-September 2024 Special Lease Deals-
FYI - most gas today that once contained MTBE now contains ethanol as MTBE was been banned as it is can contaminate ground water. The change happened about 18 months ago.
I have a 2000 VW Passat with the 1.8 (ATW) engine. I am experiencing an overheating problem. I recently had a new timing belt, water pump etc put on so I am confident that is not the problem. Then, I had a new thermostat installed, and the problem subsided for a short while, but now when I start it up, the temp gauge stays "cold" for a while, then pops up to normal...but no heat. Then I'll get blaring heat and the temp guage will return to normal. This sequence continues, and I'm afraid that one of these times it heats up (the temp warning light illuminates and the alarm sounds), I might harm the engine. Is there some kind of sensor that I can replace? I have done a little research and I find that there is a Coolant Temperature Sender (Standard #TS477) and a Coolant Temperature Sensor (Airtex #5S1478), I'm not sure which does what...Suggestions please!!
Also, often at a low idle, my oil level idiot light will come on (with the obligatory alarm), but when I rev the engine, it goes off. The oil level is fine, and changed frequently. I think this may be the Oil Level Sensor?
Thanks for any help!
Dave
That's not to say we've not had maitenance issues. We've had to replace the front axles twice (one was warranted...three were not). It ate brakes until recently..switched to a different OEM brand, and they've worn very well.
It did have an oil leak at 90,000 miles, but that was covered under the 10 year, 100,000 mile warranty. When that was fixed, VW also discovered some sort of cam tensioner problem and had to replace that as well.
I do change the oil religiously every 5,000 miles. But since we had the V6, we didn't get hit with the sludge problems (although VW changed their recommendations for all of their engines for oil if I recall).
This year, I spent $450 replacing a bunch of vacuum hoses that had dry rot and were falling apart, but heck, the car is 9 years old, so that's to be expected, and it once again, runs like a champ. We get about 30 MPG on the highway, which exceeds the estimates (and it beat my 2003 1.8T Passat that I had up until 2 years ago).
Would we get another? I don't know. We hope to get another 1.5 years out of this one (gotta get son #2 out of daycare). My DW has her heart set on a an Infiniti M (used probably). But she has said a couple of times that if we can't get a good deal she'd go buy another Passat. Me...I'd keep the current one another year and then try to get an M :-)
The technicians first told me the codes in the computer indicated a faulty cam chain tensioner, but it also had codes for a faulty crank position sensor. I ended up having the crank position sensor replaced (about $180).
I had been experiencing the car just shutting down several times. It would start again after sitting for 15 minutes. I drive 55 miles to work so I can't have the thing dieing on me like that. After I had it fixed, the car runs great. According to the computer it says I am getting between 32 to 35 mpg highway.
Did your mechanic say anything about the crank position sensor or have you ever had the thing just quit?
It is possible the cam chain tensioner needs to be replaced but the crank position sensor can trick the computer into posting the fault code for the cam chain tensioner. If it were me I would have the crank position sensor replaced and see if it cured the problem.
Also, do you use synthetic oil in the car? Even though VW did not start recommending it for these cars they have changed their recommendation and synthetic is now recommended and instead of 10K miles between oil changes 5K is recommended. These engines are quite succeptible to sludge problems and the synthetic helps prevent that.
jcm
WSA281557PL623 2008 VW PASSAT OM PACK ENGLISH
Yes $60.00
http://www.vw.ddsltd.com/cgi-bin/default
The car has 67935 miles.
I am getting the following codes:
17195 P0811 excessive clutch slippage
17100 P0716 Input turbine speed sensor A circuit G182 raneg performance.
17095 P0711 Transmission Fluid Temp sensor A circuit G93 range performance.
This is on a 2001 VW Passat 1.8.
The transmission is not engaging. Please advise.
Appreciated
Whay charge instead of making them available as a PDF? $60, that's why!
http://www.vw.com/myvw/yourcar/carinformation/technicalliterature/en/us/
If it's the same manual owners get they sure can make it free as PDF online for owner's convenience.
Do other manufacturers post their owner's manuals on the web? I've never looked since I have bought new cars since the '80's (my philsophy: buy 'em new and wring every last cent of value out of 'em).
As owner's manual go, the VW one isn't top shelf. They could learn a heck of a lot from Hyundai, judging from the manual that came with my mother-in-law's 2002 Accent. You should see the DIY section...very nice!
BTW, did you look in the pocket under the steering column for your owner's manual? It fits nicely there and it blends in well with the remainder of the dash. I don't understand why people don't leave the manual in the car when they sell it??? :confuse:
I asked the salesman for the manual whenI bought the new car. I think all the first owner could have one. Sometimes the owner lost it and following buyers can't get one. I have to agree Hyundai did good on this part and customers can register on their website and access a lot more tech information than the owner's manual contains.
