Anyone Familiar witih Passports Using Oil
malachy72malachy72 Member Posts: 325
is the same vehicle. So you might try a search there as well.
  • greenmaxgreenmax Member Posts: 47
    among Isuzus. Depending on the amount of oil being used, it may be normal or a cause for concern. Anything more than a quart per 1000 miles is abnormal according to Isuzu but I would start worrying at half that usage. Don't forget that oil use increases with age/miles and is partly influenced by driver behavior and proper maintenance.
  • morgan63morgan63 Member Posts: 3
    THANK YOU FOR RESPONDING TO PASSPORT USING OIL.
    JUST COMPLETED HAVING A HONDA DEALER LOOK IT OVER. THE PSV VALVE WAS PLUGGED CAUSING THE EXCESSIVE OIL USE. HOWEVER, IT HAS ALWAYS USED A QT AT AROUND 1200 MILES SOMETIMES 1500 MILES. STILL IT HAVE BEEN A GREAT CAR AND I PLAN TO CONTINUE TO OWN IT. THANKS AGAIN; AND YES IT IS A ISUZU RODEO. I HAVE BEEN MORE THAN PLEASED WITH THIS MODEL.
    JUST COMPLETED HAVING A HONDA DEALER LOOK IT OVER. THE PCV VALVE WAS PLUGGED CAUSING THE EXCESSIVE OIL USE. HOWEVER, IT HAS ALWAYS USED A QT AT AROUND 1500 MILES. STILL IT HAS BEEN A GREAT CAR AND I PLAN TO CONTINUE TO OWN IT. THANKS AGAIN; AND YES IT IS A ISUZU RODEO. I HAVE BEEN MORE THAN PLEASED WITH THIS MODEL.
    Sounds like this has come to a quick resolution, so we'll close the topic and archive in a few days.
    kirstie_h
    MODERATOR /ADMINISTRATOR
    Review your vehicle
