TOYOTA TACOMA vs. FOR RANGER
Well I didn't see the liar thing, but I can understand why you maybe upset. Just don't let it draw you away from a good debate into a personal vendetta. Honestly I am so sick of this clearance issue.
1. In the photo layouts there is no antenna
2 Both show a picture going up a hill or mountain.
3. The Ranger has a steering wheel column shifter, while the Tacoma has a floor shifter.
4. The Ranger has 7.4" of axle clearance, while the Tacoma has from 10.8" to 12" clearance depending on tires.
5. The Ranger does have 5 lugs compared to Tacoma's 6 lug wheels.
6. Ranger XLT the limited slip differential is an option with the V6.
The ride is smooth & quiet on an ashpalt wearing surface. The ride is smooth on a concrete rigid pavement provided the wearing surface is in good conditon. I have notice that on the concrete surfaces with exposed aggregates there is a slight droning sound from the tires that is noticable. Also, at the expansion joints of the concrete rigid pavement if the joints are fairly close and there is no differential settlement between the two the transition ride over is fairly quite. On those that are wide there is a slight thump sound. Most of the city roads are asphalt concrete and unfortunately the surfaces of the streets are in poor condition here in NY, which causes a bouncy and jiggly ride.
Thanks for the input.
I think you can reorder the TRD logos's from TRD when you go to sell it...
spkirk
I have a 1998 Tacoma XCab V6 SR5 Auto with the 31's. It's holding up great. No problems at all, except it's black and keeping it clean can be tough.
I have had it one winter (New England) and it did great, though a couple of bags of RockSalt in the Bed helped out (weight). I've taken it off a road a bunch of times and i have yet to get stuck. Sometimes i don't even have to lock the hubs.
A guy i work with loved it so much he went out and bought the same exact truck from the same salesperson, from the same dealer, a month later. He got his in red, and loves it, and has had no problems either.....
I also added a tilt and slide sunroof (Webasto) and it makes the cab feel even bigger.....
14K and no problems.....
-wsn
PS Anybody got the K+N filter for there Tacoma. My air cleaner is coming up on replacement time. I'm not looking to gain ponnies or anything, i just thought it would be a better filter, and less $$ in the long run. Good Idea????
-wsn
Good luck!
Chris
I don't know about the K&N filter, but at $21 for a Fram air filter it is not all that bad.
Matty,
When you take a closer look the Tacoma does have a few things that are standard and not found in the Rangers.
http://community.webtv.net/dp2000/TRUCKFORCEACTION
In my personal opinon, trucks are suposed to be work horses, not luxury items. That is why I will refuse to pay over 16 grand for a small pickup. Under this priciple, I don't see how any one could justify buying the Toyota bare to the bones, when the Ranger has a lot of options on it for the same price. I know that they are both great trucks, but for the price, Ranger for me.
www.auto.com/autowire/qroll15.htm
The national Highway and safety transportation
site listed it and the geo tracker as the most unstable vehicles made in turning.
Heres another sweet quote:
"Three vehicles -- a 1998 Ford Explorer, the Ranger pickup and a 1998 Chevrolet Lumina -- had tires that broke their seals and deflated in maneuvering the test corners, dropping the wheel rims onto the pavement. An agency document said when the tire was ripped from part of the rim, the vehicle was difficult to control and was more likely to slide sideways, also "increasing the risk of rollover"
Nice quality there.
This article was on the front page of the Chicago Sun times, with a large picture of the Ranger on the front page. Here one of many URL's:
http://www.auto.com/autowire/qroll15.htm
Even though the tacoma has a higher ground clearance, it isnt engineered by cost-cutting
"save-bucks" which slap everything together.
Its all in the quality of engineering , the suspension, the stablzer, and the sterring.
99 Tacoma bulletins = 0
Hey Cspounser, what was that you were saying about apples?
Ranger/B4000 was rated best truck by Canada 3 years in a row. I'm not sure, but I think it's becasue Ranger is a better value, and a Tacoma handles really nadly on Canadian roads and weather. That is why I didn't like the Tacoma when I test drove it?
please do not post anything larger than the "window". Oversize posts foul up our screen sizing, and have to be "hidden" for things to return to normal.
