Visitor Agreement.
Your answer was particularly helpful and reassuring.
In my own little brain, I had assumed I needed a hatchback or SUV form factor to be wheelchair friendly.
It wasn't until I fell in love with Ford Sync (and ruled out the EDGE because of its poor crash test results), that I really wanted to verify that assumption.
Mike
It does just fine in way more the 4 inches of snow.
The AWD can help is wet conditions, too.
It probably uses more gas than the FWD model.
If you put the wheel chair in the trunk of a Fusion, you will have to lift it out.
Not sure if this is a problem for you.
LOL! I brought the car to my house to see if my RC planes would fit! They did.
AWD is available on the SEL V6 and Sport models for $1850.
The AWD system adds about 300lbs to the car's weight, which impacts acceleration and fuel economy somewhat. The SEL V6 FWD will do 0-60mph in 7.8 seconds, while the AWD version take 8.6 seconds. Fuel economy is reduced by 2mpg for both the city and highway figures. The 2011 Fusion SEL AWD has EPA ratings of 17mpg city and 24mpg highway for a combined rating of 19mpg.
The ground clearance of both the FWD and AWD models is the same. A small oddity- the fuel capacity on AWD models is one gallon less than the FWD.
Overall, I am averaging 22 mpg.
My wife has an '09 Escape AWD with the same drive train as the current Fusion.
She also averages 22 mpg and has about 20 more horsepower.
You can also get an old ipod and use itunes to manage the music and playlists, etc.
If you have protected content (older itunes songs e.g.) you'll need an ipod or other mp3 player to play them - they won't play directly off USB unless you convert them to mp3.
Re: the CD save feature. If I put a CD in and use the "save" instruction will it save the music in mp3 format? Will artists names and song titles be decoded and recorded on the hard drive or flash memory so that I can speak the magic words and the song will come up? My CD are not new (at least five years old).
A few other questions. I presume that to use the step-by-step navigational instruction you do need a cell phone. Are minutes charged to the cell phone accoung all the time you are using the direction link?
Does the 911 alert if airbags go off require a cellphone be connected and turned on?
I'm debating getting a tracfone or other prepaid phone to have in the car? I prefer not to, but these features may justify the small cost of some of the prepaid plans.
Finally are there other synch features that can be used without a cellphone?
Thank you very much. I can't believe that Dave Matthews is taking time from his busy concert schedule to answer my questions. Thanks dmatthews3.
I'm not certain, but since it is a Microsoft system, I am guessing it is stored encrypted (and probably copy protected) on the internal hard drive as the WMA format.
The nav system does not use the cell phone, it is all satellite and internal storage for POIs, like a handheld Garmin or TomTom.
The 911 alert does require a cellphone to be paired with the system in order to work. The car has no built-in cell service.
-Brian
Now for clairification we have the Nav setup in our Fusion Hybrid so speaking for it when you put in the CD it saves the music to the hard drive if you tell it to. Doesn't put it in mp3 format as you can NOT save mp3 to the HD thats why I believe they also have it set up so you can put your mp3's on the flash drive and plug it into the usb port. On a lot of my CD's I saved it did also have the names and song titles also like mp3's do but not for all my songs as some of them are older CD's of just Greatest hits by many singers but on all the CD's from name brand companies it did. Don't know how it does this so I'll leave that for someone else. The sync seems to be quite smart so it would benifit you to take some time and sit down and learn, figure out, experment or whatever it takes to learn it. Good luck, got to go, as I go on stage in just a few minutes :-) :shades:
Finally how does the call to 911 work. if you deploy airbags and don't hit abort switch within a prespecified short interval a call goes out to 911 and gives your location. Will this work if your cell phone is turned off. Does sych have the smarts to turn it on somehow. How is the location determined (GPS-phone) (GPS-car??) (other?).
Thank you. This forum is very helpful on this subject and, even though I am quite dull, it will likely help others with Milans or Fusions, or any one with "sync" who didn't have time to ask and couldn't find it in manual.
i had never used it before, but found out it basically measures how long the engine has been running, like a lot of commercial/industrial machines.
this weekend 1630 miles/26.5 hours. 58.5 mph average.
Boz
Check out Tirerack.com. I've found some excellent tires on that site for half the price. In fact, instead of dropping $200 per tire on OEM Michelins for my previous Mazda6 (Tirerack's price, it would've been even more locally), I spent $110 per tire on a set of Yokohama's. Wet and dry traction was vastly superior to the Michelins. The ride was smoother and quieter, and cutting apexes was an absolute joy, without the incessant squealing the Michelins made all the time. They actually lasted about 5K miles MORE than the Michelins, and still had plenty of tread when I sold the car.
Sorry, but OEM replacement tires are simply a rip-off on most vehicles.
