'99 Silverado/Sierra vs. F-150
DirltonDirlton Member Posts: 30
New to pick-up frenzy. GM on brain but currently
leaning Ford. 4.6 w/manual vs. auto vs. 5.4? Best
spec. out for general use/limited, light towing?
Want 4X4 because it comes in damn handy
occasionally (Minnesota), ext. cab, nice radio,
etc. Not afraid to spend $ but do not believe in
spending what doesn't need to be spent. Then there
is the issue of maybe should keep GM on brain. Need
help bad. Please respond dirlton@aol.com
«13456710
    If you want an extended cab, I would go with the Ford because of the 4th door. I would also probably go with the larger V8.
    Yes, I know the GM models have a larger extended cab, but the convenience of the 4th door (for me) would be the deciding factor. Also with the F-150, you get a split rear seat. That's not available on the GM models.
    If you can wait a year, GM will have a 4th door on the extended cabs.
    In GM's favor, however, are standard 4-wheel ABS brakes, more powerful engines, and AutoTrac 4x4.
    Bob
  • KEH4x4KEH4x4 Member Posts: 109
    If you will keep the truck longer than the warranty, I would get the Ford. Chevies are notorious for automatic transmission failures, and air conditioning failures. Both expensive. Plus the Ford has the fourth door, and is a little cheaper. Also, I think the Ford has a more twenty first century look. The Chevy looks too much like the old design. And I hear that because of the recent strike, GM trucks are few and far between and demanding higher than normal prices.
  • signasigna Member Posts: 26
    I currently shopping for a replacement for my '93 Chevy Silverado. Currently, I'm leaning toward the Ford since the new GM is sooo conservative, and it lacks the fourth door. It all depends on what style you prefer. Don't let anyone tell you which truck to get on a reliability basis, they're too close to matter.
    KEH4X4: My '93 Z71 has 130,000 miles, and both the auto trans and air conditioner work perfectly. Infact, they've never been touched except for an oil change in the trans.
  • cdeancdean Member Posts: 1,110
    KEH4X4
    You can look up reliabilities and see Ford's automatics trannies have a much worse track record than GMs. GMs are regarded as the best automatics out there. I've never heard of ANY a/c failure on GMs other than '94 when they had a recall on their compressors because they were using the wrong oil.
    signa
    have a look at the GMCs. I like the styling a little better on the GMCs, and you still get all the mechanical advantages this new truck has over everyone else.
  • kent123kent123 Member Posts: 61
    I was going through the same decision about 6-8 weeks ago. Liked the 4th door on the Ford, but after driving both, the Chevy impressed me with better, smoother power (5.3 Chev vs. 5.4 Ford) and overall better fit and finish.
    I ended up talking to a friend who has a car lot that deals exclusively in late-model, low-mileage stuff. He said that the Chevy PUs get sold much faster than Fords and hold their value better. So, even if the initial price is lower on the Ford, cost of ownership may be higher than the Chev.
    I ended up ordering a 99 Silverado LT 2WD Ext. Cab. Order placed mid-Sept, "preferenced" on 9/23, but no build date yet. If they don't get it built soon, I may cancel and wait for 2000 model in hopes for a 4th door.
  • 26andrew126andrew1 Member Posts: 93
    KEH4x4
    The chevy comes with more features standerd. If you look at the options the price is very close, along with everything else. Except for the diesel and 4 door
  • DavyddDavydd Member Posts: 121
    <<In GM's favor, however, are standard 4-wheel ABS brakes, more powerful engines, and AutoTrac 4x4.>>
    That's a BIG HOWEVER! The Chevy trucks are totally reengineered under the sheetmetal and are now years ahead of Ford technically. It's a no-brainer for me. Chevy is it. My two cents.
  • malibu1malibu1 Member Posts: 52
    Yeah, I wouldn't base my decision to buy a new truck on the fact that it had a "21st century look" and that it had a fourth door. That sounds like things my wife would use to pick a truck. I go for power and reliability and Chevrolet wins that battle hands down.