Many dealerships have a policy that whatever is in the car at trade in time gets tossed because of liability issues with previous owners' names, adresses, et al.
Has anyone had any condensation or window fogging in their 2004 Passat GLS? I get that sometimes in the rear windows or around the edges of the windows. Leads me to believe there's a leak somewhere but I've never seen a drop of water inside the car. Perhaps the seals are wearing down.
I also noticed the instrument cluster will black out on really cold or hot days. Once I turn the car off and back on again, the cluster lights come back up. Is this normal?
Had some creaking in the dashboard but after a couple of visits to the dealer, it seems to have gone away.
Rear window stopped working. Brought it to the dealer. When I got it back, the other rear window stopped working. Duh. Brought it back again. They both work fine ever since.
The CV boots were ripped at about 29,000 miles (maybe sooner, who knows?). They told me it was a $700 job but luckily it was still under warranty.
Had a couple of recalls: break light switch and the heated seats switch. All is well now after the dealer replaced the parts.
Other than that, it's been a fantastic car! It rides beautifully, looks great inside and out and it's quick!
it is on the outside, there is a special cleaner available. i forget where and what its called, but there is such a thing.. probably like headlamp cleaner or something like that. ask the pepboys people or advance auto parts or whatever is near you.
good luck, and it illuminates the road so much nicer after that gunk is off.
It has been a while since your first post and you don't mention if this car was bought new or used. If you bought it used you may have some recourse with the dealer you bought it from. If you bought it new you may be able to have it fixed on warrantee. Either way I think it looks like you need transmission work.
Anyone else please feel free to chime in on this one.
Jim
Jim
I've read, although not actually experienced myself, squeaking from the front brakes can be due to the retaining clips on the inner pad not holding the pad tight enough. The front inner pad retainer clip fits into the piston in the brake caliper. On some of the aftermarket pads, the clip is too loose, allowing the pad to vibrate and squeak. The cure is to remove the inner pad and bend the clips outward to grip better.
Alternatively, it could simply be a matter of just applying some brake quiet paste to the backing surfaces of the pads, where they come in contact with the caliper. Again, the idea is to eliminate vibration which is what the squeal/squeak is.
Here's a link to a photo of the a VW front inner pad showing the retaining clip (it's the bottom one):
http://www.volkswagenspares.com/UserFiles/Image/wearleadpads6.jpg
The current problem happens very intermittently. When we are going at low RPMs and accellerate quickly (like to pass another vehicle or go up a hill), the engine stutters/hesitates like it isn't getting enough gas. I have a VW shop (not dealer - independent) up the hill here. They first diagnosed it as a bad spark plug (caused by running low on gas, sediment getting in & fouling a cylinder). So replaced the plug ($120 repair). I drove it away and a few miles later the problem is there again. So back to the shop. This time they say fuel injectors - and I may as well replace all 6 since with the high mileage if one is failing the others may be following soon. So replaced all six (total $725). Picked it up last night & was running fine for me today but after about 10-12 miles, when my boyfriend got behind the wheel - he is a more spirited driver than I am - the problem showed up again. Every time the check engine light has come on (and stayed on). I don't want to keep pouring money into this car for mechanics to take stabs at fixing it. I found this VW shop recently but they seem reasonable (and are certainly saving me money over the dealer). If anyone out there has had similar problems and/or has ideas I'd really appreciate it, thanks.
If anyone in Seattle knows of a really good VW shop I'd love to know about that as well.
If you have the triptronic transmission, I would advise you to pop it down a gear using that, manually, before you break something.
Like for an 08 Passat, if they happen to burn out, is that covered?
I don't know about an '08 Passat but I think you can just buy a headlight low beam or high beam bulb for 10 - 20 dollars?
Love it, great package, Fun!! Very similar to my 06 Accord feel, but has more goodies, my lease is up on the Accord, shopping around, and found this Passat, got a good lease quote, haven't signed, but based on what others are saying, it is making me scared on the VW maintanence, I see both reviews, good and bad, I don't know what to think. The lease is 36mth, so should I be worried about problems or the engine??
My mothers 04 Jetta, has been pretty much trouble free, literally. I am a Honda guy, but you know what, there are other great cars, and this car has tons of fun packed in it!! Love the 6spd Tiptronic. Am I being really overly paranoid about it all, Really I don't see many, or hardly any newer model problems posted, so I am guessing that is a good sign..lol... The car has the 2.0T engine, should I be worried about that, what if I choose to own it after my lease end, will my turbo eventually start running slow...? Am I reading into all the posts too much, and really it seems to me that the VW has gotten better over time with problems, but consumers don't let a company live that down. Even the new 08 Accord has a few bugs. I haven't had any problems with my 06 Accord.
