2000 ram 1500 towing???
We are looking to purchase a vehicle to tow our 24' travel trailer camper. 6100 lbs max. weight loaded. we have spotted a 2000 ram 1500 truck quad cab with a 5.9L V8 5 spd. would this have enough pulling power and umph to tow this type of trailer. We currently have a 94 ford explorer and are needing a "bigger" vehicle to use. Also the asking price is 16,900 is this reasonable - it has 62620 miles. Don't know much more as far as specifics on it. Please advise!!!
Dave
I'm not trying to second guess Dave, but I think I know why he made his recommendation (post #3). Evidence seems to indicate that this engine/transmission combination in the 4x4 seems to have a higher than normal failure rate, approximately 6%.
The automatic transmission in a RAM 1500 4x4 with the 360 motor is the 46RE. This is a very strong and durable transmission. Versions prior to 1998 had a marginal lubrication system in the overdrive unit. Problems surfaced for people who carried or towed loads above 60% of the rated vehicle GVW, or about. This was exacerbated in vehicles operated in cold climates as ATF flows are greatly reduced in lower temperatures. Snowplow service made the situation even worse. Chrysler even issued a cold weather kit that basically bypassed the transmission cooler in order to heat the transmission fluid. Those that allowed the vehicle to come to operating temperature experienced far less transmission problems, or switched off the overdrive on steep hills when carrying heavy loads. Those who neglected to follow "schedule B" service intervals suffered even greater failure rates.
In 1998, Chrysler upgraded their entire transmission line to improve fluid flows in colder temperatures, especially to the overdrive unit. In addition, sensors were added to lock out overdrive until a certain temperature was reached. There were other improvements as well (early shift solenoids were sometimes troublesome), and pre-1998 transmissions can be upgraded with the same improvements.
In general, transmission problems are higher for most truck lines in 4x4 configuration. In this, Dodge is not alone. Dave's suggestion is a good one, especially when buying a vehicle that you don't know how was driven or maintained.
Good luck,
Dusty
As a 2001 Ram owner with the AT, I've heard enough AT failure stories that it's going to be Schedule B maintenance for me on ALL areas.
Dave
Dave