    Cdean is correct also in the fact that GM has long been the maker of the best automatic transmissions in the business. Ask around, I am sure you will get this confirmed by people that are in the 'know'.
  • BrutusBrutus Member Posts: 1,113
    Chevy is years ahead of Ford? Where is this huge technological advantage? In the rattling third door? The lack of a supercab fourth door? The lack of a competitive diesel? The lack of a V-10? Fewer chassis options? Chevy will eventually get to all of these things, probably within the next two model years, but who's years behind?
    Chevy's V-8 engines have always had a little more horsepower and get a little better mpg. That's nothing new. Chevy makes a good truck, as does Ford, but there is no doubt that Chevy has been following, not leading, for quite a few years. If you really like something new that shows up on a Ford, wait a couple years and you can buy the Chevy version.
    Brutus
    You're mentioning different things. mechanically, chevy is ahead of Ford. better engines, brakes, frame, transmissions, ride, suspension... all you have to do is drive one to see it. do they need a V10. i don't think so, not with a v-8 that has more power, torque and same mileage as ford's v10. they do need another diesel. but those things aren't what this discussion is about (1/2 tons). go and read every magazine with a truck review in it, and they all say chevy is ahead now.
    they're ahead by exactly 2 years. The '98 ford vs '98 chevy had several advantages, such as the door prob, better ride than chevy, better ergonomics, IMHO. the truck was engineered 9 yrs after the '98 GMs. putting it lightly, there have been quite a few technological advances over those 9 years. GM has just now put a product with this technology. Now the '99 GM trucks are ahead of the class in every other department. it doesn't mean that ford all of sudden sucks, it just means chevy's got the latest cutting edge techonology in their product, and ford has 1996 technology.
    please give me an example of when chevy copied anything from ford, because i can think of none.
    it just seems that the stuff you're interests lie in come with a blue oval on the front. And there's nothing wrong with that. :)
    Cdean
    cdean,
    Brutus, like myself, comes from the heavier end of the pickup spectrum, although I have owned half to\ns in the past. Almost everything on the new Silverado/Sierra is already available on the F-Super Duty truck, but not the 150/250LD. I believe this is where Brutus was going with his comparison. The Super Duty Ford has the 4 wheel discs, an outstanding frame, the automatic from hell, and like the GM trucks, an evolutionary design change as opposed to a radical one like the 150/250LD or the Dodge Ram.
    In 2001, everybody will be all caught up - the updated Ram will be released, the 150/250LD will be upgraded, and the heavy GMs will then be available. Coincidentally, that's when my loan ends on my 96 Ram - will make for some interesting comparison shopping...
    i realize thats where the interests, sorry if i didn't make that evident. comparing the Ford SD to the '99 silverado are apples and oranges, but you do see the "technology of the times" like i was trying to get at it.
  • DirltonDirlton Member Posts: 30
    Did not intend to start a GM vs. Ford war. If you look back at the original post I was asking for help/info in spec-ing out a new 150 should I decide to go that route. Particularly opinions on the "brightness" of choosing 4.6/manual vs. other configurations. Any other views in regard to "best" drivetrain, axle, tires, etc., etc. would be MUCH appreciated. You guys know the lay of the land better than I. Please remember I am after just light duty, occasional light towing, light hauling capability, and creature comforts. If I decide to go the GM route (a distinct possibility), I'll just pester you people some more. THANKS.
    I think that the Chevy and Ford are both good trucks. The statement about Chevy being years ahead of Ford, kind of, seemed to me to be similar to saying, my dad can beat up your dad, so I decided to respond in controversial fashion. I don't thing either truck is years ahead of the other.
    kcram is right that I compare everything to the heavier end of the market. I'll admit that my knowledge of the F-150 is fairly limited. Obviously, I'm bias to the blue oval based on my experience with Ford trucks. Once again, though, my experience is with the heavy duty models (F-250HD and the new truck).
    cdean,
    You've got a lot more experience with all of the different truck manufacturers. Your mechanical background is also light years ahead of mine. As a matter of fact, I've had people e-mail me with mechanical questions, and I refer them back to the site and, specifically mention that they should seek you out.
