5.4L Ford V-8 ( L is for LEMON )
Ford's 5.4 liter V-8 is a LEMON. At between
2500 to 3500 miles the engine develops what
Ford is calling "piston slap". This is a loud
knocking caused by the pistons slapping the valves
under acceleration while the engine is cold. The
knocking is similiar to the sound of an engine with
a bad main bearing. I have become an expert on
"piston slap". According to my dealer, and Ford,
there is no repair. Ford acknowledges the problem
but will not call it a defect. Ford has known about
the problem since 1997 and has done nothing about
it.
it.
Aluminum pistons expand at a different rate than the steel parts of your engine. Whomping on the accelerator with a cold engine is a sure way to sieze the piston to the cylinder. Maybe you cold siezed the thing a couple of times when it was brand new, and now you have too much clearance between the piston skirt and the cylinder.
I have lots of friends with 5.4's and 6.8's that are very happy....... I happen to have bought a '99 Silverado, but had no concerns about Ford's motors, just didn't like the taurus cosmetics of the 1/2 ton ford.
Just to let you know, the 5.4 has an excellent reliability record and I have never heard of a failure due to this knocking.
Ford has done a very poor job of informing their customers in regards to this problem which adds to the frustration.
It says a technical service bulletin is coming out. According to TT, the good news is a fix has been found, and that it will affect several thousand owners of Triton engines, in all sizes including the V10.
The bad news is that the fix is major, not everyone will be getting it, and it requires engine tear-down to replace the pistons with ones made from different materials, and different tolerances.
But seriously, I think the problem is thought to affect about 1/10 of a percent. Real enough if you are unlucky, but not terribly likely. But if you do hear piston slap, you must act firmly if you want the Ford fix, pistons and wrist pins. Not everyone is going to get them, because Ford says the problem doesn't affect everyone.
Barlitz
You probably won't have it.
this truck runs better now then when it was new
no piston slap and better mileage.
n.j.
The 1999 production run has recently ended,
and 2000s are starting up soon. So, did any of
the 1999 engines get this "fix" while still on the
production line? If so, that means theres a mix
of "good" and "bad" 99's sitting on dealer lots, so
what date of manufacture should we be looking to
avoid (for example: pre-June1999)
I'm assuming this fix is implemented on all new
2000 engines coming to dealers soon?
Any insiders out there please respond!!!!!
Bet NOBODY will know the exact details until Ford announces the recall.......
You mentioned the "Dieseling" and also the supercharger issue. A motor with a blower will be built with looser tolerances than a naturally aspirated engine will. This may be why your engine "slaps" until the piston skirts expand.
Barlitz
'99.5 White Lightning on 100 octane Unocal.
From what I understand the 4.0L OHV motor in the rangers have the same problem. THere is another group "4.0 liter engine problems" or something close to that on the edmunds site that talks about it too.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
