WHICH REAR END?
I'M READY TO BUY THE 99 SILVERADO 2500LS EXCAB LB
6.0L ATM . MY DILEMMA IS THE 3.73 OR 4.1O RE. I
WILL BE TOWING ABOUT 10K LBS 4-5 WEEKS OUT OF THE
YEAR, THE REST OF THE TIME WILL BE BACK AND FORTH
TO WORK. I WOULD LIKE THE BETTER GAS MILEAGE OF THE
3.73 BUT WILL I NEED THE EXTRA TORQUE I WOULD GET
WITH THE 4.10? I WILL BE GETTING ALL THE TOWING
PACKAGES OFFERED....CAN I LIVE WITH THE 3.73 AND
NOT JEOPARDIZE THE ENGINE AND TRANNY?
First of all, towing 10,000 lbs. you will exceed the tow rating if you go with the 3.73.
Secondly, when you're pulling up long grades, you will certainly wish you had gotten the 4.10!
If you do go with the 3.73, be prepared to see a lot of middle fingers waved your direction from folks that have been stuck behind you on those long grades!
There are three solutions that come to mind.
1 - Order the 3.73 and manually shift the transmission to lower gears to keep both speed and RPMs up. To my way of thinking, this is the best option. Others may disagree.
2 - Order the 3.73 or 3.55 and then add a auxilliary transmission underdrive for an effective ratio of 4.10 or 4.30. Good but you're looking at an extra $2500 or so.
3 - Order the 4.10 and auxilliary overdrive transmission. This is kind of yucky as you may be shifting a lot commuting. Again you'll need some pocket change to the tune of $2500 or so.
I've been in the situation of towing with a 3.73 but not with as heavy a load. All that it took was to manually pull the transmission down to the appropriate gear. It wasn't a big deal. I was able to go up hills reasonably well. I never had to drop all the way down into low.
Rich
For the purpose of this discussion lets assume that the difference between the ratios of top gears of the transmission are 10%. The difference between the ratios of 3.73 and 4.10 is also about 10%.
The question is that if I use the transmission to increase engine RPM, (for a given speed) how is that different from using the rear end ratio to always increase the engine RPM (for the same given speed)???
The engine RPM and speed are the same in either case. What you are describing a truck wound up and still going to slow is probably pure abuse of too small an engine and too large of an over load.
Rich
You have me confused. I think that we're saying the same thing but I'm not sure.
If I remember correctly, each of my F-250s and a 3.73 rear end will go 70 MPH and use 2100 RPM.
If I had a 4.11 rear end it would take 2310 RPM to go 70 MPH. A 4.30 rear end would require almost 2500 to achieve the same 70 MPH. With a heavy load you may never get into the highest gear of the transmission, but if you're huffing and pufffing while moving at 70 MPH, what's the difference?
To move any load by a truck there is a specific requirement for torque. To meet the requirement to perform the work of moving the load, a certain number of RPM are necessary. Does it really matter how those RPM are generated? What is the difference between running in OD with a 4.11 or locking OD out with a 3.73 IF BOTH produce the necessary RPM and torque?
There is probably one aspect that we haven't addressed, efficiency. An aux transmission probably would incur a slight efficiency loss due to the additional gears being turned. (Probably 1 or 2 percent, if that.)
Hadn't thought of the closeness of the ratios. That could make the towing vehicle a bit more raodable.
I guess it breaks down to what are you going to do the most? If you're towing 90% then the 4.30; but if you're empty most then 3.73 and an auxillary transmision to give an effective 4.30. I know that when I'm ready for that 5th wheel, I'll be going the aux route!
Rich
"Pounding the floor with a sledge" sounds like an interesting installation technique to me. I can't imagine why it wouldn't be the same for a 4x2 SC. The end of the transmission is under the front seat. I've been told that the aux replaces the tail shaft and housing of the standard automatic transmission.
Rich
Rob
But then, if as you say you will be doing most of your driving without the load, you might consider the 1/2 ton truck, which can still tow your load.
Big difference in fuel mileage between 1500 and 2500, but not much difference between the 4.10 and 3.73 for either one.
1500 4x4 can tow 8000 pounds with 4.10 axle, and towing package.
I had thought about that..but not real hard..
I can't find that data anywhere
Oh well..
Still going 4:10's
"I'm trying to think, but nothin' happens."
-Curly
A trick for the stoplight racers is to gear in the 5.xx to 6.xx range.
My interest came about when someone on another board mentioned that Ford Superduty's with the 4.3 rear didn't respond quickly because gearing that low produced slower acceleration.
So, everything being equal, a F250 V10 with a 4.3 rear should be slightly quicker than an F250 V10 with a 3.73. Right?
I think that person was combining the effects of lower rear axles with the additional lower transmission gearing that comes with the heavier commercial trucks. Just guessing on that though.
For instance, if you can run to 60 mph with just first gear, and by going to a higher numerical rear end, the thing needs a shift to 2nd at 55 mph, you might hurt acceleration....
