Visitor Agreement.
Fuel gauge indicator remains lit in spite of the tank being full. Didn't think it was a big deal. The car ran OK.
Drove the car for more than 20 miles, ran fine and it cut off in traffic. The car started immediately.
Drove the car again on a long trip on the freeway, as soon as I took the exit the car acted funny (like it was shaking and making an effort to continue running) it cut out. It started immediately, during the trip, I would have re-start the car and go. Then it died completely. I was unable to start the car again. Had it towed. The mechanic could not reproduce the problem “this dying problem”. Based on the diagnostic test the mechanic replaced the fuel pump and disconnected lock up torque converter system.
The fix did not work and I encountered the same problem. The car had to be towed again. At the shop the car started immediately and again the car would not stall or die when the mechanic took it for a spin. He is now recommending replacing the crankshaft position sensor and module. HELP!
I have also noticed that every once in a while when I first start the car after it has sat for awhile, that there is a chatter noise under the hood(I'm thinking A/C compressor).
I am a salesman for an automotive and tire center so I am around cars all day long and I know when things are not right. I have talked to the dealer about the lack of power issue but they said that there is nothging they can do if no check lights are on(understandable). Is any of this common?
Good Luck! :sick:
I have a 2005 GTP and while I love the car in general, I've been having problems with the headliner and the sunroof shade. I would be interested in hearing from others about their opinions of the quality of the sun shade. I noticed last summer that when the car got warm the shade pane tended to bow downward in the middle. I've also had this annoying creek or ticking sound (depends on the day) whenever I encounter rough pavement. It seems to be related to the pliability of the shade and rigid plastic of the pice you grab to move the shade back and forth. You can push up on the shade and it makes this noise. I'm shocked at how cheap this part seems to be and I had the dealer look at this and they said it was "normal".
Thanks for your feedback....
I have a 98 Grand prix GTP 98k miles. had a new engine put in at 96k miles as the rods went on the old one.
The new problem is: I just had a battery replaced at the dealership, next day the car stopped so they just replaced the fuel pump.
However the car still will not start, AS the new pump is getting no power. I'm being told that the fuel pump relay will not engage, because my Automate alarm is malfunctioning, and will not send an enable signal to trigger the relay.
Now the dealer tells me because of this I will need to have the alarm removed and also need to have the PCM replaced ( cost $3,500 the PCM is in disable mode and cannot be reprogramed because of the alarm)
Has anyone had the same problem, I've had both relays replaced. the relay is a 5 pin relay, the fuse is good it has power, the top pin on the relay gets power.
All the wiring has been checked at the dealership and has continuity, they did a full diagnosis of the PCM and all is fine, except the fuel enable signal to the relay.
Is there some other way this can be fixed short of paying to replace the PCM
I just purchased a used 2001 Pontiac Grand Prix from an original owner. This is the first time I've purchased anything American so I'm wondering if I did the right thing. Three days after my purchase the low coolant light turned on and it hasn't turned off. I drained the coolant, added new coolant and changed the radiator cap to the suggested "Stant 11230" radiator cap. The coolant doesn't appear to leak an the oil doesn't have water in it. The light still doesn't go away. HELP!!!! Any suggestions?
And my newest problem is the heat. no heat.
I think this will be my last pontiac.
Never another GM car ever.
Good luck,
Layne
I just cannot believe there is and was no recall.
when excellerating at about 10% throttle i get hesitation any where from 50km to 100km/hour. It does this between 2000 and 2400 rpm when it get's to 2400 it drops to 2200 even with the same amount of gas (foot has'nt moved). I have run fuel injection cleaner thruogh it as well as changed the fuel filter. I have taken it to the dealer(I have a friend that works there) we took it to for a long test drive with there scanner and nothing came up no codes at all.
any body have a solution to this problem?
thank in advance
Press & hold the 2 & 3 buttons @ the same time for about 10 seconds; a 2 or 3 digit code will appear, write this # down,press & hold the am/fm button for about 10 seconds: another code will appear, write this # down, then call 1-800-537-5140 and enter 202108 followed by the # key, then enter the #'s that you wrote down from your radio followed by the * key. The call will give you a 3 or 4 digit override code. Write this code # down so you have it if you ever need it again. Enter this # into your radio following the instructions in your owners manual. If you get an override code that starts with 0, you drop the 0 when entering the code into your radio.
If you don't have an owners manual, try this, press & hold the hour button until the first 2 digits of your code come up, then press & hold the minute button until the last 2 digits show. Then press the am/fm button. This should reset your stereo. It did mine.
Hope you find this helpful. :shades:
Went to different dealer ship they called gm and they said there is no fix right now . any help please
My 2005 GP has the shake problem you're talking about. It doesn't hesitate, it just shakes when moving from a stop. The dealer checked it out and the tech. told me that something was definately wrong. The tech made a suggestion to GM for a possible fix, and the GM technical advisors said the problem was within tolerable limits. My car had this problem from day one. I think GM should take these vehicles back if they can't fix the problem.
Let me know
AND IT'S MY PRIDE AND JOY, OTHER THAN THE FACT THAT
I'VE JUST RAN INTO A WATER LEAK IN THE BACK PASSENGER
FLOOR AND ALONG THE INSIDE DOOR RAILING. I'VE CHECKED
AND DOUBLE CHECKED FOR VISUAL WATER SPOT'S AND HAVE
NOT FOUND ANY. MY GUESS IS THE WATER IS RUNNING DOWN INTO THE DOOR PANEL. MY QUESTION FOR ANYONE WHO CAN HELP IS, WHAT CAUSES THIS AND HOW DO I REPAIR THE PROBLEM?. THE CAR IS NOT UNDER WARRENTY AND I'D RATHER NOT PAY A DEALER. CAN YOU SUGGEST WHAT PART'S ARE NEEDED?.
THANKYOU
I would be interested in your class action suit. I listed my 2002 Pontiac Grand Prix GTP fire on 11/12/05 #492. I called a lawyer, but he said he was not the right kind of lawyer for this kind of suit, and it would be very costly to sue GM. It would cost more than the car was worth. I did report the fire to GM's Allogations Dept., who in turn forwarded my complaint to ESIS (an investigation/research company). I sent ESIS all the pictures, repair orders, etc., but have not received anything in response from GM.
Then I have this clumpy clay looking stuff in the radiator. i was told that something was probably put in the car to stop the radiator from leaking. i have tried to flush it out but it hasn't helped.