Front Porch Philosopher
SUV, Pickup, & Aftermarket and Accessories Host
Toyota Tacoma 4X4 with 31x10.5X 15 tires=
9 inches
Lowest rear point, directly under differential, 3 vehicles measured. Maybe a fraction over.
Clearance under differential, vehicle lowest point is+
9 inches
Well looks like the there is equality in some areas. Go measure if you do not belive me.
"Federal test researchers cautioned against comparing the vehicle test results to draw conclusions about any individual vehicle because so few vehicles have been tested, and officials still were deciding on the best test".
This round appears to be just American nameplates. The Tacoma's day will will come, and we will see how it does.
the 4:10 rear end and it came out at 12 inches with the 31's.
By the way, did you get the chance to read the 98-99 Ford Ranger Technical bulletins? THESE are what consumer reports goes on. Interesting that the 98-99 Ranger had 61 technical repair bulletins, and the 98-99 tacoma had 7.
Oh well.........
Also, measured a Tacoma with 235X75X15 BF Goodrich tires like my new ones and it measured in at 8.25 inches and the guy that helped me was a co-worker that wants to buy a Tacoma. He said, "But the booklet says it should be 12 inches clearance.
You see, your limited by the radius of the wheel which on a 15 inch wheel is 7.5 inches. Then the distance of the tire rubber from ground to rim on my BF Goodrich tires is 6.5 inches. So that equals 14 inches. But if your differential ring gear is 8 inches, which is what a Toyota has then you have to take 4 inches off the max clearance which leaves you 10 inches. Now consider that there is some metal in the differential housing, say 1/2 inch thick, take that amount away and you get 9.5 inches ground clearance, just like I said.
In order for you to have 12 inches ground clearance, given that the 31X10.5x15 tires have 6.5 inches ground to rim, and the rim 7.5 inches, do you realize that the ring gear on that vehicle would have to be 4 inches in diameter?!? And Toyota uses the STANDARD 8 inch ring gear.
Sorry man your numbers just dont add up and the Tacoma I measured was brand new.
I did specify to the direct bottom of the differential. I was not counting the lip around the drain plug that comes out the drivers side of the differential.
It was 9.5 inches on the brand new TRD. A little over 11 to the bottom of the axcel but 9.5 to the differential.
Thank you very much as that is what I derived from the article. I will read it again but do not recall seeing the Tacoma even mentioned.
Quite a few years ago Consumer Reports got on the Susuki Samuri as in their tests of the vehicle it had a tendancy to roll over. There was a big picture on the front of an issue of a Samuri with outriggers so it did not roll in their tests.
As Consumer Reports reviewed the Ranger in December, and made no mention of ANY tendancy to roll, I question the article cited. Such a tendancy would have apperared in their tests as it did with the Susuki. But I have an open mind enough to look further into the issue.
I have never had any feeling my Ranger would go up on two wheels. And in regard to a tire coming off, the ONLY time I have EVER had that happen is when something was hit, like a curb, a large rock. Rims are built to hold tires on, they just dont fall off when you turn. Sure sounds like a fishy article to me.
In regards to the 4x4 compact pickup trucks all can be made to rollover.
Sushi,
I thought you said you had a Mazda in one of your earlier post. Just wondering in post #512 you said you have a Ford now? Still seriously considering that Frontier?
"The mission of the NHTSA is to reduce deaths, injuries & economic losses resulting from motor vehicle crashes by setting & enforcing safety standards for motor vehicles. Grants are awarded to states to help them organize, develop & implement highway safety programs. "
I had a 91 22re yota pickup with 225's and the rear diff clearance was 9.5.
Werent you the one boasting about the Rangers quality?
98-99 Ranger =61 technical repair bulletins
98-99 Tacoma= 7 technical repair bulletins
what were you saying about apples?
spkirk:
Well going to try out the new tires this weekend so will update pictures on my website:
http://members.aol.com/Cpousnr/index1.html
Guess I will have to save a couple pics from my Stanley tape sitting under a Tacoma and Rangers differential. Let me try to explain that one more brief time.