    Most of what I have learned about issues related to towing, torque, hp, axle ratios, etc. have been gained from this site, followed by some additional research. Anybody can verify that by scrolling back through the posts from earlier this year. I volunteer my two cents worth on this site, because I know if I'm way off base on an important issue, someone will jump in and correct my information. Although I may have engaged in some friendly banter about the Ford vs Chevy argument, I think it's safe to say that I've never contradicted you on issues of substance.
    Of course, I still think that Ford provides the best overall quality vehicle, but who knows? Maybe I got lucky with my last truck.
    kcram,
    I finally visited "Salesmen are people too" recently and saw you were participating there. There were over 300 posts since my last visit. Most of those salespeople seem to be pretty above board guys. Still, their line of thinking is on a totally different tangent than the average consumer. When you see the knowledge they have, it's easy to understand why so many vehicles are sold for close to MSRP. These guys are pretty slick and they tend to get really offended when they think you are treading on their turf. I made some statements that are sure to get a rise out of them. I'll probably participate for a couple of days again and then stop. They really do hash the same issues again and again. It's easy to get caught up in it.
  • AzchevyguyAzchevyguy Member Posts: 20
    Dirlton:
    There would be no bad choice on any of the Big 3 trucks. The Big 3 are putting a lot of quality in building these trucks because they are big sellers producing big profits. I love the Silverado, even though it only has three doors (just a couple of years ago, extended cabs only had two doors). It's new engines are smoother and more economical than the previous ones, and once your rear seat passengers get in that one door they will be treated to more leg room and comfort than they ever had in an extended cab pickup. Everyone here can give you their opinions, but you need to check the all the Big 3's trucks out for yourself. You will know for yourself which one is for you. Happy Hunting!
  • alchavezalchavez Member Posts: 28
    Being a "born and raised" Chevy guy, I am looking forward to purchasing a new Sierra (To me it looks better than the Chevy for once). I do believe that Ford is indeed ahead in the quality department but I have a 2 year old daughter and and planning on having more kids soon. So the issue of roominess is important to me. Since these days its important to have every kid under a certain age in a carseat I think the sheer size of the new GM rear seat in the extended cab seals my purchase decision. But a four door extended cab would allow me to place my daughter in the space behind the driver's seat without climbing through the entire truck and would make it easier to carry other passengers as well. Does any one else have this dilemma? Are the new Superduties roomy enough for a toddler car seat in the back ( not sitting in the center). (Of course, rear-facing infant seats are another story.)
    alchavez
    p.s. Don't nobody suggest that I get a minivan, my ego can't handle it. Besides, I want the truck to go camping and hope to buy a 22 foot camping trailer in the very near future.
  • SilveradoMacSilveradoMac Member Posts: 11
    Yes, there are "slick" salesmen. There is no doubt about that. And yes there are a great many that are above average. Let me tell you though that there are certainly "slick" buyers that no one EVER hears about. Its always the salesman who is the slime in a bad situation. What do you think the answer the customer gives us,when, after saying they want to take our car to their mechanic to have it looked at, we ask to let us look at their car also? I just wish you could be on our side to see what happens also. It is very one sided. Yes, I am a salesman, and I certainly know their are bad salesmen out there but ask a salesman to tell you a story about a customer sometime instead of just listening to the customer side. Just food for thought
    Brutus,
    I believe I made that "years ahead" comment based on the 1/2 ton (this message track, not Super Dutys) 1999 Silverado/Sierra improvements in small block V8 engines, cab space, brakes, transmission and drive train (Autotrak), electrical harness, hydroform frame, etc. Dodge had its "years ahead" shot in 1994 and Ford got its "years ahead" in 1996. Now both have about a two year catch up.
