Let the word spread forth from this discussion forward -- we prefer Mazda3 engines not because they are Ford, but because they are Mazda!
(My apologies to the late JFK for that loose pun on his moon speech!)
Meade
N. American engine choices are 2.0l (target 148hp) and 2.3l (target 160hp). Both of these engines can be found on the Mazda6 (2.0l not in the N. American-spec Mazda6). FWIW, the world-wide Mazda3 engine choices also include: 1.6l, 1.4l, and two 1.6l diesels (the 1.4l and diesels come around 6 months after launch).
Aside from the displacement size, the 2.0l has NO RELATION WHATSOEVER to the 2.0l found in the current Focus or current Protege.
Instead, the 2.0l is part of the same engine family as the 2.3l (the 2.0l doesn't have SVT though). This family was introduced in 2001. Mazda is Ford's 'center of excellence' for 4-cylinder engines and therefore primarily developed this engine family for sharing with Ford.
So what is Ford's influence on this engine family? Basically, Ford gave Mazda the basic block, some Cosworth processes, some $$$, and told Mazda to come back with a family of engines that met these criteria:
- ensure the manufacturing process is cheap & modular enough that plants around the world can produce it. In fact, there are plants in Mexico, Japan, and Spain that are building this family of engines.
- ensure the manufacturing process allows to easily increase/decrease displacement size so that a lot of variants can be produced
- compete with the best 4-cylinder engines out there in terms of: performance, fuel-efficiency, weight, robustness, and technology. So basically, Honda's 4-cylinders were the benchmarks. However, Honda have since made another step forward and are still the benchmark.
- ensure the engine can be easily tuned for both performance and emissions. For example, the 2.3l PZEV on the Ford Focus is simply a non-SVT and PZEV-enabled derivative of the 2.3l in the Mazda6 and Mazda3.
The last point is interesting, because the family of engines that Mazda gave to Ford is kind of generic (in this particular case, no SVT). It is then up to the other individual Ford brands to tune the basic engine to their liking (e.g. develop their own variable-valve timing or not have it at all). By doing this, each of the brands can kind of customize the engine themselves, and more importantly, the average consumer won't realize it's really a shared engine because things like hp numbers will be different.
A perfect example of this is the 3.0l in the Mazda6. By allowing Mazda and Jaguar to customize certain parts of the engine, the engine has different sound & performance characteristics on the Mazda6, Jaguar X-Type, and Ford Taurus (yet the Mazda6 & Taurus engines are assembled in the same plant). To go even more extreme, I've heard that Aston Martin pretty much just combined two of these together in one of their V12's (though I admit, 'just combined' is a gross simplification).
So the point is that the article isn't really correct in saying the Mazda inherits engines from Ford, it's much more interconnected than that.
So what if the new Golf & even the Renault Mégane offers more comfort. They're not even close in handling/steering. Even the Focus I's ride comfort is slightly less comfortable than the current Jetta/Golf & maybe some French rivals, too.
*runs away*
:-D
I'm exited that the Mazda3 might have 180 hp. 180 hp combined with the handling abilities that Mazda is building into this car should make a pretty nice "sport compact car". It should give a lot of the cars in it's class a run for their money. Horsepower numbers don't come out of thin air, so I'm guessing that someone at Mazda "leaked" this info to Motor Trend.
Yeah, you'd better run Hank (shaking imaginary stick in the air). How dare thee!
U.S. engine choices will be a 150-hp 2.0 liter and the 2.3 4-cylinder from the Mazda6 upgraded to 170 horsepower.
...on a sinuous proving ground near Paris and found the car had most of the sharp precision of a Focus without feeling quite as stiff over the bumps.
Now will the 2.3L engine be also available in sedan AND hatch?
Dinu
qbrozen - this is probably obvious to the rest of you - that quote makes me think the 3 will be 170 horses (I also received Motor Trend's car preview), or will the 2.3 in the 6 be upgraded? Then so, would the engines in the 6 be upgraded?
Volvo V40 replacement getting I-5 turbo from V60.
How on earth do they keep that thing from bouncing around (balanced)?! Wouldn't they have to counter-balance it with weights making it almost as heavy as a V6, thus defeating the purpose?
Either that or some REALLY strong engine mounts!
very simple, they divide the circle in five: the five cylinders are 72 degrees out of phase to each other, and the whole thing is balanced.
Just go to MazdaUSA's site and check out the Mazda3 flash - it says so right there.
Peak hp number can really get people excited(& boost their ego, too, if they own one).
I personally don't like engines that are strong-high-end only, because you have to rev high all the time in order to feel the superiority over the low-end bias ones. That's a lot of costly grinding & wear.
It does strike me, however, just how fixated we have all become on HP. 160 HP in a compact car would have been nothing but a wet dream 4-5 years ago - now we pine for more.
I personally think this 2.3L in this car is going to make for an extremely entertaining package. I think I'll be satisfied with it.
Yep, groovypippin is right on with the engine production locations: Hiroshima, Japan for Mazda3 and Chihuahua, Mexico for N. American-spec Mazda6.
Again, Ford's plan has been to have production facilities around the world that can produce the same engines to ensure engine production is close to auto-assembly plant.