Other than that one instance, bigger rear end numbers produce more rapid acceleration.
But your response makes me wonder if that is the limiting factor in the example with the Ford Superduty 250 that I mentioned previously. Especially since 3/4 ton trucks are designed to haul and tow heavy loads and not drag race unloaded at the stoplight.
I'm assuming that the transmission gearing is lower and the shift points come sooner in order to get those heavy loads moving. Therefore a 3.73 may not downshift quite as soon as a 4.3 and run a little quicker in a short sprint.
Am I on to something here?
did i make my point, or just confuse?
Put another way, there is a point at which you can have a ratio that is too high numerically, for the amount of engine flywheel present. To make the Mark Buck case, if you double the ratio, you need to reduce the inertia of the engine (flywheel) to 25%. Then, Mark wins every race to 50% of Cdean's top end.
Okay, sorry for all the info, here is my question. Do you think I should stay with the 3.73 or try to change my order to the 4.10. 95% of all miles on this truck will be on the road with no load, and out of that 60-70% of those will be on the highway to and from work. I don't plan on racing cars at the stop light, but I would like to be able to keep up with other trucks.
Mike
And while I can't speak to what's right for you, I can tell you in my own case, I waited an extra month because 3.73's were everywhere, but I was stubborn enough to want the 4.10, and felt I could use it to maximum effect.
Emotions aside, since you want something for the hill country, like I did, AND are thinking about going to larger diameter tires, I still believe the 4.10 is the better choice for you. Whether it is worth it to change the order at this point, just depends on how relevant the extra wait is to you.
Thanks for the help, I'll have to think about it.
Mike
Don't worry, there a lot of options.
First while you're towing, there's nothing wrong with using lower gears in the transmission to achieve adequate response. The whole thing is getting the proper engine RPMs for the driving situation.
If the 3.73 is really such a big pain while towing it can be replaced two ways. First, have the rear end gears replaced. My guess is that a grand and a half should cover it. The second option is to install an auxiliary transmission. I've seen quotes of 25-3500 installed by Camper World (Maybe that's not the name, but it's the one with the "Presidents Club" and a 10% discount.) If you're near Indiana, US Gear will do it for less. (www.usgear.com)
You're saying 95% is w/o the boat. So probably you have 2 or 3 hills with the boat that may require some transmission shifting on you part. That is probably less than 1% of your total driving.
Is the 1% where a 4.10 or 4.30 would be nice worth the lower gas mileage, higher engine revs for the other 99%? Or is the aux trans cost really, really worth the 1% convenience during the towing.
Good luck,
Rich
4:10 is for serious towing and gives that extra pep when empty as well. The MPG difference is hardly noticable.
3:42 is the best bet for MPG...but may lack some pep and will limit your towing...(maybe not much ..depending on what you are towing)
I'd go with 3:73 for an all around perfect gear.
4:10 if you want that extra pep for highway passing and take off's
3:42 for decent pick up..and the best economy
3:73 is the best choice perhaps?
Good luck
Tim
3:42 and 4:10?....maybe enough for an entire mac combo?
get 3:73....you won't be dissapointed. If you really don't mind a tiny bit extra in gas....get 4:10 and have all the pep you will ever want.
let us know what you do.
Most Silverado's probably have 3:73 in 4WD....3:42 in 2WD...but don't quote me..
- Tim
If you are unsure...remember...it's all the same price when ordering.
mlfreeman
With conservative driving and a tonneau for improved aerodynamics my best tank for combined city/freeway was 17.8 mpg. Way better than I expected. And that's with only 2,500 miles on it!
I've just added a Gibson low restriction cat-back exhaust and I will be checking mileage in the near future after the novelty of the improved acceleration and great sound wears off. This thing really kicks now. Can't wait for K&N to release the new FIPK for this engine.
I think that a two speed rearend would be great, how about some feed back on that!
For the new GM's it looks like the 3.73 and 4.10 are the best choices. I think the 3.42 is only a decent choice for these motors if you are doing LONG, cruise control trips all the time. The mileage reports that are being posted here show very little penalty for choosing the 3.73, or even the 4.10.
I agree that the 3.73s are the better choice for the type of driving you mentioned. mgdvh mentioned that the difference between the 3.73 and the 4.10 is about the cost of an extra mac combo next time. That's pretty close to what I calculate, as long as you go to McDonalds once a week. I have a Ford V-10 with the 4.30. The 4.30 cost me about 2mpg compared with the 3.73. If you drive 15,000 miles per year, that's about $5 extra per week, depending on the gas prices in your area.
Just as an example, the 99 Ford 6.8L V-10 had 275 horsepower and 410 lb-ft of torque. The 2000 Ford 6.8L V-10 will have over 300 horsepower and 430 lb-fts of torque. The liters didn't change, but the horsepower and torque did. The Ford 5.4L also gained horsepower and torque between model years.
Many of todays trucks come standard with 16" wheels where previous models had 15" wheels. With 16" wheels you could get the next lower axle ratio and still end up with the same overall ratio that you had with the 15" wheels.