    Besides the fourth door, the slam against GMC/Chevy is in the exterior design--probably about the least important consideration for a pickup truck. Personally, I support their conservative decision of design evolution.
    alchavez,
    I keep looking at both the Sierra and Silverado in my own mental debate as to which I like best in appearance. Despite what I said above about design, we all suffer from our vanities. It's too close to call. The best deal will decide it.
    As for the fourth door, I think your concern might be the primary concern for the lack of one--when you are one on one with small children that fourth door is nice. One of my fellow workers with small children shares that concern. Ironically he bought a 20 ft. popup camper trailer this month and is now going to wait till next year to hopefully buy a 4 door Silverado. The wait is easier in Minnesota now that we are hibernating for the winter. ;-)
    The fourth door is not a major concern of mine. I have no small children and will rarely have rear passengers. I might think different when loading grocery sacks for the first time.
    grocery sacks for the first time.<<
    You hit the nail on the head with that statement. As the saying goes: "It's the convenience stupid!". I don't have small children either, so I would look to use that back seat area for "putting things". And... I don't want to have to walk around to the passenger side in order to access that space.
    Bob
    When GM did the third door on the S trucks, they intentionally put it on the driver's side because of what Bob said. GM's research showed most compact trucks are driven by people who carry stuff, not passengers, thus they wanted the door on the driver's side as a convenience. Conversely, full-size truckers with extended cabs carried passengers more than stuff, and wanted the curbside door for safer access, especially for schildren.
  • weslwesl Member Posts: 53
    Hey all,
    Just saw both the F-150/250LD and the new GMC Sierra at a local auto show. I really like the size of the GMC, but the quality is awful. Acres and acres of cheap and poorly fitted plastic. Ford has all the competition beat in this one area. When you slam the doors on the F-150, you get a solid thunk. Can't say the same for the GMC. I like the revisions made to the GMC, and love the powertrain, but could not see myself spending time in that interior.
  • adsfadsf Member Posts: 1
    As a chevy owner, I must say that the 99's center
    floor console is really a joke. Why did they
    move the cd player into the floor console and
    reduce the usable space in the console? The
    cosole itself is ugly too.
    Same stupid mistake on the lacking of 4th door.
    Now GM is the only big 3 that does not have the
    4th door on their trucks.
    Frankly, I think the idea of two additional short rear doors is so good, I wouldn't be surprised to see it show up in other kinds of vehicles such as 2-door SUVs and 4-passenger sport coupes. It would give a whole new meaning to the term "2+2". There's no reason to limit this idea to only trucks.
    Bob
    As a current Chevy owner, and current '99 F150 order holder, I must agree with the previous Chevy interior comments. The new Truck's insides are years behind Fords. That's why I've jumped over to the blue oval!
    A comment I read recently (can't remember where) stated it best "new Chevy interior -- by Fisher Price" ha ha ha. That goofy floor console was enough to send me over the edge...
  • sean8sean8 Member Posts: 2
    WELL, WELL, WELL !! I HAVE TO SAY THIS IS A FIRST FER ME. I WAS A BOW TIE MAN FOR MANY YARS AND I ORDERED MY FIRST FORD F150 4X4 SUPER CAB !! I WANTED TO GIVE GM MY MONEY BUT THEY JUST DID'NT HAVE WHAT IT TAKES. YA THE MOTOR HAS GOT LOTS OF POWER BUT THAT FORTH DOOR, GREAT INTERIOR AND GOOD LORD WHAT A FANTASTIC TWO YEAR LEASE!!!!!!
  • mp1mp1 Member Posts: 7
    Hey sean8....
    Can you tell us more about your F150 lease?
    <<Frankly, I think the idea of two additional short
    no reason to limit this idea to only trucks.>>
    Saturn is adding a 3rd door on the driver's side of its coupe which opens truck style.
    Have you noticed how the extra doors latch? If you get a chance take a look. GM and Ford have a good double latch. Dodge on the other hand, well you be the judge.
