Acura TSX Maintenance and Repair
Have you experienced any problems with your TSX? Please share any solutions here!
Honda's paint quality is less than average. It has been my experience that Honda products scratch and chip very easily, especially with the TSX's hood.
If the rust occurs where the paint is chipped, I really don't think Acura is going to help you.
What color is your TSX? Because it seems like the Carbon is particularly susceptible
wgn4snow: What trim level Forester did you compare. The 2.5X, 2.5XS or the new 2.5XT. I would think you would need to get the 2.5XT to get a good stereo. It's the only one with an additional 120 watts and a subwoofer. The 2.5X and 2.5XS apparently comes with really cheap speakers. But the brochure offer upgraded features as an accessory for those models. I would expect that a 2.5XS with upgraded speakers would have less power than the TSX system, but might sound better.
By the way, from what I understand, the Forester 2.5XT will smoke a TSX from 0-60 and a quarter mile. (I still don't think it will handle nearly as well as the TSX.)
Let us know if you have more impressions on the TSX and the stereo if you decide to buy.
The main beef with the Subaru was the back seat and the roughness of the engine when compared to the Acura's inline 4. There was noticeable engine noise in the cabin with the Forester, even at moderate highway speeds. Also the rpms at moderate highway speeds were much higher (3100 rpm at 70mph cruise in the Subaru vs. 2200 rpm in the Acura (same speed/same road).
As to the TSX's speakers, I should clarify that I was looking for the vibration, hence the Rite of Spring selection (not may favourite piece). It goes from very quiet to VERY loud very quickly. In general the sound system sounded fine.
The only "performance" complaint for the TSX is the turning circle, which is a bit large. That however is countered by its very precise steering at highway speeds.
Having eliminated the Subaru, I will look at the CRV again (just to be sure). If the local Honda dealer is discounting end of year EX's there may be a substantial price difference between the TSX and the CRV.
The Forester has Impreza running gear with a mini-SUV body, the lower cost of the two-level Subaru line. The only logical Subaru to try to compare with the TSX is the Legacy GT sedan. Even those are not directly comparable, but an infinitely closer match than the Forester.
blane: True, comparing a TSX to a Forester is unconventional. But there are many post throughout these discussions from people who don't know what kind of car they want. If you must have a sports car, than you can eliminate all other types of cars and just look at cars in that class. But if you are looking for a vehicle that is fun to drive, takes your mind of work when you drive home, has room for the family, is extremely reliable and comes with everything you want stock, your choices will span several classes. I am not sure how adviseable it is to tell someone not to consider a vehicle just because it isn't in the class of vehicle they were considering in the first place. If that had been the case, I never would have looked further than the Honda Odyssey minivan when buying a primary vehicle for my family. As it was, I ended up with a luxury SUV - the Acura MDX.
One issue with HID headlights that I've noticed recently: when you are waiting to make a left and an HID-equipped car approaches from the opposite direction and goes over 2 (or more) small bumps, the very narrow headlamp beam makes it look as if the driver is flashing his headlights at you (i.e. "go ahead"). Now I will wait until an HID car is approaching so slowly that I am certain he/she is letting me go. If you have HIDs, please be aware of this, ...and be careful out there. :-)
It is the result of having the now heavy mirrors on the end of a long, resonant arm. Perhaps you have noticed that some cars have a rubber thingie that goes between the mirror arm and the windshield to add stability. If this really bothers you, perhaps you can make or find one.
Problems so far
1. leather color seems to be literally wiping off, the front seats are starting to have 2 shades of beige color.
2. AC water drain hose was not connected properly, resulted in a massive water leak that spanned the front passenger and rear passenger areas.
3. Front rotors already started showing scoring marks.
4. The alloy wheels get filthy the same day after you wash the car. Too much black brake dust.
5. Wood trim on steering wheel has started popping up(peeling) from the window side.
6. car has 3000 miles on it. Checked oil level, about a centimeter down from the full mark, and it is already dark color.
Anyone having similar problems?
At least you can listen to that 360-watt, 8-speaker premium sound system that delivers high-fidelity, full-range sound. According to Acura it sets a new standard for "luxury". I'll bet when you're listening to that great sound system, it is easy to forget about all the other problems with the vehicle.
It has not been in for the first service yet, I will see if they honor their warranty. When I showed it to the mechanic fixing the draining hose he dismissed it as normal, whatever that means.
Other than that, it is quite a delight to drive
Ignition: I have experienced this on a few occasions now where it takes a while to start the car unless you turn the ignition key, keep it in the on position until the fuel level guage is activated, and then you crank it. It then starts fairly quickly. Is this a problem, or do you think it is a feature of the ULEV technology where all gas fumes are recycled back, so it takes a while to get some gas transfered by the fuel pump back into the engine?
