Transmission service
I recently purchased a 95 TC with 73k miles. The previous owner kept pretty good records and they indicate that the vehicle was serviced regularly except for the 60k transmission service. My local dealer is running a $99 'special' to flush and replace the fluid but wants $160 to do that and replace the filter. As I am not having any problems would the $99 sevice be adequate or would I be wise to go ahead and replace the filter also?
The transmission engineer who frequents the LS board is a strong advocate of the flush method, however. So, with my LS, I had the flush performed at around 35,000 miles and left the pan and filter intact. At around 70k, I will have the full service done, pull the pan, change the filter, and flush. That is the process recommended by my dealer.
If I were you, I would go for the full service - flush and filter.
Thanks for the responses.
What is $200 per year in flush/fliter change. I am constantly trying to think of things: external filter, external additional cooler, synthetic ATF, LubeGuard additive, etc....to spend more than the $200! Every year's maintenance defers the big hit!
if you tow, you need a larger than stock transmission oil cooler by the radiator. no arguments accepted, it is God's rigid law. if you didn't get one by virtue of having the van built with the "towing package," you need to add it after the fact. you should also consider a supplemental oil cooler as well.
Ford and GM towing packages include this, plus the control relays for extra load on the signal lights which spares the brake and turn signal switch life... larger battery/alternator... heavier suspension... larger radiator capacity... generally also heavier brake systems... and they were engineered together to reduce the load on engine and running/stopping gear to about what it would be on the same car in normal service per square inch of metal/amount of friction/expected service life.
if you want to use synthetic because you want to, have fun and spend hearty. if you don't want to melt the van down under load, beef it up now.
Swschard I appreciate your response ,
I don't tow everyday but when I do it's right up to the Max allowable by specs , when I waqs looking for a vehicle I ended up buying a Ford Conversion Van it's a 2000 E250 , the 250 has the 16 inch tires discs all the way around , it has a factory transmission cooler , I,m not sure but was told at time of purchase that all E250,s have a towing package , so I accepted that , although I had to put a hitch on myself , I figured it must have heavier duty parts as you indicated becayse why would Ford put a transmission cooler on if it did,nt have a towing package (bigger radiator , heavier alternator and relays ) as you have suggested ... Any comments on this ... thanks , Larry
all automatic trannies have a radiator-located cooling assembly for the transmission fluid. the difference is in the size, as determined from the assembly code number, and sometimes location. in my case, if I had a standard A4 transmission and standard radiator, I sort of remember from looking under vehicles in the back lot that they had the standard assembly technique, the ATF cooler built within the frame of the radiator. the HD towing rig had to mount the ATF cooler behind a larger unit radiator with only the radiator connections in the assembly. the engine oil supplemental cooler, a much smaller dingus the size of a paperback book, was located under the radiator assembly.
you can always add a supplemental cooler with hoses ahead of the radiator if you have to, but it's not as protected and integrated and wasn't tested as a unit to insure no warranty hassles if warranty is needed.
there should have been a pass-through paper from Ford, the chassis maker, showing the equipment on the conversion vehicle as supplied to your converter. if that says trailer towing, cool. that van should have enough weight and frame to control the load, as long as you don't try squealing around corners on two wheels or something... but without the full buildout, which to me always includes the lower-ratio axle for more torque (screw the mileage, gain the dead-start torque and better engine braking with the OD turned off) and towing enhancements, it won't last.
and I typically run my vehicles until I have gotten my money back out of them
BTW, do please plan on always clicking OFF overdrive when hooking up that tow, you will beat up the clutches and have dangerously less control of the vehicle if you try and pull with OD on. one of the secrets of not having troubles is to always shake your head and say, "screw the mileage" with a tow on and a choice of options in how to drive. that's right up there with the law of gravity and Murphy's Law as un-arguable facts of life
Looked at Summit's inline filter , it seems to be fairly priced , 20 some bucks .... I am wondering if all instructions are included on installation , i have a ford Conversion , with the 4R70 transmission , where abouts might I hook this up , I have transmission fluid going to radiator then to transmission cooler back to transmission , do I have to splice in to transmission line , or go right to fitting coming in or going out of transmission ? DO you think by pushing the fluid through this filter , it might tax the pump on the transmission ? I looked bulk parts
inline filters hookups and they come with a magnetic filter ..... I wrote them and they responded saying that it could clog up filter and don't reccomend , I can't figure why they are saying that about their own product .. Anyways I would welcome a reply , on any of the points I,ve written... thanks Larry
I was wondering about that Ford inline filter , I was not aware that Ford had an inline filter availiable ...You say a plastic ribbed one they sell , hmmm , The one Summit sells is one that is replaced with a Fram 8A filter , Where did you bolt the housing for the filter , looks like it has a flat back and is bolted somewhere ...
Also what do you do ? Cut the line and put rubber hose with clamps on ... Does not look like anyplace where this might be mounted >> the housing .... I am wondering if by adding this filter if it will strain the transmission pump that pumps the oil thru the radiator and cooler back to transmission ..... any thoughts of any of this .... Thanks , Larry
I have a 2000 E250 Ford Conversion with 7000 miles on it , I tow at times pretty heavy and have been reading that this 4R70 transmission is really not heavy duty ... I have a factory cooler on it , just put a transmission temperture gauge , while towing I run between 150 and 195 degrees ... As winter is getting closer up here in NY I am looking for a project to undertake and I thought the filter would be a good one , also just bought a larger transmission oil pan by 3 Quarts made of aluminum with some cooling fins I will be putting on also ... I take this vehicle off the road in winter so have plenty of time to work on it ... I am wondering ? If I install an inline filter it would have to me mounted somewhat horizontal to the existing transmission line , as anything not horizontally inline would probobly tax this transmission pump even more ...
looking at the ones offered by Summit , for about $30 seems like a winner .. any thoughts ..... Larry
http://home.cfl.rr.com/ksc/aamcosucks.html
Go to the dealer, if you don't have a local shop you trust.