    On the Ford lease; on a 29.000 truck my payments are almost 600.00 with a lease @ 2 years 339.00. And if you can pre-pay your lease you save even more. It's not for everyone but it is worth a hard look.
    SEAN
  • cadmanncadmann Member Posts: 5
    I bought a '98 ford f-150 4x2 supercab shortbox xlt with 4.6l v-8 auto 3.55 axle. I had to replace my totaled escort. I purchased it on may 6 1998 and now have 12,000 miles on it. Quality is excellent, the only problem was a driver side mirror had to be replaced because of damage in transit. I average 18mpg to work and local short trips and took one trip of 400 miles and averaged 20mpg. Drivetrain is great if different from old pushrod engines, power is delivered differently. This is something a lot of people will have to get used to in new trucks, because this is where the are all headed. I am a FORD man but I won't lie about any problems I have. I have found that anything made by humans will break - period. How it is handled is what concerns me more than anything. My cousin had a cavalier(hope its spelled right) and had 5 a-c pumps go out in 1 1/2 yrs. Out of warranty after the 2nd one and gm wouldn't back it after that. Her father has a '85 chevy 1/2 ton that kept eating up head gaskets, dealer couldn't fix it and when it ran out of warranty gm wouldn't back it either. He finally pulled the engine out, tool it apart and found out the block had about a coffee can of casting sand in the block. I am sure there are the same kind of stories about ford and dodge out there also. Personally any problem I have had I have gotten taken care of by the dealer and Ford. That is where my loyalty will continue to go to. If I ever have something that they should fix and don't , then I will probably look elsewhere. Just my opinion.
    I rechecked the 1999 Chevy Silverado and its lack of the 4th door on the drivers side for the extended cab. Personally I didn't find it a problem. My wide body 230 lbs. handled it. The driver's seat back flips forward and the seat itself travels forward allowing you to step right in. With the cab 4 inches longer and the seats way more comfortable (and useable) than Ford no matter how you get in makes it better.
    Actually stepping in from the driver's side is easier than any 2 door automobile coupe because of the door height. There is no problem dropping brief cases, groceries, tool boxes or carry on luggage for that matter. Yeah, a fourth door would be nice but it is not a deal breaker for me.
    Actually I kind of like 3 doors. I carpool now and drop my brief case on the seat behind me with my 4 door car. When I take 3 people, the third guy always gets in the way of my routine. With a Silverado they can load from the passenger side and I can sneak my brief case under the rear seat out of the way before they get in the widest opening of the three (Silverado/Sierra, Ford 150 and Dodge Ram) on the passenger side. I don't want anybody fussing around on my side.
    When I test drove a 99 Chevy, there was no way I could fit a brief case behind the back seat from the drivers side, but the truck had power seats. The seat back would not fold forward at all. I guess the top-of-the-line LT drivers don't need
    to use the back seat!
    davydd: Did you really think the back seat was comfortable? I took a test drive in The Truck, expecting that it would be a major departure from other extended cabs, but it wasn't. You do have more legroom, but the seat back was still way too upright to be comfortable. Any full sized human is going to get real cranky back there.
    It's nice to hear that you like the new Silverado. I wish I could have found reasons like yours to like it, but there were just too many negatives. I ordered a *4-door* Ford.
    Wesl,
    I would avoid making decisions as important as what truck to buy based on the 'look' of the interior. I can maybe overlook some things that I do not particularly like that much in the interior, to get a better built truck with a more powerful engine, better tranny and so on. I would rather take a flight on the ugly airplane with the hard seats that had a good engine rather than the pretty plane that hits the ocean floor!!
    Malibu1
  • stanfordstanford Member Posts: 606
    The engines in the new Fords can hold their own with the new Chevys. I spend 25K miles a year in my truck (and many people drive more). I want something nice, comfortable, useful, and powerful and dependable. I wouldn't pick a new truck based on any single category, but I might discard one because of poor showings in one of them.