My new 31s measure 14.25 inches from the ground to the middle of the cover of the lugnuts. I would expect a Tacomas 31s mounted on 15 inch rims to be close to the same measurement.
Last time I knew, axcels were straight, not bowed up.
On the Ranger if you divide the 8.8 inch differential by 2 you get 4.4 inches. 14.25-4.4 is equal to 9.85 inches. Subtract some value to take into consideration the distance from the 8.8 differential ring gear to the outside of the differential housing and you get in the neighborhood of 9 inches which is what I measured on the Ranger.
Now since the Tacoma has an 8 inch ring gear, do the simple math. 9.5 inches clearance is reasonable and what I measured on the Tacoma TRD.
In order for the clearance to be 12 inches, a ring gear in the neighborhood of 4 inches is required.
Heck with it, I will post the pictures next week.
Retraceted maybe?!?
Im talking about the NHSTA TECHNICAL RECALL REPAIR BULLETIN.
You know, the one where the 98-99
Ranger has 61, and the 98-99 Tacoma has 7?
WHat do you have to say about that?
I hear it has a sweet interior and stock stereo
though.
I think Car and Driver has a detailed review of it in this months edition.
There is plenty of info on the Frontier. You just have to search the web for it or go to one of those 4WD magazines. It your interested try
http://www.metagrid.com
or
http://www.trucktrend.com
Just keep plugging at it. All though I may not agree with all you say I wouldn't want this topic to be one sided. Always good to see differing views even though you may not agree.
Sushi,
One more site to check
http://www.pickuptruck.com
It gets me off the red light with gusto and no one can keep up. Although, I would like to be able to have a chance to take it off-roading, anyone know of a good place in northern California?
1. What advantage is a cluth cancel swithch?
2. What do you mean by the highest engine placement? Wouldent than make you prone to a roll over?!?
Ok, here are some of the summary posts you had and my answer:
Summary: SOME VEHICLES MAY EXPERIENCE VARIOUS
CONCERNS SUCH AS INTERMITTENT WIPER OPERATION
WITHOUT COMMAND, DOME LIGHTS REMAINING ON, AND/OR
THE DOOR CHIMES REMAING ON. *YC
Yes, I had my wiper swith replaced for the stated problem.
Summary: SOME VEHICLES MAY RECEIVE INCORRECT MUD
FLAPS DURING INSTALLATION AND WILL NOT FIT PROPERLY TO THE VEHICLE. *YC
These are major problems?!?
Summary: SOME VEHICLES MAY EXPERIENCE POOR RADIO
RECEPTION ( AM/FM). *YC
Summary: EXHIBITING A BROKEN SEAT BACK HANDLE
LEVER. *YC
Summary: SOME VINYL COVERED ITEMS SUCH AS DASH
PANELS, DOOR TRIM PANELS, CONSOLES, ETC., MAY
EXHIBIT A SMALL DENT, SCUFF, ABRASION AND/ OR
DISCOLORATION RESULTING FROM ASSEMBLY, TRANSIT,
DEALER PREP AND/OR CUSTOMER USAGE. *YC
Summary: LIFT EFFORT IS EXCESSIVE ON THE DRIVER
AND / OR PASSENGER OUTSIDE DOOR HANDLE. *YC
Summary: CONCERNS WITH ADHENSIVES NOT RECOMMENDED
FOR BODY PANEL REPAIRS. *YC
Summary: EXPERIENCING A " BUZZING " OR " RATTLING
" NOISE FROM THE EXHAUST SYSTEM. *YC
Most of the issues you posted are nits. Talk to me about faulty polution controls on Tacomas that enfluance my environment. No comment on that?
In order to get 12 inches clearance with 31X15" tires, the Tacoma would have to have in the range of a 4 to 6 inch in diamater differential housing. Because no matter how you work it, the height of the center of the tire on a 31x10.5x15 is 14-15 inches.
The differential ground clearance is directly proprotional to the height of the tire and size of the differential case, period.
