99 Sierra squeal when stop
Just got my 99 Sierra SLT 4x4 ext cab, 5.3. Drove
it over the last few days after a couple hundred
miles it started making a faint squeal when
stopping. It is similar to a brake squeal but not
very loud.
It happens when stopping, but it does not start
when I first start braking. If I am going slow, 30
mph or so, it may not squeal at all. If stopping
from 50 it will start after braking for a few
seconds. The squeal will stop when tires stop.
When starting the squeal remains until 25 - 30 mph
then it goes away.
Got a f/up call from dealer today. He feels that
the problem is probably a pebble or some other
foreign object that is causing the problem.
Anyone else having this? It is the only thing
wrong so far (no seat problems or vibrations).
This is a great truck! Can't wait until breakin
is over.....
very loud.
then it goes away.
is over.....
I don't know how you would not use the abs during the first few hundred miles, as all it takes is one misplaced bump to set the abs off under braking. This is my only real beef with my 99 4wd. Once the abs is set off the truck 's stopping distance is actually vastly increased while the front wheels regain nearly all their present grip. The truck would stop faster if allowed to actually brake under these situations. I have the Firestone Wilderness tires, and maybe is a function of the poor grip of the tires. has anyone else noticed this? Any fixes?
Seems that some squealing has been occurring on the Silverados too.
know that the four wheel disc brakes do squeal
from time to time. Improved stopping distance
vs. rear drum brakes, but the disadvantages are
that disc brakes do have a tendency to squeal
at times.
Drivers side front wheel, axle seal to casing is causing the sqeel. If you put the front end up and turn the wheel it will make the noise. My dealer simply sprayed penetrating lube where the seal meets the casing and the squeel is gone. Really simple fix. I hope this works for you, it did for another guy who had the same problem. Let us know how you make out.
good luck.
I'm trying to be logical here. One spray of WD-40 and it's gone forever? Why only the left front? I can see that this one is going to keep me up for nights!
Rich
http://community.webtv.net/dp2000/TRUCKFORCEACTION
may I recommend KROIL and SiliKROIL by Kano Labs in Tennessee. These are "super creeping" oils which came out of WW II, and are usually sold industrially. If you regularly get packs of "bingo" cards for various mechanical purposes, you will find them there. It is sold mail order and a spray can is a very good thing to have handy.
I have used them on a CJ-7 with a solidly rusted rear hatch piston that nothing else would touch, as well as other around the house and around the farm uses. I sent a package to my dad and he bought an entire sampler kit as a result. Good stuff!
Front Porch Philosopher
Paul
this topic is being "frozen". It will be archived or deleted in the next 10 days or so.