Yes the prices are good, provided you are buying the wheels too.
Also at $142 there is the Continental ExtremeContact DWS at $142. This tire is highly rated by both tire rack and CR.
Besides the Dunlops mentioned above, I'd add the Yokohama Avids and Continental Extremecontact DWS as two excellent choices for a lower price.
Let me also recommend shopping around at different tire stores as well. There are local tire shops that will MATCH Tireracks prices per tire (including the shop I've done business with for a decade now...), plus they only charge $9.95 per tire to mount/balance them as well. They also honor the warranties since you purchased them from the tire shop.
Again, when it's all said and done, spending $200-250 per tire with everything included is simply insane.
I have always had excellent results with Cooper, never had any experience with the other brands, and I tend to stick with what I know.
I checked around, the Continentals, installed, $871.
All the local stores that would mount YOUR tires that you brought in and did not purchase from will charge minimum $45 per tire, to mount and balance, and that does not include the TPMS hardware if needed. If they have to replace the valve stem they have to rebuild the TPMS, and that is an additional $13 per wheel.
No matter what you do, these tires are going to cost up to $200 per wheel once all is said and done.
I kind of miss my wife's 1984 Tercel's cabin controls. Easy to operate and find, and you turned on the compressor yourself if you wanted it.
Oh, and I don't know about the auto temp controls since I don't have one. Never had one on any vehicle I owned. I assume it would be similar, being automatic.
I'd thought that the figure of $250 was given and I had assumed that was referring to just the cost of the tire. But if you had a more normal size tire on the Fusion, like the 17 inchers, it looks you'd only be paying about $20 or so less per tire for the same model tires.
I paid $80 to have my snow tires mounted on rims and balanced. That was comparable (and even less expensive) than the quote I received from Belle Tire and Discount Tire locally. The killer for me was neither place had the tire in stock and both wanted to charge shipping to get that tire.
Second, if you have a warranty issue, you wont get any service from a local tire dealer, nor the place that mounted then for you. You have to deal with Tirerack.
That isn't the case either. The warranty on a tire is good at any authorized reseller (allowing they were purchased from an authorized reseller).
Ordering from TireRack, including mounting, balancing, and shipping, was $125-150 (not including the local places *shipping* charge) less than buying 4 Dunlop SP WinterSport 3D tires locally. And the place that did the mounting and balancing washed and vacuumed the car for free.
I used to deal with tires for years, sold Coopers, and we would warranty a Cooper sold by someone else, but the customer still paid for mounting and balancing, but a customer who bought the tire from us and we installed them, would get full warranty, which included mounting and balancing. If someone brought in tires for us to mount and balance, we would, but they would be on their own for warranty, since we would not warranty them.
I guess what I'm saying is if the tire dealer who is doing the mounting and balancing does not deal with the brand of tire that you purchased, you wont get warranty work from them, so buyer beware on the tire brand.
That's also not true. I bought Yokos through the local Gemini tire shop (which sells Goodyear, Dunlop, and Kelly), in which they got through Tirerack (and matched their price), and two weeks later, a sidewall blew on one of them due to a piece of construction debris. The tire shop replaced it under their treadwear/road hazard warranty, no cost.
Not for nothing, but it seems the local tire shops around you just don't give a @#$% about customer service.
My understanding is tire manufacturer warranty does not cover mounting and balancing, I'm not aware of any shops that throw that in...so never considered that as a possibility.
That said, for a number of reasons, I'd not do things the way my kid did, I strongly prefer to just get my tires from an independent shop about a mile from my house. With mounting, balancing, and delivery considered he costs about the same as using tire rack and I trust him to take care of me if there is a problem. (My kid may have done the same had he known, we only discovered what a bargain the local guy was on tires after his tirerack/walmart gambit)
Yeah, I had "that guy" back home in Cali. He would beat deals, get me the tires I wanted, etc. I also had a suspension guy I liked. In SE MI I can't find a decent independent that carries any brands. Even "local" regional chains didn't seem to interested. I could have had Tire Rack drop ship the tires but had them come to my place instead. I really like supporting local businesses when I can, but I couldn't bring myself to pay a $150 extra for no better service. If you can't compete on price/service then you need to change your business model. Oh and I ordered the tires on Wed night and they were delivered Friday morning.
To combat theft, I don't leave anything in worth stealing.
Good luck filing an insurance claim when the police report says 'no signs of forced entry'.
I really like the Fusion, but this is one feature I would not want to use.
What you probably don't know about it, since you are so against it is, you can program a second code into it, and use that for gaining access, and change it randomly. That is exactly what I do, change it every so often, especially if I used it where people were watching. It takes all of 30 seconds to change the code.
"Chacqu'un a son gout."
