Volvo Problems--Questions/Answers Here!
schoemerschoemer Member Posts: 1
edited March 2014 in Volvo
Help! Does anyone else have the coolant warning "stop engine" sign coming on frequently (at least 1x month for the last 6 mo. perhaps) The dealer keeps topping it off (sign comes on when it reaches the minimum level). The engine never shows hot, I never see evidence of a leak in my garage, yet the coolant disappears. The dealer checked and found no leaks. Dealer is not aware of this problem with anyone else, or so they claim. It is getting a bit annoying to say the least! Can't find any problems of this sort on this site except way back in 2000. My car has 55K but this has been happening since before the 50K warranty. Absolutely love the car otherwise!
  • mullins87mullins87 Member Posts: 959
    Did the dealer pressurize the cooling system and watch the pressure over a period of an hour or so?
    Tell the dealer or an independent shop to stop being lazy and diagnose the problem. Mullins is absolutely right, you need to pressure test the system and perhaps use a detecting dye to find the leak.
    You either have a hidden leak or a head gasket issue going on. Those are the only possibilities.
  • chetdudechetdude Member Posts: 5
    I bought a 2000 S80 2.9 and it has been nothing but problems. The transmission dropped at 50k, the onboard digital fuel economy gauge never worked (despite repeated trips to the dealer) and worse off, after three years, the driver's leather seat looks like it has 300k miles in wear. Did we get a lemon, or has anyone else experienced similar problems? This is our fourth and last Volvo. It's enough to make me long for the old 240.
  • jrosasmcjrosasmc Member Posts: 1,711
    Hmm, sounds like a lemon.
    Well, not so fast here. I heard "3 problems in 50K miles".
    Now the trans is inexcusable, okay, one big demerit
    The gas gauge, well, just about any car made can fart one time electronically.
    The leather seats might have been a lack of instruction on Volvo's part to owner's on how to properly take care of leather. Lots of people really don't know and damage the interiors unknowingly. If the leather is allowed to dry, it will scrape and crack like nobody's business.
    Of course, leathers come in different grades, and I don't think Volvo uses top, top grade--but it should be a decent grade of hide. If it comes from Scandanavia, their hides look great and dress great because they don't use barbed wire but sometimes they aren't so durable. I owned three Saabs and all the leathers went to hell, but that was older stuff than yours, too.
    Maybe Saab and Volvo didn't use the finest leather back in the day.
  • s80nightmares80nightmare Member Posts: 3
    Since I have so much experience with the S80 problems, I feel that I can tell you this. GET OUT NOW! Seriously though, I just had my radiator replaced at <40,000 miles. I also rec'd low radiator fluid warnings. Three weeks after they replaced it though, I overheated and rec'd a "STOP CAR" message about a half mile from home. I barely chugged home and refilled the coolant. I brought it back in (1 1/2 hours round trip) and they said that there was an air gap in the hose that caused the most recent problem. I have zero faith in this car, so we'll see where I break down next???
  • lancerfixerlancerfixer Member Posts: 1,284
    The leather in my 740 looks great after 14 years, and I don't have a garage. I imagine the previous owner did. I regularly use Zymol cleaner and protectant (two separate products) on the seats, though.
  • balooobalooo Member Posts: 24
    I 'd like to have my oil changed by a less expensive service provider then the dealer.
    Does anyone know the "trick" to turning off the the service message?
    Assuming I can take my S80 in for major service intervals makes more sense to me.
    I have 15,100 miles on my S80 and took it in for the 7,500.
    I don't see the point in spending nearly one hundred bucks for what is basically an oil change.
  • kmcbridekmcbride Member Posts: 2
    I need to replace the windshield wipers on my '99 S80. Went to the auto store, the in-store computer matched me up with (supposedly) the correct wipers - but they are not as wide as the (original) ones on the car. Also, I note that the two wipers are of different sizes ...
    Does anyone know what wipers work as replacements ??? Thanks.
    Get your wipers at the dealer. They cost a bit more but they fit and are of decent quality. This is one of those items where the dealer is your best shot. The big chain stores make lots of mistakes, and even if they don't, sometimes their products are substandard quality. Last thing you want is a nice big scrape mark on your windshield, which is NOT cheap to fix on your car.
  • tessa4010tessa4010 Member Posts: 1
    Hi. Can anybody offer me some advice? I am thinking of purchasing 1991 740 station wagon. It looks in good shape. Has 144k miles on it. I am concerned after reading so many bad things about Volvo. I thought they were reliable cars.
    I dont have alot of money to invest in maintenance or upgrades. Any advice on this or a better station wagon? thanks much!
    "I dont have alot of money to invest in maintenance..."
    Stop. Move on. Buy a Geo Prizm. Don't get me wrong, I love my 740, but maintenence is not cheap.
