Honda Pilot Care and Scheduled Maintenance
Now we owners of the Pilot need to email NHTSA the following message, or a version thereof. Email the message below to: webmaster@nhtsa.dot.gov (alternatively, use the web form on NHTSA safety hotline site at http://www.nhtsa.dot.gov/email.cfm).
Message that needs to be conveyed to NHTSA by as many Pilot owners as possible goes as follows: "The 2003 Pilot headlights are very weak and do not sufficiently illuminate the road ahead. This creates a very serious driving hazard on the freeway especially at speeds as high as 70 mph. The Pilot's headlights fail to illuminate the curves in the freeway, and consequently, Pilots can veer off the highway and get into crashes. Apparently, the Honda company is aware of this problem but has chosen not to take any action. We appeal to NHTSA to urge Honda to recall and replace the defective headlights".
Feel free to modify the message above. Thank you.
I payed MSRP for EX-L w/DVD at Wilde Honda in Waukesha, WI (Milwaukee). They will not charge over MSRP and did not push any accessories on us, however we opted for the running boards, mud flaps and cross bars to complete the exterior look. We added the cargo cover and all weather floor mats to the interior which have proven themselves useful during snowy days.
I'm currently considering the Honda Pilot LX to replace my wife's aging minivan. I got couple of maintenance related questions about it:
- It seems the 3.5L has a timing belt instead of a chain. What is the recommended replacement interval?
- Does the auto tranny has a drain plug?
- Anybody has a link to an online manufacturer's recommended maintenance schedule?
Hope this helps!
Any suggestions on whether I am better off with one vs. the other? Thanks.
Well I drive in urban Houston, TX. I think I'm suppose to be under the guides of the normal condition, but not for sure. Then I got friends that tell me that you should get oil changed every 3Months or 3K miles no matter what.
Does anyone have any comments?
THANKS
these last couple of messages are really making me think we need to combine these discussions. What do you think, host?
Any advice on what absolutely needs to be done at 30,000? Thanks.
You can also go to hondacars.com and click on the Owner's Link. Sign up there and you can view a good bit of info about your car, including maintenance. But I'll make it easy just this once
here is the list from that site for 30K under normal driving conditions:
Replace engine oil.
Rotate tires (follow pattern on page 311 in your Owner's Manual).
Replace engine oil filter.
Check parking brake adjustment.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect exhaust system.*
Inspect fuel lines and connections.*
Inspect cooling system hoses and connections.
Inspect front and rear brakes.
Inspect tie-rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
* = See information on maintenance and emissions warranty, last column, page 273 in your owner's manual.
Inspect and adjust drive belts.
Replace dust and pollen filter.
Replace air cleaner element.
Replace rear differential fluid. (Necessary for proper break-in of the VTM-4 rear differential.)
Dust Filter-My salesman suggested not waiting until 30K but rather do it at 15K and showed me an example of one he had. So I requested it and they charged ~40.00 for the part and 75.00 to put it in. I asked if I could do it, and the guy said the first time requires removing a dash crossbar that is part of the molded dash, this part is not put back, only used for molding reasons. The next time it isn't an issue and should be do-able by a non-trained person. It is behind the glove box and requires removing the glove box door.
The Vtm unit engages upon acceleration on a regular basis, so you don't need to go "offroading" to use it.
Thanks for the link.
but i do strongly suggest you follow the manufacturers suggested maintenance and change that fluid. You certainly don't want to have something go wrong and have them tell you "hey, you didn't change the fluid, so you are not covered under warranty." Better to be safe and fork over the $40, $50, or $60 now.
www.hondacars.com
Register and go to service/maintenance link. Click on FAQ's. You will find the answer to the oil usage questions (doesnt say need 5w-20. Just says you need specific ratings on the oil you purchase).
Of note is that someone (dont recall who) posted a msg saying they had never heard of a, "special oil". I too, had never heard of it. And was going to change my oil at 1000 miles. Now, I wont. Turns out that Honda DOES put some additives in the oil for that first oil change. And they tell you (as others have posted), not to change the oil for the first 7500 miles.