Those "no defect" cars of the past on which the japanese built their well earned reputation for superior reliability tended to be standardized cars with few options, while Detroit was plagued by quality issues made worse by allowing extensive customization of options.
The Japanese deserve much credit for adding the complex options, power and handling to their cars, while keeping the selling prices reasonable and maintaining reasonable but not perfect reliability. The inevietable trade offs cause us to complain, because everyone wants to buy a perfect car, but after the griping is over most repeat buyers conclude that for all of their imperfections, cars like the tsx are still better than most Detroit offerings. So relatively speaking the reliability and refinement is excellent to superior considering the cost and content compared to past offering and current competition.
Please let me know
I don't know what can be done, especially since the new mirrors are heavier due to internal electronics, and the speakers are better with stronger bass.
Maybe you can finagle some damping foam behind the mirror to make it more stable?
Also, should I stick to the recommended premium unleaded fuel?
I suggest you read the section in the manual about break in before leaving the dealer.
We had our first service(free of charge) and Acura has corrected the off centre steering, and they ordered a new steering wheel to fix the peeling wood trim issue. They however ignored the following problems as being "Normal"
1. Rotors already showing scoring marks(circular grooves). Vibration in steering when applying the brakes from a speed over 40mph.
2. Leather color fading
3. vibrating rear view mirror due to loud stereo.
Second basic question: Are your tires inflated properly?
You might see relatively weak fuel economy when the car is breaking in, but you should certainly see better than SUV MPG.
Your Pathfinder had a 21.1g tank and its fuel gauge drops somewhat linearly from Full to 1/2, but moves slightly faster in the bottom 1/2, and the low fuel light glows brightly with about 3-4 gallons left. (You get slightly fewer miles in the bottom "1/2" of the tank than in the top "1/2".
Conversely, the TSX has only a 17.1g tank and its fuel gauge drops very quickly in the first few dozen miles. The TSX fuel light also glows ridiculously early.
Depending on your driving style, you should be able to get at least in the neighborhood of 350 miles from your TSX before the needle points to the red line at "E".
In my Solara, I tried several tanks of each, and found running regular cost me about 15-20% in gas mileage, so it was actually cheaper to run high octane gas, and I got more power as well.
I hope that your problem is this simple.
Yet you said you fill up every week and go 275 miles per tank.
How are the other 155 miles being driven? Short trips? Highway?
Regular or Premium Gas?
Calculate your real MPG. Take the 275 miles per tank you get and divide by the number of gallons you fill up with.
Mileage should get better as you get closer to 10,000 miles (typical of all Honda/Acura products).
Jerk when accelerating from a STOP????? What do you mean? Maybe you just aren't used to the throttle input on this car compared to the Pathfinder.
Although the car accelerates great when I'm moving (anywhere from 15 to 50mph), I've found that it takes a moment (less than a second but more than a millisecond) for the acceleration to kick in from a dead stop. It almost feels like the car is waiting for turbo to kick in, but I know it doesn't have turbo. Is this normal? Does it have to do with the 4 cylinder VTEC engine?
TrickyDick
The VTEC doens't kick in until high RPMs, so that is probably not what you are feeling.
The "launch" of the TSX seems a bit problematic. I think that part of the issue might be the heavy wheels and all-season tires. I suspect that adding stickier tires would actually move the car off the line a lot quicker.
TrickyDick
And, don't forget, you are not dealing with just VTEC - this is an i-Vtec system. Hence, the flat torque curve.
The rev limiter kicks in at 7,500...
Be very careful, at this point, to document everything that happens with the repairs. With a major problem like this, you should keep your eyes on the lemon laws for your state.
Yes, you'll see improvement as the car loosens up. That is the typical Honda/Acura pattern.
I am considering the 2004 TSX for my next car and would like to know if the 2004 TSXs have address the known problems of the 2003s:
-Buzzing of the speaker insulation due to high bass.
-Vibrate happy review mirror.
-Easily discolored leather seats.
Did I miss anything else?
I've not heard anything about easily discolored leather seats, but the rear view mirror does vibrate, primarily at high bass levels.
A fix for rattling door panels is reportedly under investigation.
Mirror vibrating: It happens all the time and it happened in both of my last two Honda cars (I had two Accords before my TSX). Occurs mostly when I blast the music. I couldn't care less and see it as a non-issue.
Discoloration in seats - I've had no problem whatsoever in my quartz interior, and I've not heard this one before. However, the TSX, like most cars built in Japan, does not have dyed leather. The color is painted on. So, if you snag the seat with a metal button or something it is theoretically possible to wear some of the color off. But, I haven't had so much as a hint of a problem with the leather in my car. It seems pretty high quality.
I was just hoping to find the TSX to be better built so I can ditch my Mazda6 (good design but poorly built).
I think I'll wait for the 2005 model TSX to alliviate some of the stresses I have experienced with my first year Mazda6.