    Re: wipers. I'm not sure if the S80 is the same way, but the three Honda/Acuras I've owned have all used a larger driver's side wiper. I downsize by one inch on each side in the winter when I put snow blades on my Accord.
  • tupperpatrtupperpatr Member Posts: 1
    I have a 2000 S80 with 60,000 miles that is in the shop at the moment with transmission problems. Isn't this unusal to have transmission problems at 60,000 miles. What should I be alert for with dealing with the dealership?
    Thanks for the help.
  • volvocrazyvolvocrazy Member Posts: 2
    Just hit 50K on my 2000 Volvo S80 (2.9) I received a message that read "performance reduced". My car is idling rough. Has anyone received this message and know what the problem is?
  • tmarttmart Member Posts: 2,437
    Where did this message appear?
    This message appeared on the dashboard message display next to the speedometer. It has now disappeared- I wonder what has happened?
  • 80708070 Member Posts: 1
    I own a 1991 volvo 240. I love the car but Ive noticed 2 somewhat annoying things with the car.One thing is the servicelight comes ON every 5k miles like its supposed to, then shuts off after 2 minutes which is normal.However,is there any way I can shut this off myself without taking it to the dealer for service? My other problem is that every time my headlights are ON with the rear defrost ON, and then I depress the brake pedal I notice my lightbulb indicator light on the dash comes on, but only when I step on the brakes. When the rear defroster shuts OFF the indicator light doesnt come ON when stepping on the brakes.I know this sounds confusing.As far as I know I do not have any bulbs out or am missing any on the car. Any ideas anyone,because Im stumped? THANKS
    1987-93 240 Models
    To reset counter, locate reset lever behind left centre of instrument cluster and push reset lever upward.
  • dabaerdabaer Member Posts: 7
    regarding the reset of the service light, just ask your service manager. he should tell you. he showed me once, it is a combination of the trip odometer and the radio power switch or something like that. My independent where I get my oil changed has it down and yours shuld too. surely the volvo service manager should tell you.
    I have a 143,000 miles on my 1999 S80 and the whole dealership from parts to mechanics to the cashier know me very well, I am there so much. I can not imagine buying another volvo. it is a grea ride and handler but the maitence and repairs! I was hoping to hear some one positive on the newer models but doesn't sound good.
    I wonder what a cadillac's track record is like?
    Procedures vary relative to model and year. The light reset information I posted is correct for 1987-93 240 models.
  • 2000s802000s80 Member Posts: 2
    I am nearing the end of the 3 year lease on my 2000 S80. To date, it has been a very reliable car and I am think about buying it at lease termination. My only concerns is that it goes through light bulbs (specifically front headlights). In two and half years, I must have gone through 6 or 8 bulbs. Yeah, I've heard the DRL line ... however, never had that occur in my other DRL equipped cars.
    Question: should I be concerned with the electrical system of the car and NOT purchase an otherwise reliable car? Or do the light bulbs have that low of a lifespan. I have about 30,000 miles on the car.
  • kirwandkirwand Member Posts: 4
    I just took my 99 S80T in for a tapping noise in the engine which I assumed was maybe valves. The dealer said it was the seals in the pick-up tubes that were bad and restricting the flow of oil to the engine. So, they were replaced and when I went to pick-up the car, the same tapping noice was there. Service tech took the car back to the mechanic and 15 minutes later came back with my car and said it was the injectors making the noise. So, 1) can injectors make a tapping noise, if so should I do anything about it and 2) did they fix something that maybe did not need to get fixed?
  • davefromnydavefromny Member Posts: 6
    The Brake light in my 2000 V40 comes on when the car gets cold, then goes off after it warms up such as spending the night in the garage. Next cold morning, it comes back on after driving a few miles. Warms up during the day, light goes back off. Fluid reservoir is full, brakes work fine. Any ideas?
    Red brake warning light or amber ABS light?
    It's the red Brake light. The ABS seems to work normally on slippery roads.
    David, 3 things provide a ground for the red brake warning light; ignition switch in bulb check position (between Run and Start where all warning lights come on), low fluid level float switch in the master cylinder reservoir, and the parking brake switch. Any chance the parking brake needs adjustment?
    Many thanks for the quick reply. I don't think it's the parking brake, because I have a different light for that which says Parking Brake, and it comes on when I pull the lever up. I was inclined to believe it was a bad sensor of some sort. Based on your input, maybe something on the float is out of adjustment, or thermal contraction fools it into thinking the level is low. I'll look to see if I can find anything. At least that gieves me some knowledge if I have to take it to the dealer. Thanks again.
    Sorry about the parking brake misinfo. Was using generic circuitry. Let us know what the outcome is.
