Ford Fusion/Mercury Milan
1959698100101111
  • baggs32baggs32 Member Posts: 3,229
    Still not a fan of the leaves (in either Honda or Ford
    Ford did realize there would be people like you and they do allow you to customize many parts of that Hybrid gauge cluster. The leaves can be changed to a graph readout if you don'tlike them. There might be other options for that part of the display but I'm not 100% sure. I don't remember reading that Honda allowed you to make such a change to their 1985-looking leaves.
  • coldcrankercoldcranker Member Posts: 877
    You Fusion owners have made a good choice. I love my '05 Freestyle, but I just rented an '08 Fusion SEL V6 last weekend and had some fun. Spins the front tires (Michelin Primacy 225 width) easily. Handles great. I had to really watch for highway patrol vehicles. I know this thing gets great quality ratings, and now I know its fun to drive. Ford is doing allright. I guess the criticisms come for the suspension being a bit too harsh compared to Accords, Camry, Malibu, Sonata, but I had no problem with it myself.
    Can't wait for the Fusion hybrid to come out in about a year or so, as it should use the time-tested Ford Escape excellent hybrid system.
    That V6 is the 3.0L V6 Duratec like in my '05 Freestyle, but I think the Fusion is different than the Freestyle version and has variable valve timing (VVT) and slightly different heads/valvetrain (?). Is that the case, Fusion owners? I know Ford tweaked the old 3.0L V6 to go into the '09 Ford Escape, increasing power without sacrificing fuel economy, so there is life left in that highly evolved, proven design for a 24V V6. (Aside: Did you know Porsche originally designed the Duratec V6, and a 2.5L version went into the Ford Contour / Mercury Mystique / Mondeo(Europe) 14 years ago?)
    On the downside, Ford needs to get better MPG out of its 4-cylinder Fusion, since Saturn Aura is up to 33 MPG highway, and Hyundai Sonata is at 32 MPG highway to Ford Fusion's 29 MPG highway.
    Yep! I believe it made 195hp in SVT form. Comparable to the Nissan Maxima.
    Not sure what the torque numbers were.
  • akirbyakirby Member Posts: 8,062
    Job 1 for the 2010 Fusion is February including the hybrid based on current reports. It's not a year away - it's only 2 months away. Yes, the 3.0L V6 in the Fusion has VCT good for 221 hp compared to 200 or 210 in the Freestyle. The 2010 Fusion gets the updated 240+ hp version.
    It also gets the same new 2.5L I4 from the Escape and should net 33 city/34 highway - best in class. The hybrid fusion will beat the camry hybrid's fuel economy by 6 mpg (39 city vs. 33).
    There will also be a 263 hp 3.5L sport version available with manumatic shifting on the V6 models.
    Thanks for the responses. My Freestyle Duratec V6 (203 hp, 205 ft-lb) has roller followers on the valvetrain, compared to many other Duratec V6 variations out there (Jaguar, Lincoln LS, Fusion, Mazda, etc.) that tend to run DAMB, aka direct-acting mechanical buckets, which rev better but don't wear as well over time. I'm guessing the Fusion uses that, and I know the other cars do. I think the old Taurus used roller followers, too, not the DAMB. The Freestyle Duratec V6 also runs the water pump on a mechanical gear, where the others are using a belt. Odd that they wouldn't just use the new gear-driven water pump across the line. Wikipedia (search in there on the word duratec) at Wikipedia Link -- put in duratec as search word. has a good summary of the details. Its been a while since I took a peak in there, so I'll see if they have the new info about the '09 Escape's new Duratec V6 variation.
    OK, good education article on the newest changes coming to the Fusion/Milan at Click here for details
    Anybody ordered a Fusion hybrid yet, set for Feb. 2009?
    Wow what a new car. Better than a Camry hybrid by quite a bit.
    For those interested in discussing the Fusion/Milan hybrid, please go here.
  • explorerx4explorerx4 Member Posts: 20,993
    had my first occasion to experience how the awd works last weekend in the snow.
    the snow was either fresh or packed down, not plowed, but the landscape was pretty flat.
    didn't notice any wheelspin starting out or turning, so i guess it works pretty well.
    you still have to be careful about stopping.
    had to scrape my windows for the first time too, bought the car last march.
