Car won't start
I have a 97 accent manual shift. About once a month the car won't start. I crank it, but it won't turn over. I don't have my foot on the gas pedal. If I walk away and return in 10 or 15 minutes, it usually will start, but sometimes it won't so i have to tow it. The starter, plugs, filters, battery etc are all fine. The car starts almost all the time, but for no particular reason it occasionally won't. It seems to happen when the heat and humidity are high, but I've also had the problem first thing on a 40 degree morning. Any ideas would be greatly appreciated.
if nothing else is done, you come back in 15, and it starts, it's wiring, relay, solenoid, and/or starter motor that's at fault.
if it isn't even turning over, (no noise, maybe a click, maybe a R_R_R_rrr..........rr........... as if it was 40 below) it's battery as prime suspect, with wiring possibly also funky.
What could the problem be? the electrical system went under a load test and the battery and alternator checked in fine. Now, the dealer did say it may be the starter. Basically the tech at the Lexus dealer said that the starter may not be making the electrical connection. Now, of course, when I took it to the dealer it starts perfectly. Therefore, they can't say for certain if it's the starter or not.
Any ideas?
nowadays, it's parts replacement. can't figure it out, replace another one. still an issue? --, well we haven't changed the tile on the floor yet or washed the windows, we'll try that.
they COULD use a DVM to check continuity while very slowly rotating the starter motor... or even a testlight. then they could test the starter solenoid in the same fashion. they could even use a sub-ohm-meter, if they had one (I built my own once, but needed the parts more for something else) to insure there were no defects in the battery or ground cable and connections.
but that takes time.
what I would do on my truck at this point would be disconnect the battery, tape the end, put that in a plastic box to be darn sure there is no power availiable..... slide underneath and clean up the starter connections at all ends and use lockwashers before bolting things back together. if I had issues after that, I would replace the starter on spec because I have had one do this myself and my sister has also had a winding go open. if that's the one that ends up in contact with the commutator brushes for next start, voila! -- it won't start. another winding ends up in contact, it will. luck of the draw.
until I had the time to get dirty, though, I would do what a grey old mechanic suggested on Sue's car... carry a chunk of two-by-four, because it doesn't conduct and make sparks, and if you have a no-start episode, whack the starter a couple times with the end of the two-by in its center. that should jiggle the armature over a touch and allow a good winding to get power.
Thanks for the advice. I'm going to print out what you said and take it to my local mechanic that I know.
So, would you say it is the starter at this point? I mean if the battery and alternator checks out fine? And a quick jump starts the car?
Excluding that, I wonder if your dealer still has enough collective wisdom left in his shop's gene pool to do a starter draw test and see how many amps that puppy is asking for when cranking.
I think you're referring to a cheat coil trying to null part of the meter's magnetic field, which pulls on the slots or holes of a spinning disk through induction, and thus spins the dials.
probably not of much use to the danger-seeking power thief, who is as likely to blow his butt to the moon as shave a buck off the monthly bill, because in most areas, the power companies have switched to non-mechanical remote-reading meters by now. while you can retard a corner of the meter rotor in a mechanical unit, until caught and taken by the lawyers, the pickup on a remote meter can be a chip that senses voltage differential on a piece of wire across an inch or so of length. that's a lot harder to cheat, and you are almost certain to get lit up in the process.
N O T recommended.
One thing to be aware of, that vehicle has a starter relay (little square box, in fuse relay block) and theft deterrent, that the starting system runs thru, so if all of the cables check out and the starter checks out, then it may be possible that the Park/neutral switch is a problem if AT trans, the clutch switch if manual or the starter relay may be the problem.
Yes/no
If no, do this now.
If yes, and still no-go, then remove and clean both battery terminals.
Try jump starting again.
If no-go, check clutch pedal start switch and fuse for this switch as well. This (the switch, NOT the fuse) could be temporarily bypassed by connecting the wires to each other (by-passing the switch itself)
If still no go, I would say starter solenoid or starter motor has had a coronary.
You could verify, if you are courageous, by push starting the car but please be very careful doing this or have a friend do this for you. If it starts with a push, you can pretty much assume a starter or solenoid issue or the connections to either.
