Keep it or dump
                    I BOUGHT A NEW NISSAN ALTMA IN 1996. IT CURRENTLY HAS 45,000 MILES ON IT. A SIDE FROM THE NORMAL REPLACEMENT ITEMS, (TIRES, MUFFLER, BATTERY) I HAVE HAD TO REPLACE THE CONVERTER BECAUSE THE SENSOR RUSTED OUT ($300.00), THE VALVE BODY IN THE AUTOMATIC TRANSMITION NEEDED REPAIRED ($800.00), AND NOW THE COMPUTER WENT OUT. THE MECHANIC REPLACED IT WITH AN USED ONE FROM THE JUNK YARD. $400.00) THIS CAR IS STARTING TO BET A BAD TASTE IN MY MOUTH. HAS ANYONE ELSE EXPERIENCED SIMILAR PROBLEMS? SHOULD I EXPECT ADDITIONAL PROBLEMS? SHOULD I GET RID OF IT?
MY LEMON
MY LEMON
I myself don't believe in "lemons", since it is impossible for an entire car to be bad. Yes, some cars are not well engineered and some have problems, but the idea that a car is a "time bomb" waiting to go off because of some "lemon-ness" built into it 6 years ago just doesn't wash with me.
I'd say you just add up the cost of these repairs over the last year or two and see if the monthly average is anywhere near the cost of monthly new car payments. If not, you are still ahead, and if so, maybe it is time to buy a new car.
if not, there isn't much left of a major nature that beating the car up would have messed up, so it should be in pretty good shape.
used cars are always a gamble on present condition. yours ought to be in reasonably good shape now, barring any little whangs and oopsies that come with age and wear.
The biggest issue with calling a car a "lemon" is that it meets a legal statue. Most consumers completely misunderstand this designation and cry about their "lemons" after the dash rattles for the third time. It has to be "a significant impairment of use, safety or value".
My only point was really a linguistic one. An entire car cannot be a "lemon" since in most cases it is only a small percentage of the car's componentry that is malfunctioning.
It's not unlike saying that because a window is jammed in your house, or the hot water heater leaks, that your house is a lemon and you think it's going to fall down now.
You do have an advantage of approximately 1 thousand because of the low mileage.
On the average vehicles should cost about $1200 per year for maintenance and repairs. Looks like recent repairs have been bad, how about other years?
The psychological factor can be significant in deciding to purchase a newer model.
Your resale value will only go down.
I would take it to a Nissan specialist mechanic and have them go over it carefully. Then you will know for sure whether there are a lot of anticipated repairs. It won't be perfect, but it can give you a good idea of future repairs.
But then again your screen name may say everything about this decision. Cover what's needed until conditions improve.