  • threadsthreads Member Posts: 9
    "Unlike the four-wheel-drive systems found on many trucks and SUVs, Fusion’s all-wheel-drive system has been tuned with an emphasis toward performance while still offering confident, all-weather driving. By constantly monitoring and predicting traction, the system seamlessly delivers torque to all four wheels, even before wheel slippage occurs. An active, on-demand coupler can deliver the precise amount of torque to the rear wheels up to 100 percent." [2006]
    my previous ride was an 02 explorer 4x4, which was taken over by the kids.
    that is what i was used to.
    my wife drives an escape with triple treads and she is extremely happy with how it handles the snow.
    i'm thinking the fusion will be fine. one of the reasons i picked it was in a couple of snow storms when pretty much only 4x4's were moving, i saw a milan awd and another time a zephyr awd being able to handle the driving conditions.
    The Fusion AWD is a very capable winter car ( http://en.autos.sympatico.msn.ca/resources/article.aspx?cp-documentid=1408348 ). The front to rear power vectoring with brake lock differential Traction Control on both axles makes the Fusion AWD unstoppable in all but the most severe road conditions ( brake lock differential Traction Control operates at speed up to 62.5 mph).
  • dieselonedieselone Member Posts: 5,729
    Wow, that pic brings back memories. I bought a '98 SVT Contour in early '97 when it was first introduced. SVT actually called me shortly after I purchased to tell me I was one of the first 50 who purchased one. They'd call from time to time to see how I liked the car etc.
    It was a fun car that unfortunately had reliability issues. Great v6 though. Loved to rev with fuel cut off at 7200rpm and was an absolute blast to go through the gears. Got lots of tickets in that car. It just begged to be driven fast.
    The '98 2.5 Duratec SVT v6 was 195hp and IIRC 165 ft-lbs of torque. It was bumped up to 200hp in 2000 I believe. It was a pretty high strung engine with the torque peak at 5500rpm and hp peak at 6600, but it would pull hard to 7k rpm redline and was smooth enough that if I wasn't watching the tach closely I'd hit the rev limiter at 7,200rpm.
  • mek0123mek0123 Member Posts: 33
    ON that 13.5mpg urban driving. My '01 Grand Caravan gets about 14mpg in the city and I live in Michigan. I also let my van start up about 20 minutes in the winter. I reset my mpg avg meter when I want accurate mileage. Stop and go really hurts economy. Also, I change my six plugs every 18 months. They are usually about .015 out of spec. Once I start driving normal again my economy city/highway combined gets back up to about 21mpg avg. Too, it's well broken in at 251K on the odometer. Stop and go traffic and excessive idling is the worse thing for any engine.
  • mz6greyghostmz6greyghost Member Posts: 1,230
    Gee, I wonder why your mileage is so bad...
    20 minutes? WAY too long in ANY climate to leave running. Save gas, time, and $$$, and give it (at max.) two minutes to idle before moving. The vehicle actually reaches operating temperature quicker when moving compared to idling.
    Yeah, that kills fuel economy. Just idling an engine can burn close to a gallon/hr, so you've wasted a 1/2 gal before going out of your driveway.
    I've noticed, just letting my '07 Expedition idle a bit more in the morning and when dropping kids off etc., along with single digit temps have dropped my avg. city mileage from 14 to high 12s. I never let it idle more than 5 minutes.
    Does anyone know for sure when the 2010 Fusion will hit the showrooms? My dad's 2000 Taurus is pushing 200k miles and he's contemplating a hybrid as he has a 60 mile round trip commute for work that is basically stop and go with little highway. He's thinking a Fusion Hybrid may be a good option. From what I've read it looks like a promising car. I like the restyle.
    I'd expect the first 2010 models to hit dealers in March. The hybrid may be a month or two later. Should know a lot more at the Detroit auto show.
