The Quad 4
well i found a car the other day good shape what i am looking for. 94 grand am GT good shape 96k on it. but when i popped the hood i noticed the Quad 4 engine in there which i know has a reputation for blowing head gaskets. which is what will happen when you try to make a high output 4 cylinder engine with some [non-permissible content removed] mechanics behind it. my question is if i get the head gaskets replaced will they last for very long or what would be the cost of finding a 4 cylinder twin cam or a DOHC and putting that in.
But you are correct that these tend to destroy head gaskets at a higher rate than do today's engines.
I'd expect a head gasket change to cost $300-$600 depending on any machining needed.
Bottom line, if you like the car, buy it and know that all cars break something, so you might as well drive something you like.
At least you won't be spending that same money on timing belts, the Quad 4 is a timing chain engine.
TB
From '96 until the end (it was ultimately replaced by the Ecotech) it had 150 hp. I had a '99 Alero rental car with that engine for a day once...that was a sweet little car!
My ex-wife had a head gasket go on an '88 LeBaron turbo. Same basic problem...aluminum head, iron block, and different expansion rates. When this one went though, it needed a new head, as the old one got warped too badly. I think it cost her about $750 for a new gasket and a used head. Then it was another $75 for my mechanic to put all the wiring, hoses, vacuum lines, etc on top of the engine back together the RIGHT way! >:-(
It wasn't too many years ago when 96,000 miles without an engine overhaul was unheard of!
My point was...today's cars are pretty reliable compared to what they used to be.
It's one thing for a head gasket to blow, and only have to pay a few hundred bucks, or even $700 or so. That's no big deal. But when you start getting into the thousands or, worse, needing a whole new engine, then we have a problem! A guy at work recently had the head gasket in his '98 Windstall blow. Took out the whole engine, and it was something like $5,000 to replace!
Just my experience and $.02 - I agree with everyone else. If you buy something with that many miles on it, don't pay much, because most likely you will have some problems with it.
http://www.babcox.com/editorial/ar/ar40032.htm
