Oldsmobile (1999)--no trans dip stick?!!
 k8treed
                    Member Posts: 1
k8treed
                    Member Posts: 1
                    How do you check the transmission fluid level on my 99 olds cutlass? The owners manual indicates a location to check and add every other fluid but directs you to take your car to a dealer to have the trans fluid checked (go figure). I found the cap which is under the air cleaner but there is no dipstick...Help!!!
thanks....Matt C
thanks....Matt C
The procedure must be followed or problems may occur.
(mumble mumble glad I don't have to put up with that nonsense mumblemurmurmmmmm)
What got me flying was Alcan saying you must get the car up on a lift, with the engine running, in order to top up the tranny. Does this mean that such applications cannot be reached from above? Refilling from below makes it a terrible task, including "pumping" the fluid, due to no clearance for pouring (?). Tell me it ain't so!
Let's see now...we save .63 cents by eliminating a dipstick X 4 million of that type of car = hey! Bonus for the CEO!
If a person managed to somehow break off their dipstick sheath from the transmission, they would be left with what GM now offers at the outset. Of course, they conveniently thread the hole and tighten a threaded plug into it, in lieu of the extravagantly expensive dipstick no longer to be installed.
NOW-- Does this give rise to after market dipsticks and sheaths appearing, for those stalwart owners too brain numbed to move on to other brands of vehicles?
Some of the newer Europeans require PCM relearning or a scantool to reset the trans oil level.
This is my living. When they do things like that, all I can do is shake my head.
From the stand point of a mechanic, all it does is create headaches. From the stand point of a person who also supplies technical information, it makes it difficult to have to tell folks that to check their oil, they will have to basically go to a shop.
Luckily, I don't have any such transmission in my overly abundant collection-- at present. I am worried for the future...
now, you guys don't wanna be dumb like me, right? even the Jackass crew doesn't do that kind of thing.
never, by God and all that stands good and true, put yourself in that sort of idiotic position. there are real good reasons that everybody says do >NOT!< put anything underneath a raised car, including your hands... and they are usually on page 4 of the local section of the newspaper, down near the bottom, with quotes such as, "according to Medical Examiner Q. Wack."
IMHO, you shouldn't be having a cupfull in the customer lounge if it's not positioned so you can see the SIDE of the car as well. when stuff falls off a lift while running, I would bet dollars to donuts it usually falls forwards or backwards.
One of the Lincoln transmission engineers praticipates in the Edmunds' discussion thread for the LS, and he said that it wasn't a cost thing... there wasn't enough room for a dipstick!!
This really annoys me, as I like to do a lot of preventive maintenance, and changing the tranny oil/filter is one of those items I like to keep up on.
I not long ago bought a "monster" size Mityvac pump for just such (and many other) procedures.
Also, as someone mentioned a few posts up, the tranny oil level has to be checked when it's at a certain temperature. This isn't easy for an old, backyard mechanic like myself, since the car has to be up on a lift in order to access the "check hole".
There's no dipstick on rear axles.
There's no dipstick on most manual transmissions.
There's no dipstick on these transmissions for a couple real good reasons. First off, the vast majority of people have zero idea of how, when or why you check trans fluid. Or most importantly with what. And it is much easier to avoid a leak if there is no hole to begin with. If you are so intent to check the level, all you do is take it up to operating temperature, lift the vehicle and be sure that it's level ( it's amazing how many people forget that ) and unscrew a 7/16 pipe plug on the final drive side of the transmission. Unlike a dipstick, there is no chance of somebody pouring motor oil in, there is less likelihood of leaks, less chance of water inhalation and yes, reduced costs. Unless you've gone over a hundred thousand miles, there's no reason to mess with this anyway but if you want to, go for it.
Manual transmissions (at least up until a few years back) used gear lube(oil) and so do differentials. The likelyhood of a leak is far greater with the automatic transmission and is one of the reasons they were designed with a means to check the oil.
Manual transmission do NOT have vacuum modulators that when the seal goes, sucks trans fluid into the engine.
And you're theory regarding the water inhalation is flawed, beings that manual transmissions and differentials have vents, which by the way are usually lower then the opening of the dipstick tube. So if there is a chance of water inhalation on an automatic, there is just as great a chance on differentials and manual transmissions.
that changed in the late 70s when GM started putting overrunning clutch bodies of phenolic in the power train, and everybody's electronically-controlled trannies now have a bunch of tissue paper parts in them.
you have to do things right and within the car's published specs or you don't have a chance to get out of the payment book on the original tranny.
diffs are still all steel. there is a difference.
there are a lot of AWD/4wd front transfer cases now, including mine, that are not checkable or fillable. and in fact, they're pretty darned small to be taking up to 110 HP in the case of my vehicle and moving it... shoot, the pulley you hang on a 50-HP electric motor to slip a belt on weighs more than that complete transfer case. guess what, they aren't serviceable items any more, they are replacement items, and you best be watching them for leaks, because that means you need to go to the bank.
Now they made it more convenient. All you have to do now is simply drive a few miles to a repair shop, have the car positioned on a hydraulic platform, lift it eight feet in the air, then remove the filler plug with a special wrench and then stick your finger in a tiny hole and see if there's any fluid without actually knowing how much full is.
Certainly simpler than that diabolical dipstick!