    Just start and go, everything I've read says there is no need to warm-up, just drive gently at first.
    http://www.cartalk.com/content/columns/Archive/2007/April/06.html
    Thanks, I'll be hitting the Chicago auto show, so hopefully some good info will be available by then.
    so i could check out how my fusion awd would handle a snow storm.
    i wanted slippey conditions and traffic.
    it did really well. was really good taking off from a dead stop.
    got by a struggling accord a couple of times when i was able to pull up next to them
    at a light in the not travelled lane, then just went by them when the light went green.
  • have1merchave1merc Member Posts: 2
    i have a 2006 Mercury Milan 6A , handles very nice in the snowy northern new england, i passed a Hummer !! without even thinking about it. and it was ugly out there....
  • dmysterdmyster Member Posts: 12
    I bought a 2006 Fusion SE a few weeks ago, and have been noticing a buzzing noise in the dash on the driver's side when accelerating at lower rpm. If I accelerate harder or let off, the noise goes away. I found a TSB code 07-1-10 that seems to describe the problem... but I'm not really able to spend a lot of money to get it fixed. Does anyone know if this is a serious problem or not?
    TSB 07-1-10 (Vibration-Buzz from Bulkhead)
    http://www.fordfusionclub.com/index.php?topic=66540.0
    awesome! thats perfect... thanks!
  • mitchfloridamitchflorida Member Posts: 420
    Ford executives told Automotive News yesterday at the 2009 North American International Auto Show that the next generation Ford Fusion will share a platform with the current European Ford Mondeo.
    "We're transitioning to a Fusion-Mondeo convergence," Derrick Kuzak, Ford's vice president of global product development said at the show. He confirmed that Ford EUCD platform, which the mid-size Mondeo is built on, will be the foundation for all of Ford's mid-size vehicles, including the Ford Fusion.
    In the U.S., the Ford Fusion goes head to head with the Toyota Camry, Honda Accord, Hyundai Sonata, and Chevrolet Malibu in one of the most competitive segments in the market. The Fusion currently rides on the Mazda 6-derived CD3 platform, which is also used under the Mercury Milan, Lincoln MKZ, Ford Edge, and Lincoln MKX. Ford reduced its controlling stake in Mazda to 13 percent late last year.
    Since Alan Mulally took over as CEO for Ford, he has made a push to globalize platform development. In the coming years, this will lead to European-engineered and developed models migrating to the U.S. market, including the Ford Fiesta, which will be sold for the first time in the U.S. market, and a European-derived next-gen Ford Focus. We can reasonably expect the next-gen Lincoln MKZ, Ford Edge, and Lincoln MKX to ride on the new Fusion platform as well, although the future of the Mercury Milan is uncertain.
    Although none of the executives at the auto show would say when the next-gen global mid-size car would appear in Europe or North America, analysts and suppliers expect the car to be available in the U.S. in 2012 as a 2013 model.
    I've always been amazed that a Fusion CD3 Mazda6 platform can be used on the 4,400 lb Ford Edge, whereas the Fusion weighs 1,000 lbs less. Does anybody know if the control arms and spring mounts are at least different when using it on a big crossover like the Edge? And there must be reinforcements added to pan of the heavier incarnation.
    the current fusion, i have an '07, is based on the previous gen mazda 6.
    you can see where the original platform was stretched in width.
    i have been in an edge a few times, even driven 1 for a few days, but i never thought to look for the same platform underneath.
    The Edge platform was highly modified from the Fusion platform. I'd say they're more cousins than siblings at this point.
    akirby, I know what you mean. I'd love to compare the underside view of an Edge to a Fusion. I'd guess there are welded-on stiffeners added to the pan, and the control arm mounts and control arms themselves are thicker/longer, and the springs are wider. We all understand that car makers want to save money by sharing platforms amongst models, but man thats a big diff in weights on that Mazda6 platform between a Fusion and an Edge.
    I think you pulled the weights from two bad examples. Ford's site says a 2008 Fusion SE FWD V6 weighs 3280 lbs while a 2008 Edge SE FWD weighs 4078 lbs. That's still a difference of 800 lbs but a lot of it is due to extra sheet metal, the aforementioned structural reinforcements/additions, more glass, more sound deadening materials, slightly heavier engine, larger wheels, etc.