Now of course, every car is going to have some glitch or little problem, but that is if you consider them a problem...
So let me know what you guys think, Am I just making a bigger deal of it all what I read?
I'm a Navy guy stationed in Seoul, Korea. Thanks to some great advice, I felt comfortable enough to purchase a 2003 Passat GLS (1.8T) with only 36,000 miles on it. I've owned the car for about 3 months and it's been a pleasure to drive. I've put on about 600 miles during that time, and here are some minor issues I've experienced.
1. My car suddenly idled roughly and the check engine light came on. I barely made it a local car repair guy and he was able to diagnose it quickly and determined that I needed two new ignition coils. My car was essentially running on 2 out of 4 cyclinders. Hence, the rough idling. Since I'm overseas, I had to opt for VW dealership's price of $75 per coil, and I purchased two more online to replace the remaining two in order to have brand new coils on all four cyclinders.
2. The brake light had some bulbs burning out and I couldn't simply replace them with standard bulbs from Korea, because the off-set angles between the two engagement pins are 120 degrees apart instead of 180 degrees. Apparently, Audis, Mercedes, BMWs, and VWs share this same offset compared to the rest of the world. I'm ordering some bulbs online.
3. The brake pads only lasts about 12,000 miles, and I'm planning to order the pads in advance.
4. I've been reading discussions about the waterpump and the timing belt. Since my car is 5 years old, should I consider replacing them with only 37,000 miles on the car?
5. The previous owner installed an after-market Xenon kit for the headlights and it was going to be too much money to replace the burnt out bulbs, so I had the whole thing ripped out and reinstalled the standard Halogen lamps. Has anybody gone through the same experience?
6. The seller forgot to give me the owner's manual and I forgot to check the glove compartment. Can you tell me where to go for a replacement owner's manual?
Navyguy
I couldn't order an used owner's manual from e-bay, because they won't ship to APO/FPO address. I've found Bentleypublishers.com and ordered my owner's manual.
I still wondering if I could get some expert opinions on the water pump and the timing belt.
Navyguy
Check under the steering wheel for your owner's manual. There's a slot there that is designed to hold the manual since it is on the larger side and the glove box is on the smaller side.
However, if you purchased a complete timing belt kit from a reputable VW aftermarket parts supplier (germanautoparts.com comes to mind), the kit will more than likely have the improved aftermarket waterpump with the metal impeller, along with a timing belt, serpentine belt, hydraulic tensioners and (if you order the deluxe kit), a thermostat. The metal water pump will extend your timing belt change intervals to the 90,000 - 100,000 mile range (as recommended by the factory).
Here's a rule of thumb that I follow:
If the car is mainly used for urban (stop and go) driving, perform the timing belt service every 65,000-75,000 miles (regardless of whether the car has the OEM plastic water pump or the aftermarket metal water pump). Stop and go driving generates more heat, and wear & tear on engine components in general (than highway driving) - especially rubber and plastic components. I would also recommend an oil change every 3500 miles in this scenario.
If the car is mainly used for highway driving, then perform the timing belt service at 65,000 miles (if you have the OEM plastic water pump), or 90,000-100,000 miles (if you have the aftermarket metal water pump). This is the scenario where oil changes at 5000 mile intervals is definitely applicable...
Well, it was worth the try. At least you'll know where your new manual should go.
I think a sensor may be dirty or have a bad connection. I can't seem to find the location of the sensor to check it. Anyone have experience with this problem?
I love driving my Passat, by the way. Even though it has less power than the TL had, and isn't quite as luxurious (mine is a GLS w/ 5-spd, leather, ect), it is just really fun to drive -- there is just a better connection with the road and the car that is hard to describe. i can't speak for the new body styles, but I really like my '02.
any information on this fault please
17965 P1557
Charge Pressure Contr. Positive Deviation
http://www.bentleypublishers.com/tech/vw/vw.dtc.table.htm
Like splitting hairs, eh?
I have the Bentley Manuals for the B5 Passat, AND Mk4 Jetta/Golf, so I am very much aware of the 105K recommendation. The 90K-100K interval is MY recommendation - I prefer to err on the side of caution rather than roll the dice on a $5,000+ engine replacement.
Having owned and worked on VWs (Mk1 through Mk4) for the past 27 years (including performing many timing belt jobs myself), I believe I know a thing or two about timing belts.... :shades:
