Doors Rattle
creak
Member Posts: 2
I have a 2002 GLS Jetta. I love driving the car but the front doors creak and rattle. I have had it in the shop 3 times. They can not find the problem. They have replacedd the door molding, cleaned took the doors apart, cleaned it--it still creaks. Any suggestions?
Also, your door creaking and rattling description is vague at best. Are these creaks and rattles occuring at idle or while driving? Does it happen when you open and close the door? Are the windows up or down? Have you had the doors apart prior to these issues......ie aftermarket speakers installed? Does it happen in the heat, the cold or all the time? My door's were fine until after the last summer when all the lube dripped out of the hinges and the doors started creaking when I opened and closed them. I had the dealer lube everything and they are once again fine. I once had a Camaro that only creaked only when I went over large speed bumps. The dealer told me the striker in my driver door was worn and adjusted it. No more speed bump creaking. Let us know about yours.
I say I have no rattles at speed but I DID have a rattle from bass speaker vibration in my right door armrest. I have a Monsoon system and during some songs with deep base I was getting a buzz like rattle from the right side of the car. While driving during the song at high volume I leaned over and stuck my index finger right on differnent parts of the door with moderate pressure. Finally I found the culprit. It was the passenger armrest. I got home and tightened it and played the same song again. No more buzzing rattle at high volume. Just some thoughts.
The good thing(id=f there is a good thing) is that my rattles disappear for periods at a time.
I do clean them everytime I wash my car and have even used Zymol Weather Strip Conditioner. It did not help.
which sounds a little curious, but if it works....
rubber should not dry out, it's not a water-bearing material. it could de-plasticize and get brittle... it could be attacked by ozone or other pollutants and crumble... or it could be UV sensitive and sun rot... but that won't happen in a day or two. plenty of time to clean it good with rubbing alcohol and clean rags, then take a road trip or two to see what happens. you can re-treat afterwards if it didn't do anything for you.
Got my '02 1.8T last February and had the "foils" installed by the dealer the day I purchased the car. That solution lasted less than a week. I later installed X-treme Rubber Weatherseal from The Home Depot (3/8"x1/8"). I put it around the top of each door and have had quiet doors since. Although, after many rainy days, I sometimes have to spray a little silicone on the car body's rubber seal, but otherwise, no more problems.