    I'm guessing the 2010 Fusion will be a little heavier since it will have more sound deadening materials and some other enhancements that seem likely to add a small amount of weight.
    baggs32, Yes I know that the weight diff between an Edge and a Fusion is because the Edge is bigger. .. My point is: Ford uses a platform really meant for a 3300 lb vehicle on a 4000+ lb vehicle, and I was wondering exactly what Ford has to do to keep the chassis stresses under control. Thats like you or I putting on a 100 lb backpack with our same knees, back, and ankles. Thats a lot of extra weight to carry around, so something has to give, but what components specifically.
    They modify it. I'm not sure it can be put any other way than that. Honda made the Pilot out of the Accord and Odyssey, Toyota made the Highlander and Sienna out of the Camry, Mazda made the CX-9 out of the Mazda6. It's not like they dropped the body of the Edge on top of the Mazda6 chassis and crossed their fingers that it would hold up. They do add structural reinforcements and bend a bunch of the chassis components to make it all work. The Edge chassis is based on, and loosely I'd wager, the Mazda6 chassis. It's not using the Mazda6 chassis intact.
    I'm not sure anyone short of a Ford engineer can tell you exactly what had to be modified to make it work for the Edge.
    baggs32, Or just looking underneath the two vehicles would be nice. No huge effort there, no engineering degree required. What parts are bigger? I do agree with you that its a very loose re-use of the Fusion chassis on an Edge.
  • xmechxmech Member Posts: 90
    I'm suprised how the 2010 Taurus almost came out of nowhere, already has a date when you can test drive them (Buy 'em?), and seemingly the facts and figures like MPG are available. So what happened to the 2010 Fusion? Lots of hype about the hybrid and I-4 MPG, and a few rumors about when we may see them in the showrooms, but that's about it. (OK, a nice bunch of pages on Ford's website, but they still don't have a V6 MPG figure yet? I heard they're already running the assembly line in Mexico for them.) Did I miss something? Are they having issues?
    I'm still not ready to jump into buying one, but just waiting on the news.
    They're in production now but they have to go through a rigorous new launch procedure where they build flawless vehicles for 5 straight days. One problem and they start all over. Production was initially scheduled to begin in December but got pushed back to clear out the excess 2009 models.
    Complain to the EPA about that one. Ford has their numbers for sure but only the EPA numbers get put on the window stickers and it's up to them to get those numbers to Ford.
    xmech said "I'm suprised how the 2010 Taurus almost came out of nowhere, already has a date when you can test drive them (Buy 'em?), and seemingly the facts and figures like MPG are available."
    Came out of nowhere? Its just got different sheetmetal compared to the 2005 through 2009 Ford 500/Taurus, so its not that new of a car for Ford to bring out. The drivetrain has been out there for about 3 years, too. Comparatively, the 3.0L V6 in the 2010 Ford Fusion has had some semi-major engineering changes, so there is a lot new there. And its a 2010 model, theoretically, and its only Feb. 2009, so maybe a little patience? Still, the 2010 Fusion Hybrid is going to be sold in about a month, not that long to wait.
    Are you sure? According to EPA, it is the manfuacturer that gives the numbers to them:
    Fuel economy is measured under controlled conditions in a laboratory using a standardized test procedure specified by federal law. Manufacturers test their own vehicles—usually pre-production prototypes—and report the results to EPA. EPA reviews the results and confirms about 10-15 percent of them through their own tests
    http://fueleconomy.gov/feg/how_tested.shtml
    Are you serious??? It's got different EVERYTHING except the base drivetrain. Totally new interior and exterior AND a 365 hp SHO version. It's basically a new car (for once). It's closer to the MKS than the old Taurus.
  • savethelandsavetheland Member Posts: 671
    It is inteesting when Camry or Accord come with "just new sheetmetal" (and they usually do) everybody crows how Toyota and Honda create brand new car every 4 year. And when Ford does the same it is the same car with "just new sheetmetal".