See the copy and paste below and go to the hondacars.com web page for complete info.
____________________________________________
Why should I wait to change the oil the first time?
Your Honda engine was delivered with an oil that is specially formulated for new engines that have not yet developed their "natural" wear patterns and may contain minute particles from the manufacturing process.
American Honda strongly recommends this special oil be left in the engine long enough for these wear patterns to develop, usually until the first maintenance interval specified in your Owner's Manual, based on your specific driving conditions.
Has anyone tried the off the shelf products? Is there a cheaper homebrewed concoction that I can keep in a spray bottle (i.e. alcohol & water)?
Any thoughts?
A similar discussion has just taken place over in the Odyssey forums. Their conclusion (solving some folks' long-cranking times), was to turn on the key without engaging the starter and leave it a few seconds (look for lights to come on on the instrument panel and wait for some to go off as a gauge) and then engage the starter. It seems that the fuel injections system primes itself (or something similar) during those few seconds and then starting should be much easier. There was also the warning not to pump the accelerator with a fuel-injected vehicle.
BTW: On my Yukon XL, I've noticed that the starter cranking is semi-automatic. IOW, I flick the key to the starter position and release, but the starter will crank as long as necessary -- even though I have released the key. I haven't tried it because I don't want to risk damage, but I also suspect it will cut off when appropriate even if I tried to hold it on the starter position...
Grand High Poobah
The Fraternal Order of Procrastinators
haven't had time to check back on responses to my posting. Belated thanks for your suggestions; I'll try getting in the habit of delaying the start after inserting the key.
Has anyone had experience with this?
I just had my 30 K honda pilot 2003 LX service done, and while driving the car back home the maintenance required light came on. Does any one have any ideas about what might be the problem. Thanks.
Just an update -
My pilot has so far been doing well with no problems other than routine maintenance. Gives an average of 18 -20 mpg.
for the service the honda dealership followed the plan in the owner's manual. tire rotation, rear differential fluid change, brake fluid and transmission fluid change was included. it cost me 304 dollars in SW missouri. cant go wrong with honda pilot.
I was driving down a hwy recently and my car seem to pass over a dead animal most likely a deer on the rt wheels. I heard a loud noise and thought one of the tires had blown. I pulled over and tires checked out OK, however i saw that the front passenger seat airbag on the side had come out after tearing the seat. this is not the huge front bag. Its a small bag about foot long. I believe its the bag for side impact. There was no side impact on the car what so ever. I had a carry bag on my seat at the time this happened.
Following questions arise.
is this something honda warranty should cover. I am within the 3yr/36000 miles.
The SRS light has stayed on since that time.
Does this mean that the other air bags might not deploy god forbid there is another collision.
Thanks for the answers in advance
Oil is required to be changed every 7.5K but oil filter is only required every 15K.
VTM fluid is changed at 15K, then 30K then every 30K there after. I am not sure why there is 2 cahnges in the first 30K of miles.
Trans Fluid is changed at 45K,75K,105K,120K,135K I am not sure why the 1st change is after 45K then every 30K until 105K. Then they sugest on changing every 15K to 135K, but don't list this fluid changing at the 150K service.
Also there are three small buttons on the same console as the two interior lights by the rearview mirror. Do these serve any function? I appreciate any help.
Confused in Pittsburgh!
when there's something detected too close to the
(passenger) window, such that the side airbag
is disabled (safety reasons).
As the dog occasionally sits in the front seat
(I know, my bad) - I would like to know how to
totally disable the passenger airbag - my pickup
truck has a switch for this purpose.
If your overhead console is the same as ours those
buttons are for 'homelink' a garage door opener remote.
A web search will likely find you programming directions.
There's a Honda Pilot (ORG) web site which has
a scan of the pilot owner's manual - I think it's
2004.
--SRL
