Replacing Head Gaskets--How much labor?
                    HOW BIG A JOB IS THIS AND HOW MUCH WOULD IT COST TO Have someone do the work?
My crystal ball is in the shop, so you'll have to provide us that info.
I can't stress enough the need for good documentation of the disassembly, every step. Another thing is to get a manual for your truck because you will need the torque specs for the head bolts and the torque sequence for the head bolts, also for the instructions on how to set valve lash or cam timing on an OHC motor. With a set of normal tools and a can of penetrating oil will get the job done, the only special tool you will need is a torque wrench.
Most shops charge between $400 and $600 to do the head gasket alone if you need the have the heads milled or replaced the price goes up dramatically into the $1200 to $1500 range.
Good Luck, and let us know how you fair.
Most heads have very slight warpage and it's a very good (mandatory, in my book) to at least have them cleaned up and checked out by a machine shop.
While in DaimlerChrysler service, the Neon was famous for blown headgaskets - one mechanic was pleased with himself that he could do the job in under 2 hours - he even rigged up a ping-pong paddle handle onto a scraper so he could scrape without completely removing the head, then slide the new gasket in - his cars ALWAYS came back and he couldn't figure out why!
scrape with a copper or plastic tool only, iron on iron will take metal off the block. if it's a aluminum block, don't use a copper scraper (made from hammering down a piece of soft copper pipe.)
use premium gaskets and sealants all the way, and don't goop on extra sealant or use too little... a good manual should say how wide a bead of sealant to lay down, and where. follow that advice carefully. clean your head bolts up nicely, and use the torque pattern and pressures recommended in the manual... it should be a two-stage process, tightening things down in a cross-X sort of pattern all the way around, starting perhaps at one particular mentioned bolt.
it ain't rocket science, but it's not free-form art, either.
At that time (2000-2001), we were flooded with Neon headgasket jobs, mostly '98-99 cars, and we'd do 12-15 a week.
That's no excuse for crappy work.
In that car's defense though, it had over 100,000 miles on it when it blew. It had also been stolen several times, so it's anybody's guess as to how it was driven on those joyrides!
Back in the days of iron blocks and iron heads, would the heads still warp?
ANOTHER ISSUE HERE:
What caused the head gaskets to blow out? If you replace the head gaskets, are you only fixing the symptom and not the disease?
My advise...not really a DIY job!