  • madmaynardmadmaynard Member Posts: 4
    Have a 97 850 with 99,000 miles...runs like a top...at 85,000 miles the ck engine light went on and had to have the air pump/relay replaced. Now 14,000 miles later it needs it again? What gives? This is a $500 repair to pass inspection!
    I'm really peeved? Any suggestions?
    I had posted a concern #27 and haven't heard back yet. Can fuel injectors make a loud tapping noise and is there anything I can do to stop or lesson the noise? Thanks.
  • jeffryjeffry Member Posts: 36
    I have a '94 850 Turbo w/ 85K mi. Tho I bought it new & its been pretty reliable, lately I've been annoyed w/ the harsh, jarring ride. I'm not sure if its really any different from when new or I'm just wanting something new!
        Question: 1) At what mileage do shocks (or are they struts?) usually need replacing--not particularly rough roads or use.
         2) Are there replacements that would give a smoother ride--than when it was new?? It's obviously a 'performance' car of its day & never was smooth but maybe there are reasonably priced upgrades that would make it more enjoyable to drive until I sell it in a year or two.
               Any suggestions or experience appreciated. jeff
  • rollierollie Member Posts: 337
    jeffry, I highly recommend you post this message in the appropriate forum at www.brickboard.com, www.swedespeed.com, or www.vvspy.com you'll get more answers than you can handle (or you can search the archives as this topic has been covered many times before.)
    As a shortcut, you'll find mention of www.ipdusa.com in many of the posts on this topic.
    -rollie
  • shebad44shebad44 Member Posts: 1
    I own a 1990 Volvo 740 Turbo. I've had it for almost 3 years. Just this winter (its been very cold) the car is starting to act up. When I start it in the am, I let it warm up for a while and it drives good, but when I leave work, after warming for the same amount of time, it kicks and coughs, feels like its loosing power but it doesn't, and jerks. I seem to hear a small whistling sound-like a tea kettle. Then I noticed after parking some antifreeze drips out. I took it to the mechanic and he said I needed a heater core, heater coil,and a motor blower. The price quoted for this repair was around $800. Is it worth fixing?? Will I find this type of repair less expensive but of good quality??? Is this car on its way out because of its age??? I really like this car, its everything I've wanted in a car. The mechanic did a by-pass (by passed the hoses pass the heater core. I haven't been driving it, just heating it up. I would like to get it fixed, but it it worth it. Help, need some advise.
    From posts 28 - 30. The mysterious Brake light problem was resolved by adding a little brake fluid. The level had been well above the min line on the reservoir, but perhaps my float is set high. Raised the level to about 1/8 inch above the max line, and no more Brake light in cold weather. This doesn't explain what changed to make the problem start, however, so need to keep an eye on it. Thanks for the suggesion from alcan, it put me on the right track. It's good to have someone to talk to.
    davefromny, here's a SWAG at a theory: the cold temperatures cause the volume of the brake fluid to decrease which leads to a larger portion of the fluid remaining in the brake lines which lowers the amount in the reservoir? Just a guess...
    -rollie
    Might be time to have the brake pads checked. As they wear, the caliper pistons move out in their bores and additional fluid volume is required in the calipers, lowering the reservoir level. Rollie's right about the fluid contracting when cold, and the fluid level was just at the cusp of triggering the float switch.
    Yes, indeed, your Volvo injectors can make a racket. A sharp "click" just means that the injectors are doing what they are supposed to, but if the injector is loud and gives off a heavier sound it may mean you are ready for a solvent cleaning of the injectors.
    Some injector systems apparently are more susceptible to this gumming up and noise because of how the injector is placed in relation to the exhaust manifold. Heat is the big issue here.
    Your car seems to be prone to noisy injectors from the little i've read on the web searches.
  • bokenboken Member Posts: 3
    1999 S80 T6 with 65,000 miles on it. I have had a recurrign problem where I intermittently lose my dashboard instrumentation and all steering column functions( blinkers, washer fluid etc.) It has been fixed 3 times by the dealer saying it's a problem with the wiring through the climate control system. Bottom line it has cost my well over $2,000 and stil not fixed. What kind of recourse do I have with the dealer or Volvo?
  • homebrewahomebrewa Member Posts: 1
    Folks,
    I *may* get a solid chance to land the above model, with 54K miles for a $15K price tag. I understand this car books at around low-20s retail (per NADA) but I don't have to wonder who I could possibly get it from because it's a brother of a good friend. Anyway, if I do get a chance to get it, my enthusiasm has been tempered by the trans. and electrical problems I've seen on this board. I have a '98 Civic now and while it ain't sexy, it's basically been a gas-n-oil car with a brake and muffler job tossed in. What would I be in for with a Volvo maintenance-wise? Sounds like a lot of headaches and $$$
    Thanks!!
