Oxygen Sensor
Hello All,
This morning my wife took my Tundra out to the post office and got about 1-2 miles when the Check Egine light came on. She turned around and came back home and I took my 2001 Tundra 2WD SR5 AccessCab to the nearest Toyota dealership's service department.
An hour and a half later I was informed I was ready to go. When asked what happened, they said the Oxygen sensor had failed and they warrantied the repair. I asked what caused it to fail and they had no clue, but added it wasn't uncommon on the Tundra V8 line.
Since TundraSolutions does not allow non-paying subscribers and guest to do searches or posting in the Technical section of that site (I understand perfectly, as it would be a valuable resource), I am looking elsewhere.
Has any other Tundra owner had a problem with an O2 sensor, or any other sensor going out? I have about 27K miles on the truck, of which 90% are non-rush-hour interstate driving. I change the oil regularly with fully synthetic oil and performance filter and never had any problems.
Last Saturday, I got lazy and instead of changing the oil myself, I took the 7-quarts of Mobile one and appropriate Mobile 1 filter to this very same dealership to have them change it (and they did for $9.95!). I also had them rotate the tired, but they screwed that up by rotating only two of the four tires.
Just curious. No problems until after I have someone do something. Coincidence?
There is a Tundra board here at Edmunds. I'd post the same question in there and see if you solicit any responses.
Best of luck,
Dusty
You'll find the Toyota Truck Owners: Problems & Solutions topic there!
PF Flyer
BTW, I thought I has posted to the Tundra board. Did I not do this? The 'You are here' says Town Hall>Toyota>Tundra. I'll post the same in the Owner's Clubs, too!
So yes, this is a "common" problem with the Denso sensors Toyota uses. But if this is all the major trouble I've had with my '00 Tundra in 40,000 miles of heavy duty use (towing/hauling daily) I can't really complain. Other "problem areas" would be the drum brakes, that got out of round at only 20K miles, but they fixed that for free. Oh yeah, my belt is also a little squeaky when cold. Replacing that with a Goodyear Gatorback belt for $27.
My question, any harm done in not having these replaced for a while?
So, being that it has only been two months since my first O2 sensor I wonder if this isn't a chronic problem we are seeing. Two sensors gone bad and only at 28400 miles in 18 months of ownership for this vehicle I bought brand new.
BTW, the sensor and manifold repair bill (under warranty) will be about $600.
"The service rep told me that the O2 sensors frequently fail in the V8 engines."
My last truck had 150,000 miles on it before I traded it in and never had to replace an o2 sensor. That was a 97 model year. My current truck has 50,000 miles and no o2 sensor problems. There seems to be a trend with the Toyota's.
What is that... oh yeah, perspective.
The O2 sensors are covered by Toyota's standard 3 yr/36,000 mile warranty unless you live in CA, then I think they are covered 3 yr/50,000 miles under the special CA warranty requirements.
Toyota issued Technical Service Bulletin (TSB) EG019-02 on 10/3/02 due to the frequent failures of the pre-cat O2 heater circuit failures (trouble codes P0135 and P0155). The TSB states "The oxygen sensors have been improved to correct this condition" and the part numbers have been changed as well. This applies to applicable Tundras as well as Sequoias up to the O2 sensor production change.
I haven't checked on the price of a new O2 sensor at Toyota yet, but the Bosch replacment sensor at Autozone costs about $70.
I hope this helps to clarify the problem.
Alan
I have owned Toyotas for the past twenty years because of their reliability and quality. This is the second issue that I have had with my Tundra. The first was the brakes. They went out at 37K miles and Toyota has experienced problems with them and has since upgraded to a heavier duty brake system. They told me that Toyota was constantly improving the quality of their products and since neither of these issues are safety issues that there was no recall and I did not qualify for replacement.
I may be a bit sensitive to these issues because my expectation of Toyota is so high, but I will never purchase another Toyota again. My wife's BMW runs great and their service is outstanding.
I guess I'm a BMW man now.
Our Avalon cannot compare in assembly quality to my '93 Nissan Sentra, or for that matter, my recently purchased Dakota truck. We've had problems with the power windows, engine sludging, sway bar links, ABS brakes, the transmission is now slipping at 54,000, and lots-and-lots of rattles, buzzes, and squeaks.
And why did I not buy a Tundra? Well, in part again because of our experience with the Avalon. Our dealer isn't overly enthusiastic, either. But mainly because it seemed more time than not that when I took the Avalon in for service I see mostly Tundras in for service with brake, engine, transmission, vibration problems.
Each unit manufactured speaks for itself, not for the brand as a whole. Toyota's are probably better built than many other models, but they are not infallable. All Toyota models are not cast from the same stone. I don't think Toyota makes their trucks like they make a Camry.
Dusty
NOW, the second sensor has gone out, 1 month after the first one was fixed. I am a single woman and on limited income this really sucks. I have driven toyotas since i was 16, and the last two a camry (bought new) and the tundra is a major disappointment. Calling the 800 number tomorrow.
