Visitor Agreement.
http://www.mpt.org/motorweek/reviews/rt2844a.shtml
Is there any way to retrofit it to an SE without spending so much money that you are better off just buying the SEL?
Get yourself the SEL for the price of the SE.
Take this car for a long test drive before you buy. The car drives great (V6) but the center arm rest is way too low and I find it uncomfortable on a drive over 20 minutes.
The position would, I think, not really depend directly on your height, but rather the seat height position you choose and the length of your arms. Of course a way to effectively adjust the height of the arm rest is to adjust the seat height.
I am 5'10" but the center rest seems to be 2" too low and 2" to far back. I drive a VW Passat also and the center arm rest is perfect. I know I will get used to it but I'm not enjoying the neck ache I get on longer drives.
I do wish they would come out with an automatic dimming side view mirror!!!
If you don't already do so, you might try adjusting side mirrors as suggested here:
http://www.smartmotorist.com/car-accessories-fuel-and-maintenance/adjusting-your- -mirrors-correctly.html
"For the driver's side mirror: Place the side of your head against the window, then adjust the mirror until the side of your vehicle comes into view. For the passenger's side mirror: While sitting in the driver's seat, lean to the right so that your head is in the car's centerline. Adjust the mirror until the side of your vehicle comes into view."
With them set for a wider view like that, I've found that, in addition to nearly eliminating the blind spots, there is much less glare from side mirrors. I don't get glare from the headlights of cars that are directly behind me, I only get it on multi-lane roads from car in the other lane and that is usually only a transient thing that happens as they pass me or I pass them.
I found this one on E-BAY,do you think it will work ?
It's only $17.99
http://cgi.ebay.com/ebaymotors/2006-2010-Mercury-Milan-Transponder-key-OEM_W0QQc- mdZViewItemQQhashZitem4838b27e1bQQitemZ310188867099QQptZMotorsQ5fCarQ5fTruckQ5fP- artsQ5fAccessories
Maybe find a locksmith, they can often make a spare transponder key for less than dealers charge.
It is winter & there is stuff in the street,looks like salt from the plow trucks.
I wash my car & the next day it is covered with dirt that looks like sand.
I never noticed this in previous winters.
Possible because i had a White car until this November when i purchased a Tuxedo Black Metallic Mercury Milan Premier
Any suggestions to keep it clean until spring when i can get a coat of wax on it.
No i don't have a garage.
Something I highly suggest from years of experience, get some Zaino and use that instead of wax, you will appreciate it after the first winter when the car cleans off nicely. Wax degrades over time and dulls the finish, and has to be removed periodically or it builds up and leave the finish looking rather blah. Zaino doesn't build up since it goes on very thin, and isn't a wax. Check it out when you have time.
I don't worry too much about keeping cars clean myself. I certainly never do any waxing and don't really even wash my car...other than the free ones the dealer gives with an oil change. But, if we get a relatively warm day in winter I will sometimes just hose it off, so it is not quite so grimy looking. If you have hard water, this may not turn out too good, though. We have a hose bib set up with softened water available, so I can just hose the car off to get rid of the major filth and be left with very minimal water spots.
When i adjust the fan speed for the heater,i get an Icon of a Fan with bars indicating the speed on the radio display.And it stays on until i turn the car off.
When i just turn on the Fan without adjusting the speed there is NO Fan icon on the display.
Is this working correctly ?
How doe's your's work ?
Check your tires.... they can make all the difference in the world. Also, a full tank of gas helps too!
Winter tires
Who woulda thought?
I just saw a couple light scratches on the door.
I tried Dupont Polishing Compound.
It didn't completely remove them.
I now have a Dulled looking area where i used the compound.
What should i do to fix this ?
Anyone know of a way to improve the 2010 Fusion's headlights?
What can i use to glue it down so it doesn't show the glue & will be easy to remove the next time the car is inspected.
Duct Tape, the worlds bet fixit! :P There is a clear 2 faced tape that may work for this, but I wouldn't use any other kind of adhesive, it may make it worse. You may want to just use a piece of clear packing tape over it instead, just cover the whole thing and leave about 1/4" tape past the edges, in fact you may be able to find some clear tape specifically made for doing something like this at an office supply store.
The owner's manual does not fit.
To big for the registration.
Not deep enough for a map.
Is it for gloves?
I think the engineers did that just to screw with us. Hey there is a little extra room here, what shall we do with it? Lets make it a cubby just to screw with the people buying it.
