Engine knocks
I have a 96 2WD Suburban with 72K miles on it. It has been well maintained and driven very carefully. Even though Chevy claims that it does not need a tune-up before 100K miles, I brought it in for a tune-up because it was feeling sluggish. My mechanic told me that the engine "knocks" and he thinks that the engine is damaged and needs an overhaul! This mechanic is a trusted friend and wouldn't suggest anything just for the money. Does anyone have any suggestions?
Ray T.
99-06-01-003 APR 99 Engine Bearing Knock Noise
I know the piston slap site addresses present day Chevy Knockers but it also touched on some of the older engines too. Either way GM's response was "it's normal".
Ray T.
if the dealer and zone are just avoiding saying, "this car was beat to hell and we sure ain't paying for that < ozzy > and his problems," then it's understandable.
you buy used, you can't tell which is which. I suspect we all know which is which on this forum, but no evidence, no conviction........
-Andrew L
I actually tried that this summer; my dad and I got a timing light and attempted to check the timing. However, we looked all over the place and we couldn't find the marks with which to check it. I know we were looking in approximately the right places, as we adjusted the timing on my brother's '77 Celica the same day, and we were able to find the marks on that car. My Chilton manual depicts a small hash-marked strip like a ruler as being in there somewhere, but I couldn't find anything that looked like that. If anyone knows where to find the timing marks on this engine, please enlighten me.
-Andrew L
There is a timing tab. Look for the small tube just above the balancer, the timing tab is to the left of it. May need to clean it to see it.
Looks like this.
timing procedure
Set timing at slow idle and Before Top Dead Center, unless otherwise specified.
Disconnect and plug distributor vacuum hose at distributor.
1981 4.3L (265), 4.9L (301), ground distributor bypass pigtail (blue connector).
1982-88 1.8L (112) FI, 2.0L (122) OHC, 2.5L (151) FI, 3.8L (229), ground diagnostic test terminal under dash.
1983-86 2.0L (122) FI, 2.8L (173) FI, 5.0L (305) CFI, disconnect bypass connector (tan/black wire).
1987-89 All FI W/distributors, disconnect timing bypass connector, single lead in every harness between distributor and ECM.
1981-89 Others, carburetted, disconnect 4-wire connector at distributor.
Timing MUST be set to specifications on emission label if different from setting listed. If "Check Engine" light comes on during procedure, remove ECM fuse to clear.
Thanks for the info. I'll have to take another look at it. I'm at college right now so I don't have access to the equipment, but I'll try setting the timing again next time I go home.
-Andrew L
But if anyone else knows, great. I just don't have the books on this car and I don't recall how timing is controlled.
I have the generic Chilton manual for 77-90 Buick Oldsmobile Pontiac full-size, which is not a terribly good book (I really should get an official shop manual). But anyway, the directions in there state the following:
"Using a timing light or meter, set the timing at the specified RPM by loosening the distributor hold-down clamp and rotating the distributor until the specified timing is obtained at the timing marks on the crankshaft pulley."
I'm not exactly sure how to do that, but I'll figure that out once I've figured out how to check the timing in the first place :-)
-Andrew L
WATCH OUT FOR BELTS AND MOVING PARTS !!!!
you can turn the distributor shaft, housing, and cap assembly while the engine is running. I would advise tightening up the back bolt to just a titch loose when starting, then crank it back until you can just turn the distributor system, while shooting the timing light at the mark. with the appropriate wires yanked and vacuum lines plugged, set the distributor at measured idle = book value (adjust the carb idle screw first if need be) with no accessories on and the a/c disabled. then tighten up the back bolt again and see if things shifted... if so, loosen slightly and reset, then don't wiggle the distributor this time when tightening the back screw. if it stays in place, torque both of them. if it stays in place, congratulations, and shut down to hook the rest of the geegaws up.
I am glad that I haven't had to adjust one with the distributor right up front, where access to the front of the two bolts that hold down that clamp is prevented by the bouncing fan belt over it. that means on such engines, you don't want to be putting your fingers anyplace near the front half of the distributor. might be a nice idea to chalk up the belt before starting the car to make a white danger line.
oh, yes, that third arm God gave you should come out for this one to hold the timing light :-D
I hate to suggest guessing of course, and you should be able to check advance by revving the engine with the timing light applied; however, I don't know the specs of how much advance you should see. What you would look for, of course, is TOO MUCH advance curve.
More modern cars can't really vary their timing except from internal wear, which is also a possibility on your car with a sloppy timing chain.
Thanks for all the info. I plan to do the timing check/adjustment when I'm home for a week in October, so I'll let you know how it goes.
-Andrew L
turned out the distributor advance motor, vacuum pulloff operation, was shot. couldn't verify it by taking the hose off, pushing the operator in, and covering the hose connection and seeing if it stayed in. finally made a magic-marker band at engine-off position, and diagnosed it by discovering nothing I could do with vacuum made any change. bought a new one on payday, somehow avoided dropping the two short-barrel screws on the distributor baseplate into the works during replacement, and fixed 'er right up.
if I had dropped one or both of the screws that held that vacuum pulloff into the distributor, it would have been Very Bad News, and I would have had to pull the distributor and shake 'em out, or tear it down to get to them. be so advised that you don't want to screw that up.
so if you're statically-timed and it didn't matter, check the pulloff if so equipped. if not so equipped, it's probably dependent on the engine computer operationally delaying the spark impulse, and that could be caused by failure of several different sensors... but there should be a $$$ light lit, and codes to be pulled, on newfangled modern engines.
but for your late 70s GM, I betcha that distributor pulloff is wayoff.
