Handling Characteristics
I am curious if any has encountered the following condition.
2001 f250 SD 4x4 v10: Tire Pressure 80lbs
When going into a corner, L or R, the truck appears to have an exceptional amount of sway. Actually feels to lurch over to the side. One would think this vehicle would be rock solid though turns.
jerry
The vehicle has 12500 miles on it.
I have owned it for 3 weeks and driven it ~1000 miles.
Whats the max psi on the tires?
Id suggest dropping the psi
jerry
Anyone have any luck getting Ford to fix this issue?
I have never done this but it doesnt look to hard.
Is the bed empty, or is there a collection of light or heavy stuff? Aluminum shell or tall windowed fiberglass shell? Camper?
Existing tires must be LTs by the pressure. Are they highway, OffRoad, or in between? I would expect a difference in feel between the extremes of the range.
It's the details that set the stage and help us all understand our what to expect from our trucks better.
Bed is empty.
"Existing tires must be LTs by the pressure. Are they highway, OffRoad, or in between? I would expect a difference in feel between the extremes of the range.
OEM Firestone M&S tires from factory.
jerry
I've put 80 psi in rear when I've carried 3500 lbs+, then forgotten to let it out later and drove around empty. Did this one day and hit wash-board surface on a curve and rear end felt like it was gonna kick out as rock-hard tires bounced more than shocks could compensate. Couple of white-knuckled seconds there as ABS got confused by the bouncing and uneven surface. Almost learned a hard lesson on that one.
thanks for the advice. Installed an anti-sway kit from Hellwig last evening and the difference is night and day. Drove to to work today and didn't feel like I was going to lose it in the corners. May stiffen up the rear later on, but quite satisfied now, handles like a truck should.
