I'm curious ot hear from other TSX owners about this.
The issue with octane is that high octane gas burns later than low octane gas. Low octane gas is no less "powerful" or less clean, it just burns earlier. Now, in a high compression engine like the TSX, you want it to burn late. In a lower compression engine, you want early burning (like in an Accord). Hence, the TSX likes the higher octane gas. The Accord 2.4, in contrast, will not benifit at all from Premium and may even run worse.
In the old days, if you used too low an octane, you got engine "pings" that could cause damage. That won't happen in the TSX, because the engine has a knock sensor. If you use a lower grade gas, the TSX will adjust itself to prevent pinging. So, there is no risk to using lower octane and your engine should be fine.
Here is the problem though: in order to get maximum performance, you need premium. Otherwise, the knock sensor will intervene to prevent pinging. The result will be about a 15% loss in power.
Personally, I've experimented with regular, medium grade, and premium. I did notice a big difference when I went from Premium to regular. I didn't notice any difference when I went from Premium to medium. Under the right conditions, however, I imagine that regular might work fine.
Right now, I'm running Premium. It isn't that much more expensive and I want to maximize performance. But, I feel confident that Medium grade would work OK too, and regular would probably be fine in a pinch.
Practically, with the K24 engine, none of this matters much. Hondas don't really need an extensive break-in and I think you'll be OK whatever you do.
I just bought a TSX and live in a state that requires a front license plate. I also occasionally park the car on the street. I'm looking for a heavy duty and deep front license plate holder so that if someone backs into the car they hit the plate before the actual bumper. Anyone know where I could get one?
i'm just curious if the site is as good as it looks. are people using it? what works, what doesn't?
signed,
jealous in toronto
Cost of the car (35000km) in terms of expenses beyond gas, oil is: $0. Previously had a 99 Accord - also a pretty trouble-free car (1 light bulb).
Truly a wonderful vehicle.
Can anyone give me the lowdown on this? I was afraid of snapping the rivets and ending up with a rattle after putting it back on. I hate to pay the dealer to do this, as I've always done all my own oil changes.
Thanks for any advice here...
Read this about the myth:
http://www.stoptech.com/tech_info/wp_warped_brakedisk.shtml
I have a 2008 Acura TSX 6MT that we purchased in July 2010 as a certified used vehicle with 9000 miles. The car is now 3 years old but only has ~20k miles. I am taking it in on Friday for an oil change and tire rotation and the dealer is saying that there are things that should be changed/replaced due to age, regardless of mileage. The list they gave me is:
Transmission fluid (every 30,000 miles/3 years): $89.95
Engine Coolant (every 45,000 miles/3 years): $69.95
Hydraulic Brake Fluid (every 3 years, independent of mileage): $109.99
Engine Air Filter (every 15,000 miles/3 years): $49.95
A/C-Pollen Air Filter (every 30,000 miles/3 years): $89.95
Since my wife drives it 15 miles every workday in stop-and-go traffic, in Texas heat, I am ok with the transmission fluid change and engine air filter and maybe the engine coolant change. I think the other stuff can wait till at least the winter or even spring. Of course these dealer prices are $$$ but I knew that when getting this car, so we will deal with it.
Any advice and/or thoughts on low-mileage maintenance? I think from here on out we will be on a 12k-15k / year mileage schedule, but the previous owner hardly drove the car at all. I do not yet have the previous maintenance records from the dealership for the previous owner's time with the car.
Michael
Question was really concerning the idea of "time-specific" maintenance versus "wear-specific" maintenance. Do parts/fluids wear out over time, without use, or not?
From what I was told transmission fluid change is not at 30,000 miles-more like 100,000+ or in your case by years (do not know exactly)
I do know the brake fluid should be changed at 3 years no matter the mileage. I had that done not to long after my car turned 3 years old (over 90,000 miles. I also had the manual transmission fluid changed.
At 110,000 miles I had the spark plugs changed and also the coolant
I have both filters changed at the same time which is about 30,000 miles. I do mostly highway driving. I own a 06 6MT tsx, bought new 11/17/06. It has almost 126,000 miles. Love it. excellent car.
