Dead Battery How to open hood?
Hi All,
I have a 1996 Mazda Milenia/L with a dead battery. Looking through the owners manual, I could find NO way to open the hood without power. Makes it difficult to charge the battery! (:>(
I haven't had the car long enough to even discover all the bells and whistles, but I'm learning. I will be calling an auto repair shop in the morning to get it fixed. I'm posting here in the hopes someone has a fix for this in case I have a problem with the repair shop.
Any fix will be logged into my owners manual. Appreciate any and all help.
Regards, Bob
Regards, Bob
IMHO, pinheaded move to have automated this. backwards. mooZ, mooZ
I want to thank you for the prompt reply. I figured it had to be something like that, for I can't imagine disconnecting and removing the body to get to the battery. {:>)
It'll be interesting to see if the mechanic has any kind of special tool for this type problem. At any rate, I'll be watching him closely to learn what I can.
Thanks again.
Regards, Bob
TB
I thought of this, but I needed my auto ASAP as I only have the one. I will have to do a little more research to see if your suggestion is feasable for use on my model car, and if so, I will track down a cig lighter adapter of some kind that can be used auto to auto or from a spare battery. Who knows, I may be able to help myself or someone else having the same problem in the future.
Thanks for the input.
Regards, Bob
I'm with you, Badger...who in their right mind would design a hood release like that?!
Never ever heard of an electric hood release on any make or model. Usually a lever on the drivers side kick panel at the bottom next to the park brake pedal, or possibly on the bottom of the dash on the drivers side.
Bob did you get the hood open? Was it infact a power opener?
Didn't Lincoln used to put the battery under the floorboards back in the '50's? I seem to recall Consumer Reports mentioning it in an old road test. I think you had to pull up the carpet, and go through an access panel to get to it. If not Lincoln, I'm pretty sure there was some car where they did this stupid trick!
I think it's a good idea to put the battery further back from the front of the car, like maybe up against the firewall, but inside the car just seems like trouble, and in the trunk is for demolition derbies!
in the case of hybrids, of course, it's another issue, you are riding on the engine compartment
but it's still bass-ackwards engineering to put a battery in the passenger/cargo areas. not quite as bad as putting the gasoline in the ash tray, but getting there....
no, in my book, that is something you don't want between your legs or under your fanny, when the contrivance of 2000-4000 pounds is accelerated to 70 mph or higher, and held there. that's a tubload of kinetic energy, and direct a portion of that at a car battery, and many ugly possibilities suggest themselves. that should be walled away, like, say, across the firewall and under the hood, with a big old massive engine as a shock-block.
just like Detroit does (generally.)
Considering a sack of Portland cement weighs 90 lbs., and I'm quite familiar with that weight, I must say that I''ve never seen an SUV automotive battery that weighs 80 lbs. How about half that?
