How do you like you toyota trd?
Okay I love the looks...mixed on the drive and
know they have a legendary reliability record, but
have heard it isn't what it use to be. Plus
consumer reports does not like the truck. Okay
what are YOUR opinions?
Peter
Peter
Paul
Yes, there are aftermarket companies that do make flares for the Tacoma. One that comes to mind is Performance Plus, and I do believe they are available in different colors, but not sure.
This is the 3rd toyota truck I have owned, the 1st is a 94 4x4 pickup with 22re with 87000 miles. never been to the shop for anything other than oil changes.
96 T-100 sr5 4x4. Only in the shop twice, one was of course the head gaskets, the other was a service bulliten item. both covered under warrenty.
now i also have the 99 tacoma extracab TRD 4x4. only 13000 miles so far. the truck is great. screwed together, fit and finish, performance, and off road ability is unbelievable. worth every cent. got the truck under invoice. The only thing that is noticable, is the TRD suspension is stiff on the highway. There is the trade off with the 4x4, but with the only factory locking diff on a pickup, if you use your truck to go off road, it is a must have. If you dont really go off roading, i would suggest the prerunner. same great looks, same locking rear diff, softer ride, less money, and less to break. Not that I would worry about any Toyota breaking. Good luck to anyone looking for a tacoma.
Do you have any ideas on what are the best options to get? I want the TRD package, but am not sure on whether to go with the SR5 or the Lmtd. Also, I have no idea how dealers will be willing to deal. Normally, the are not that easy at Toyota dealerships.
Thanks in advance for you help.
Anyone else, please feel free to throw in your opinions.
It is extremely hard to believe this, but I still have nothing against that TRD sticker on the truck - even after you have enlightened me so greatly. But LV, thanks for the advice. I'll make sure that I take ALL your advice into consideration when I buy my next vehicle.
Tacoma and found every 15,000 miles you have to
"Lubricate the propeller shaft and re-torque bolts"
Then it says to: "Re-torque drive shaft flange
bolts" What's the difference between the propeller
shaft and the drive shaft? What do you torque the
bolts to? Where are the bolts on the propeller
shaft to torque? Where are the flange boltslocated? Thanks for any help.
comparing Toyotas and Fords and start sharing some
important information. I posted this message a few
weeks back and no one seemed to know anything. Do
you guys actually maintain your trucks???? So here
it is again just in case there is anyone who has a
any idea about this.
I was looking over the maintenance guide for
the Tacoma and found every 15,000 miles you have
to
bolts"
propeller
bdev- I have a 1999 Tacoma 4wd 5sp ext-cab V6 with
the TRD and the bench seat. I find it comfortable
enough. It handles fine and there isn't much road
noise. The stereo is kind of weak though. I get
about 19-20 m.p.g. with a mix of town and highway
driving.
this topic is being "frozen." It will be archived or deleted in the next 10 days or so.
Front Porch Philosopher
