Havoline Extended Life Coolant-DEXCOOL
Last year I bought a few jugs of the above at WalMart on sale and thought it was a good deal, the jug said it was good for all vehicles and would protect for 5 years and 150,000 miles. The label did not say not to use it on non GM vehicles, and I liked the idea that it was phosphate and silicate free as these are hard on waterpump seals. Shortly after that the water pump went out on our 92 Toyota Camry at about 135,000 miles which may or may not be caused by the dexcool. But this has my wondering if anyone else had a similiar situation, as this product is sold at Walmart and other national chains. It would be nice not to have to mess with the coolant every year of so and extended water pump life would be a welcome benefit, but is this really going to happen with this product?
Draining the system and then adding the dex-cool will not work either, as there is still the old coolant in the system.
In order to use dex-cool form the old coolant, a complete flush must be done and even at that, the system probably won't like it.
Best thing, use what was designed for the vehicle.
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Dex-cool and other coolants do not mix. They coagulate and form a nasty gel that likes to build up in the worst possible places, like heater cores and pockets in the head.
Dex-cool is advertised as an extended life coolant, but read the fine print. I will also recommend replacing the coolant every 3 years, amazingly enough, that is the same interval recommended by ethylene glycol manufacturers.
I haven't had any cooling system problems with any of the cars.
there are automakers with "splinter" coolant formulas all over the place... VW, Honda... and I'm willing indeed to let them maintain their exclusivity.
If you cannot drain the block refill with just coolant and you would have a close to a 50/50 mix within the system yet you'll have to drain every 3 or 4 yrs due to the fact the tap water contains other additives that can errode the sensors.
I am so tired of dealer incompentence, hose leaked even after they sent me on my way with a filthy enngine covered in old coolant. had to clean it up myself and tighten the hose clamp myself. Dealers are assembly lines only interested in pushing cars out the door.
seriously, if you believe in the proposition that you should change the coolant every couple years because it's the engine and the radiator that count, not the coolant, it is just not worth the hassle to shift off the manufacturer's installed product.
if you start with Dex-Cool, cool, flush the hell out of the car and put more in. if you start with silicone/silicate, groovy, flush the hell out of the car and put that in.
if you have a Coolant From Hell in your import, flush the hell out of the car and put that back in.
not worth fighting city hall if something goes wrong.
Issue is storage etc. I already have to have the green stuff and dexcool for other cars and to keep the toyota crap on my shelf as well is ludicrous.
all these different coolants probably have a different balance of buffers in the additive package based on whether ToHonSanWagon measures a delta voltage across any part of the coolant loop.
there is also some percentage of the mystery secret ingredient, "MINE! ALL MINE!" wherever there is a proprietary coolant formula.
Well, not exactly.
They use different compositions of metals, plastics and gasket materials.
In the industry of o-rings there are at least 30 different compositions of o-rings. From neoprene to high pressure hydraulic o-rings and each chemical affects each material differently.
As was mentioned, different metals bolted together can create electrolysis. Aluminum and steel together, add some liquid to the mixture and they start to eat each other up.
I still have not received a reply from Toyota corporate as to what their red dye coolant can be mixed with
