Dodge Dakota Problems/Fixes
                    I have 2000 dakota quad that when i make a tight turn it makes a ( clunking ) noise, a had it at
the dealer they greased the bushings helped for a while but returned it also makes alot squeaking noise when going over bumps ( thinking cheap shocks ) anyone out there have similar problems???
Dusty
All Chrysler products suffered from an inordinate amount of compressor and evaporator failures in the years '94 - '97 directly attributed to component supplier quality issues. I do not remember who the compressor supplier was. The evaporators (along with the heater cores) of that era were supplied by Harrison Radiator Division, General Motors.
However, that has not been a problem in recent years and especially in Dakotas. A leak can be anywhere there's a connection. I work for a large firm that currently runs Ford Windstars and they've been troublesome in this area too.
I think you'll find that you've got a one-off problem. To the best of my memory, I've heard of no other Dakota owner in a number of years have an issue with AC components.
Best regards,
Dusty
I got a note from Chrysler about a week ago that they extended the warranty on the A/C compressor for my 2001 Grand Caravan to 7/70....
I'm not sure what the mini-van series have been using.
Dusty
With a 36000 mile warranty and 35000 miles on the truck, we contacted the dealer. We were told to bring it in just before the 36000, but said if they couldn't find a problem at that time it would not be covered by warranty.
My 2 questions: 1) has anyone had or heard of such a problem? and 2) did I miss read my warranty? I thought it was "3yr or 36000, which ever came first", not "3yr or 36000 assuming we can find the problem" .
Bookitty
I banged on the steering wheel and they worked again. I've been told it might be the "clock spring" that make various electrical contacts in the steering assembly? The problem hadn't happened
again in the past 6 months.
Latest intermittent problem is my gas gauge.
At the 1/4 full area, gauge goes to empty and the warning beep and empty indicator comes on. Turn the key off/on, it might read correctly. Probably faulty sending unit in tank? I'm making notes for
when I decide to take it to dealer.
I've got 7/75 extended warr. Just don't have time to leave truck for repairs.
Yes, front end pops!
Other than that, we love our Quad Dakota!!!!!
4.7V8,auto,2wd,lim-slip,advance bed cover.
MM
If this is helpful, those speakers are 2.75 inch diameter (6.9cm) and rated for 160 watts -- with, of course, the factory Infinity amplifier.
Good luck,
Dusty
Read in the newspaper about a recall on 01-03 Dakota's with manual transmissions (ours is) where the clutch rubs the wires that control the turn signals, horn, and headlights and can cause them to fail. Sounded suspiciously like it could be related to our problem. According to the dealer, our VIN is not on a recall list and I need to just wait to see if a recall notice shows up in my mailbox. Also got an "I'm sure they did" answer when I asked if they had checked that particular wire. Let's just say I wasn't convinced. They say there are only 150 trucks nationwide on that particular recall list. Does anyone know of a phone number for more information on this recall?
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/tsbsearch.cfm
OR
http://www.nhtsa.dot.gov/
Good luck,
Dusty