Dinu
The Westmorland Pennsylvania-built Rabbit was so bad one article also mentioned a hair stuck on the paint job. No wonder VW switched to Mexico & built whole lot more models.
That's beyond ludicrous. The Jetta and Golf 1.8T made 180 HP in 2002 and 2003. The Passat 1.8T made 170 in 02 and 03. Huh, that sorta shoots down the whole econo car won't have more HP than the uplevel sedan theory.
The Mazda3 will be an amazing car no doubt but pretty soon you guys will have talked your way into the 3 having a 250 hp rotary with the 6 being downgraded to the 1.6 liter from a '99 Protege DX.
If Mazda can slip one of it's odd little renesis engines into a 3 and charge 25k for it - thus making it profitable still, why not? The engine IS compact afterall and Mazda has already seen that a market exists among the young (the most desirable buying demo for companies looking to build a brand) for speedy limited versions of its econo car, so that seems logical if it's profitable.
Come on people, Mazda is not run by complete idiots.
That's debatable. The repeated HP debacles certainly don't lend much credence to a view that Mazda is run by smart people. The massive incentives, the years of the languishing 626 and Mazda's invisibility on many buyer's wishlists also helps reinforce the brass at Mazda might not be idiots, but they're certainly not very market savvy.
you're right, groovy, about how we've become fixated on HP. And it certainly doesn't always tell the whole story. Unfortunately, its sort of become the common language by which we can communicate our desires. Yeah, our desires have grown, but its because we always should be moving forward technologically. There is no reason why in this day of 220-hp factory economy rockets that we shouldn't demand similar or more from other manufacturers.
Please, Mazda lives on incentives like american car companies. You see sticker on a Mazda and chuckle because the factory incentives and real price always lower the car to a few K below invoice.
I don't see anything bad about incentives.
You should. It lowers the value of the car.
The new Mazda3 will initially be launched in a dynamic hatchback version, with a saloon to follow a few months later. The outstanding attributes of both versions combine to deliver a unique combination of sporty exterior design, confidence-inspiring dynamic performance, a large and flexible interior and one of the segment’s best safety packages."
"Superb dynamic characteristics, steering and braking ensure safe and predictable driving under normal conditions. Supplemental to this is a full line up of active safety systems. These include four-wheel ABS with electronic brake-force distribution (EBD) and built in mechanical brake assistance, along with optional dynamic stability control (DSC) with traction control (TCS) for superior vehicle stability and braking performance on slippery roads and in emergency situations.
Robust front and rear discs yield superior braking effectiveness, consistency, rigidity and response. A 10-inch (255 mm) single vacuum booster enhances brake effectiveness and response by ensuring linear increase in deceleration as pedal travel increases. The result is one of the segment’s shortest braking distances from 100 km/h of only 37 metres."
http://www.carpages.co.uk/mazda/mazda_the_new_mazda3_part_5_26_08- _03.asp
Dinu
Does anybody know which seat colors go with which exterior color? There are 3 colors, blue, red, and looks like purple, do we get all these? Also any beige interior pictures yet?
There's no passenger side airbag cover. Where does the airbag deploy from?
1. In some states, it makes you pay more tax. They tax you on the before rebate price.
2. Hurt resale value. I had a friend who had a $26,000 Taurus SES that sold for $14,500 6 months later. (He got a company car when he moved to Arizona, and it's a black car, and according to him, it's very hard to sell dark cars in the south) He paid $19,000 including all incentives. (He's a good bargainer)
Similar, but not the same.
"Does anybody know which seat colors go with which exterior color? There are 3 colors, blue, red, and looks like purple, do we get all these?"
There's only 2 two-tone cloth colours, red/black and blue/black (there is no purple, it just looks that way in particular pictures). And yes, N. American-spec gets these colours.
"There's no passenger side airbag cover. Where does the airbag deploy from?"
The designers purposely removed the parting line from the passenger airbag for elegance (and IMO that small detail does look amazing & elegant). The parting line actually goes from the right side of the panel with the nav all the way to the right-passenger door.
"A MacPherson strut-type front suspension and a multi-link rear suspension BASED ON THE MAZDA6 are designed and tuned to ensure an excellent balance between handling stability and ride comfort."
Even Mazda is ashamed of its 3's Focus origin. When was the last time I heard the Focus control-blade rear suspension, which is the cost-saving version of the old-Mondeo wagon system, is also used in the 6? So Mazda6's multi-link is a Ford design, too? At least the 6 shouldn't have the blade trailng link, which doesn't have lateral stiffness & totally depending on the lateral links to hold it from lateral flexing.
Oh, ok, the 3's is "remotely based" on the 6's because it's got the same total number of links, but basically the same one used in the Focus II.
The layout of each link is optimised to control the camber and achieve optimum roll centre height. ...
Road holding capability is further enhanced by the rear bushings, which are designed
and positioned to optimise toe changes in response of lateral forces.
Separate positioning of springs and dampers reduces damper frictions, but also frees space for a larger luggage compartment, while maintaining a long coil spring stroke. Twintube gas-filled dampers with large-diameter (35 mm) pistons substantially improve handling and ride comfort.
Bruno
The people who buy American Cars don't even think about resale value.
Dinu
