I bought a lemon! What can I do?
About 2 1/2 weeks ago I purchased a 1999 Ford Explorer Sport from a reputable dealer. When my check engine light came on, I took it to a local Lincoln-Mercury dealership to find out that it's going to cost appx $2500 to repair everything! And I'm more than sure the dealership I bought the car from was well aware of the car's needs!
I feel bamboozled and I'm pissed off!
Isn't there an "out" clause when you purchase a vehicle that says you have a certain amount of time to take the car back if unsatisfied? Or, like in my case, when MAJOR repairs come up where it's certain they were there before I purchased the car?
Also, you never said what was wrong with the car.
Needs rear pinion seal.
Needs rear brakes, and for the brake fluid to be drained and replaced.
Rear diff needs servicing.
Engine throttle body needs servicing.
Transmission fluid needs to be flushed and filter replaced.
I did call the selling dealership and they are giving me the run around. I know with purchasing a used car that there is "wear and tear," but the above mentioned items should have been caught and taken care of before the vehicle was resold! I bought the car in GA, and my job has since moved me to VA, and now I'm 600+ miles away! I'm not sure if the car will make it back for the repair of these items!
No-there is nothing that I'm withholding! Why would I do that?! I'm just upset that I've investing time and money into this vehicle, and now I'm coming out on the very short end of the stick!
You certainly don't have a "lemon". "Lemons" are vehicles with "significant impairments that affect the use, safety or value of a vehicle" and are usually multiple warranty-related problems - you have no warranty-related problems. The MAF, if it WAS under warranty, would have been replaced by now.
you can get the seals and fluids later.
prioritize the repairs and do 'em as needed to keep the vehicle safe and maintain your investment. the MAF, plugs, and wires you can do yourself, saving the labor costs, if you are moderately handy with tools. you could also do most if not all the fluid replacements yourself. get a Haynes or Chilton manual for your car and see if you can do some of this yourself, that also cuts the cost way down.
I think the selling dealer owes this gentleman something but not the whole laundry list by any means.
I don't see why a friendly discussion couldn't work out some kind of split deal here.
I agree with Zeus, this is not a "lemon" but only a car that needed maintenance prior to sale.
that's why I wanted to draw a line. if this used car has driveability or $$$ light issues, they should be taken care of. if the diff makes noise or leaks, that needs to be taken care of. brakes that are at the line need to be taken care of.
anything else may not need work or, in the case of fluids that are being evaluated on either the "severe service" or "more money before Friday" service schedules, screw it, deal with that next month or the month after that if it matches up with mileage recommendations in the owner's manual.
if the car has, for sake of illustration, 40,000 miles and the manual recommendations are diff at 120,000 and tranny at 90,000, those items were evaluated on the "more money before Friday" service schedule.
last I heard, the "more money before Friday" schedule is just a more polite version of the "New Orleans Mastercard," which is usually measured not in terms of credit limit, but in caliber and barrel length. aka, MMBF is theft.
Many people who buy cars from dealers assume the car is perfect - the only supposed perfect ones are "certified".
Worn shocks, suspension pieces,etc....dirty plenum and TB,etc. Most places mount new tires, replace battery and spend the rest on a detailed cleaning,wax and polish.......shiny and bright blinds the potential buyers eyes!
Most cars other than lease returns are sold because they need something. Even the lux ones are sold to avoid the 60,000 mile service [$1200].
It amazes me what people don't know concerning the second most expensive item in most peoples budget [transportation].
We always find $2,000-$3,000 in deferred and need work on almost every prebuy inspection we do! A smart buyer always budgets this much for surprises.
The rear brakes and fluids should have been caught my you or your mechanic who inspected the vehicle prior to purchase. As far as the differentials, my manual for my 98 Explorer 4wd says that the fluid should only need to be changed every 100k miles. Of coarse, you should verify this with your owners manual.
ours is sold as "blue planet" gas at Holiday. California is also quite active with no-sulfur plans, and I think Chevron is a leader in availiability. if somebody is supplying 2005 grade fuel in your area, it's almost certainly going to be advertised in a manner similar to, "SPILCO. We make the clean gas the government has demanded for 2005 right now. Because we live here, too."
Thanks again.
Refineries are custom built to handle specific types of crude and you cannot use good oil in those designed for bad oil, either.
Isn't it nice that US drivers use 12% of world output each day......slurp.
First thing I would do, is try to find an reputable independent garage to do your work. Ask around at you new 'home'. Ask several people. All this work can be done at an independent for much less money that a dealer.
It needs a mass air flow sensor for code 173 on the check engine light,
-Get a shop to clean this first. A cleaning will usually solve the 'code' being set. Make sure the battery cable is pulled to reset the code. If the code comes back again after cleaning, a new one might be the only solution. These do not have to be bought at Ford, the shop can buy at parts house for half or less than Ford price. Cleaning - $75.
needs new spark plug wires and clean spark plugs.
-If the milage is 50,000 or more this probably will help. Get wires and new plugs both. Parts should be about $50, plus labor of about $75.
-This probably isn't 'critical', depending on how much it leaks. Have gear grease added and see if it leaks a lot. My wild guess to fix - $100.
-Shop should turn drums and new shoes for about $125.
-What's the milage on this thing? If not over 100,000 miles this is not needed. Of course, the leaking pinion seal leaks diff grease. So, fixing this will involve 'servicing', which means replacing the grease.
-This is an operation where a clamp is removed and a 'tube', the throttle body, is swabbed out with cleaner. Maybe a little tooth-brushing applied also. Shop should do this for $75.
-Who knows. I change mine about every 30,000 miles. Some people never change it. Shop should do for about $100. Don't spring for the 'flush' job, this could cause more problems than it helps on higher milage vehicles.
What's the total for this all, about $600? These are my somewhat 'wild' guesses for what you could get this done at a decent shop. I might be off here. But if I'm off by 100%, this still would be about half of what the dealer priced it to you.
You bought a used car. Without inspection, probably, to find this stuff. It was not a lemon by any means. And, I'm sure the sale was 'as is', so you have no legal recourse. And you've probably driven it several thousand miles since purchase, since you moved.
