'93 Escort vs. '86 Cavalier: which to keep?? Ford has 98Kmi., Chevy has 28K
The Ford has 98,000 miles - mostly highway, with some City. Chevy - was kept in a garage, but all city miles. I'm leaning toward keeping the Chevy, but since it was all city miles - which is rough on an engine - and since it's 17 years old, will it cost a lot soon in preventative maintenence? IE-does it need a new timing belt becuase of its age? I'd like to hear any and all thoughts on this issue before I make a decision. Which one would you keep and why?
Actually, it's a hard call. Mazda basically built that '93 Escort for Ford, but that implies both good and bad. When it was new, it was good for reliability and refinement, but as it ages, that means more complexity and higher repair bills.
In contrast, GM cars back in the '80's were kinda like a fine wine...they'd just get better with age. Usually they'd start off with worse or much-worse than average reliability right off the showroom floor, but then as they aged, they seemed to hold up better while other cars would run up big repair bills. By the time they were 4-6 years old, they'd often improve to average or even a bit better.
If it were my choice, I'd probably keep the Cavalier. Do you have know the maintenance history of both cars?
The Escort is probably an R134A A/C car, while the Cavi is certainly R12. If that goes out, it will be a bit pricey to get fixed on the Chebby.
Personally, I think the Escort is probably the better driver of the two and will have the nicer interior. I think it will be the smoother of the two cars, engine wise. That Chevy engine is pretty course.
I'm just wondering why you don't keep both? I don't think you would get more than $5K for the pair. You don't state why you want to get rid of one, such as trading for something else.
If I could I'd keep both.
And Andre is right about the timing chain on the Chebby.
TB
When the base Escort went to a 2.0 engine in 1997 (that engine's still around in the Focus today), it finally became non-interference.
The A/C System is R 12
The timing belt is not an issue with these cars. That was a problem with the previous generation of Escorts.
The engine is not interfence. I had a water pump seize, the timing belt drives the pump and there was no damage.
The car isn't a Mazda. The Suspension and the trans (I had 5 speed)is Mazda. Most of the car is Ford and I'd stack mine up with any Toyota, Nissan etc. It was a good ride and it didn't break! The 1.9 liter engine is Ford. The 1.8 is Mazda. Most Escorts from 91 model year on had the 1.9.Believe they upraded the engine to 2.0 liters in 97. It is an extremely reliable motor.
Be careful to what you read/believe on these boards. There are to many people with opinions who don't know what they are talking about!
I didn't say it certainly was R134a, only probably, guess I was wrong.
I'd still take the Escort over the Chevy, miles and all.
TB
The escort is 10 years OLD AND THE Cavalier is 16. Personally I wouldn't touch either one of them.Too late in the game for me. Then again I don't know how this owner will use the car.
The other post goes on about the car being a Mazda. The fact is they are not Mazdas.Don't know what his point is about aging and complexity. Is the Escort any different than any other economy car? You're not talking about a BMW here.
Technically it was called a joint venture, but what that boils down to is that essentially, Mazda built that car for Ford, just like Toyota builds the Vibe for GM.
As for complexity, well a '93 Escort is 7 years newer than an '86 Cavalier, which was pretty obsolete even in '86, so naturally the Escort is going to be more complicated. The Escort's automatic is a 4-speed, whereas the Cav's is only a 3-speed. There's also going to be more computer crap on the Escort than the Cav, and it's just going to be more complex in general.
IT IS NOT A MAZDA PROTEGE. IT IS A FORD. I ought to know, I owned one for 10 years.
There are some people who come to these boards and contribute. Then you have people with opinions that are based on bias. Save the import garbage for another board; that wasn't the question.
Last post, what school did you go to?