    Some people may love the new interior and not mind the fact that there are only 3 doors in the extended cab. That's why there's more than one truck manufacturer. Buy whatever you want :-)
  • dunbartondunbarton Member Posts: 46
    Guys,
    I looked long and hard for my first pickup ever. Tried them all, Ford, Chevy, Dodge. There was nothing I didn't like about any of 'em, just liked the 1999 Ford F150 (4 x 2 XLT 4.6 liter) a little better.
    I certainly am not going to debate the years old Ford vs Chevy issue as I have nothing to compare against nor do I have the experience.
    Could have been happy with any of the three, just got down to a personal choice.
    The extended cab rear seat on ANY of the "Big Three" are not for adults for any duration of time. Let's face it, nobody is going to buy an extended cab pickup to haul around adults in the rear seat.
    My fourth door was not an issue.
    So far, I don't feel I made a mistake....... Dunbarton
  • bdonbdon Member Posts: 30
    I too am about to become a first time truck owner. Can't justify it based on need. I just always wanted a truck and they are nice enough now to use as a second family vehicle. I'm leaning heavily toward the '99 Silverado. I don't really care for the look of the Ford and I can't make myself trust Dodge. So, maybe it's the Chevy by default. I have 3 young kids, so the larger back-seat is a big plus. I really wish the 4th door was out. If I knew for sure when that was going to be available, I might waut. But at the same time, my current auto needs new everything and is just about to fall apart. I don't think it will last much longer. I'm going to try and get to a dealer in the next few weeks and order one...unless someone out here changes my mind. This site has been a great source of info.
    Bdon,
    Hope none of your kids require a child safety seat in an extended cab.......and I hope all of your children are small.
    Think of the future when in a few years they get BIGGER. Extended cab for three children gets old fast. Think about a crew cab if it is within your budget. They are not that much more money.
    Dunbarton
    Signa,
    Yes. The Chevy rear seat is usable. There is 4 more inches than Ford. The seat itself is 1-1/2 inches deeper and the back reclines 18 degrees instead of upright like the Ford. They are contoured and they have headrests. And, yes, you can tilt the front seat and slide it. It makes a world of difference.
    I guess I don't what you mean by negatives in the Chevy Silverado 1500 vs. the F150. Chevy's brakes are vastly superior, bigger, longer lasting, discs all four wheels and shorter stopping distance. Comparable size engines have more horsepower than Ford. Chevy has AutoTrac 4 wheel drive. Nothing equal on the Ford. Frame is more advanced. Wiring harness has only 5 splices vs. 126 on Ford. The Chevy is a totally re-engineered truck and Ford will need a couple of years to re-tool and catch up.
    Now for looks. I quite frankly like the fact that Chevy looks like a truck should look. The Ford 250 Super Duty looks like a truck but the F150 does not. The F150 looks like a Taurus ovoid wannabe. Eventually Ford will regret what they did to the F150. Ford is already starting to abandon the ovoid look that is doing in the Taurus (once a nice car).
    The Chevy Silverado LT has a lot of nice interior touches. Yes, I also like the CD on the lower console. There happens to be a flip-up door right below the CD to store spare CDs. You probably missed that nice touch. I don't know where you would store them in a Ford. Probably the center console hatch. Having fun screwing around lifting it when driving down the highway.
  • rgjd401rgjd401 Member Posts: 5
    The GM trucks are by far the best buy. They hold up better and get better gas mileage.
    Their lastest automatic trannys are top of the line. I've never had an AC problem on any GM product, car or truck.