    I believe both the Taurus and Fusion have significant changes from engines to suspensions to sound deadening and glass. I expect they will both be much stronger and improved competitors in their respective classes.
    Yes, I'm 99% sure. This page tells you that the mfr does not test every vehicle but the EPA does. The page you posted is therefore telling us that the mfr does submit what tests they do perform and the EPA still tests them too only verifying 10-15% of them which means they do not verify the other 85-90% of them and just posts their own results on their site and on the window stickers.
    It doesn't say anywhere on their site why they do the verification. My guess is that they do it to police the mfrs testing methods and results.
    For example, Ford's initial FE release on the Fusion Hybrid stated something like 38 or 39 MPG city. The EPA says 41 MPG city and that's what will be on the window stickers.
    I could be misinterpreting this so any insight is welcome. :shades:
    Not to mention the huge interior improvements. The Taurus interior is now darn near that of its sister the Lincoln MKS. Then there's the Taurus SHO which will use a more powerful version of the EB 3.5L TT that will go in other Ford and Lincoln vehicles.
    I just saw both, Fusion Hybrid and Sport and Taurus Limited, in person at the Pittsburgh Auto Show yesterday and both were pretty impressive. The Taurus blew me away. Pictures don't do it justice. Unfortunately the Fusion Sport and Taurus Limited were on turntables so it was hard to get a great look at them. The FFH was on the floor, but locked, and it looked great inside and out. I'd buy either one but the Flex won my heart that night. :blush:
    Young people were admiring the Taurus though and I heard many positive comments on it. Maybe Ford is on to something here?
  • cannon3cannon3 Member Posts: 296
    As a car buff for 30+ years, along with surfing this wonderful internet. I am going to make a bold prediction. Ford will regain its #2 spot for U.S. sales in 5 years. Taurus, Fusion, F series, to name a few vehicles are really turning heads in this industry. Ford is listening to the consumer and is giving consumers what they want. The soon to be released Fiesta, and the 2010 Focus are also going to be big winners for Ford here in the U.S. Ford is still small enough to turn its ship around and become profitable and a potent car manufacture.
    I, for one, truly hope Ford succeeds, but remember that the other automakers won't be exactly resting on their laurels.
    I know it seems early to ask about a 2010 model, but even the Ford site says coming in Spring 2009. I figured they would try to bring this one out early to boost their sales. I've been looking for a mid-size sedan replacement for my Grand Cherokee, and the Fusion was never really on my list at first, as the 4 cyl model got the mileage of the Accord and Sonata 6 cyl's. It looks like they'll get it right with the 2010 model, though. The 4 cyl seems great, and yes I'm anxious to find out what the 6 cyl MPG rates, though the new 4 cyl seems to have adequate power by the numbers anyways. My Jeep was costing me $10 a day in gas commuting to work and back last year when the gas prices got so high. I'm glad they made these improvements as I was ready to get a 2009 Sonata, and now I'm reading alot of people are having suspension noise/problems with those...
    They are in production now in Hermosillo, but they'll need a few weeks to ramp up and start shipping. I'd expect the 2010 models to start arriving end of March, early April.
    :mad: Just read the edmunds review on the 2010 Fusion, and according to them, it now has poor steering feel thanks to electic power steering... They just HAD to screw something up, didn't they? How many MPG do you lose for hydraulic steering? (The reason I think they went with electric.) I guess you could shell out the extra $7k for the Sport version, then forget the MPG.
    If it's as bad as the Sonata, you might as well be playing a video game. Heck, I wonder if I could switch the steering wheel out for a force-feedback video game one, it would be an improvement over those things.
    Hopefully it won't be too bad, or my search will have to continue.
    Autoblog found no such problem:
    Similarly on the autocross course, the Camry proved to be an understeering slug that was extremely reluctant to change direction. Turning the steering wheel was like using an old video game wheel with no force feedback. The effort was overly light and the angle seemed to have little relationship to where the car was going. One other steering problem the Camry exhibited was a tendency to run out of steering assist during the slalom where the sequence of left-right steering inputs demanded more than the power steering pump could supply. The electric power steering on the Fusion exhibited no such issues.
