitfire, or platinum, or snake oil brand?
DS#3 Dunno, but they sure are better 'cuz if i didn't say that I would look like a dumb##it.
LOOK around at racers and see if they run the snake oil stuff when not sponsored. Bet not too many of them run STP or DuraLUBE or Slick50 or Splitfire or Pet Rocks or....
Just Like that PT Barnum guy once said 'there's a sucker born every minute'.......
I think you will also have to install a "spark trainer" so the spark will go to the correct electrode
NO DIFFERENCE WAS NOTED. ITS ALL IN THE NUMBERS.
EVERYTHING ELSE IS EMOTION.
When we had points, condensers and rotors under the distributor cap the efficiency of the ignition system was about 90%. As spark plugs aged in the engine, the efficiency fell off towards 70%. Enter ordinary "Transistor Ignition". This raised the efficiency to 99% and kept the plugs operating at mid to high 90% efficiency.
Unfortunately people would still wait until performance was poor before tuning up. So the plugs would really go to do-do and again the engine was running at 70%.
Enter the feds and the EPA. We wound up with better electronic ignitions (40-60 KV), resistor and platinum plugs. The platinum allows the center electrode to be run at a hotter temperature to burn off deposits.
Today's engines with the 100K mile tune up specification are probably running even higher voltages on the secondary. Maybe even 100 KV. At those voltages, a nail in epoxy in the plug hole would work; for a while.
With all these advances in ignition systems, I seriously doubt that the split fire plug would be an advantage. But at 100K miles, spend the $80 for a set of split fire plugs, it's only about $30 more than platinum plugs. (Or .03 cents a mile.) After 100K miles and then new split fire plugs, I'm sure you'll notice an improvement.
Rich
I agree 100%
Ryan
What I heard is rapidfire is an AC plug that produces more (or mor often) sparks than standard AC plugs. I don't know if they are platinum or if you would have to make some ignition modifications. Need to call a dealer for more information.
A SPARK PLUG IS JUST WHAT ITS NAME SAYS. IT LIGHTS THE FIRE. ONCE THE FIRE IS LIT ADDING MORE SPARKS OR A SEPARATED SPARK TO IT DOESN'T DO A THING.
NO ONE IN THE DRAG RACING WORLD USES THEM AND CLAIMS HE GOT EXTRA HORSPOWER WITH IT. WE KNOW IT IS SIMPLY A GIMMICK. YES THEY LIGHT THE FIRE LIKE ANY OTHER PLUG, BUT A FRESH SET OF PLUGS IN THE CORRECT HEAT RANGE IS AS GOOD AS IT GETS. I'LL BET THOSE THAT CLAIM IT HELPED HAD LOUSY PLUGS OR PLUGS WITH THE WRONG HEAT RANGE.
YOU GUYS AREN'T THAT DUMB TO BE LED DOWN THIS PATH.
Sorry, I just cant see the value of the investment in the more expensive split fire plugs.
Rich