    Good luck
    Malibu1:
    I would never buy a truck based on the interior alone. You do make a valid point. However, if I did spend 25k+ on a new truck, I expect the quality to be good. The new GM p/u's are good trucks, but so is the Ford. Unless things have changed, you do spend all of your time inside the vehicle while driving. With Fords new DOHC 5.4, I think the truck is at least competitive. I accept that GM makes a decent truck, I was only hoping for better quality. By the way, I'm not the only one who noticed the poor fit and finish of the new GM trucks. I believe that Car and Driver was rather unimpressed as well. Of course, the GMC did win.
    dunbarton,
    If the truck was going to be the primary family vehicle, I would totally agree. But most of the time when we are all going somewhere, we're in my wife's mini-van. My dad has a '96 Chevy (Silverado) extended cab and my youngest child's safety seat works OK in there. Granted there's not a lot of room to stretch out, but I'm thinking it should just be that much better in the larger '99. As far as the crew-cab, I'd like to get this into my garage and even the extended cab is going to be tighter than I would prefer. I don't have the exact dimensions in front of me, but I'm thinking I would have to park the crew cab outside, which I'd rather avoid.
    bdon,
    As long as you have an alternative vehicle for the family, go for what pleases YOU. I don't think you will go wrong with either new Ford of Chevy. The Dodge wasn't bad either... dunbarton
  • smith6smith6 Member Posts: 11
    I'm a Ford man but I'm impressed with the Chevy wiring according to #39. Only five splices WOW!
  • bernie51bernie51 Member Posts: 10
    I just sold my 96 Dodge Ram Ext cab 1500 4x4. Drove across U.S. this summer with family and 2000 lb. (pop up) camper.All went well except with 318 eng. and 3.55 rear end it never really feels like its in the power band or has enough power. Its like the truck is just to big for the engine. At the end of the trip there was an oil leak in the manual trans. After 8 trips to the dealer they changed some of the gaskets and hopefully the leak is fixed. I advised the new owner of my experiences but he was so in love with the shape and big truck look of the Ram, I dont think he even heard me. I went looking for for more engine and hopefully for a little more reliability. The Ford S.D. looked nice but was too big to fit in the garage! The Diesel was soo cool but with big time oil/filter change expenses and complicated injector repairs after 130K or so I decided against it. The F-150 and light duty F-250 were O.K. but the auto-trans didnt shift very well on the ones I sampled. I ended up in the Chevy lot and tried the new L.S. Silverado with the auto trac 4-Wheel drive and the 5.3 automatic. This thing is very smooth and powerful. The only item I'm not sure of is the Auto-Trac set up. Does anyone have any experience with this option.Does it work? Does it last? Is it something I should include in my list of goodies? Any thoughts would be appreciated.
  • dodgeramdodgeram Member Posts: 202
    GO back to dodge, and get the 360, lots of power and sounds great. Own one my self, and not have had any leaks or loss of power on any occasion, love the truck, we use it for plowing, 4acres.
    Great Truck!
    they've had the Auto-trac system for several years in the blazers and Oldsmobile Bravada, and has proven very reliable. they're building this one on the same technology.
  • AQUATAQUAT Member Posts: 2
    I TESTED BOTH THE FORD F150 AND THE GMC SIERRA 1500. BOTH WITH THE LARGER V8 MOTORS WITH 4WD. THE GMC WAS MORE POWERFUL THAN THE FORD. THE FORD SEEMED VERY TIPPY AND DID NOT HANDLE AS WELL AS THE GMC. HAS ANY ONE ELSE HAD THIS SAME EXPIERENCE WITH THE FORD. I WOULD LIKE TO SEE THE CRASH REPORT TEST ON THE FORD IN A COUPLE OF YEARS. IF YOU OWN A FORD BE PREPARED TO HAVE THE TRUCK LAND ON IT'S SIDE.
    the torque curve on the new 5.4 triton is much improved. the 5.4 should be able to run pretty close to GMs 5.3 now, in the power department. don't know about mileage yet, but i'd guess they'd be pretty close to the same.
  • McStravMcStrav Member Posts: 3
    Has anyone sat in the front bucket seats (cloth interior) of the new 99 GMC/Chev for an extended period on time? The seats look and feel comfortable (in the show room) but I am want to know how they would be on a long trip. Any feedback would be helpful.
