Has this happened to anyone else? Do you know if this is common and/or a problem Acura is aware of? Any insights are greatly appreciated!
Tricky Dick
I've had my TSX for about 1 month and twice today, while driving it home for work, the engine totally cut-off, once while I was slowing down to a stop and once when I was going around 30-40 mph on a suburban road. This happened once before the first week I had the car when I was backing out of a friend's driveway, but I didn't think much of that incident until now. I had to put the car in neutral while the car was moving and turn the ignition to re-start the car. The only indicator I remember is the "key" symbol on the dash panel.
Tricky Dick
Later...AH
Are you dividing miles driven by # of gallons put in at the pump? I know this sounds silly but if you assume you are putting in a full tank(17.1 gallons) at each fillup your math will be way off. I find the low fuel light comes on when I have used 12-13 gallons and the most I have ever put in was 14.5 gallons. I had to drive around for 60 miles with the low fuel light on to go this far and my wife was getting really nervous.
I know what you mean about feeling a decelerative force when you let off the gas. Mine does this even when I push in the clutch and coast. I think perhaps the tires have a high rolling resistance. I am always checking to see if I left the parking brake on.
I regularly delve into the 4000-5000 rpm range, and occasionally get into the VTEC range of 6000-7100.
Don't wait for Acura's "fix" for the door buzz. Our dealer resolved with careful diagnosis and several disassemblies. Our buzz was in the locking mechanism, and was easily resolved once it was isolated.
The issue of side moldings was a big one for me, as well. The problem is, Honda and other manufacturers are clearly moving away from moldings in many car models. In some cases, the moldings that remain are virtually useless as protective devices, but clearly styling items only. Final decision for me was considering how much protection the new Accord 4 door's moldings are likely to provide in the real world - virtually none, except from another new Accord! Believe Acura offers side moldings as add-on if you must have them.
After a couple weeks, I called Acura myself and gave a good report about Pohanka.
If you look at the archived discussions in that forum, you should find it. I just checked there myself, and found it.
They didn't give us a good deal. We got it on our own by offering a fixed OTD price and walking out when it was not accepted. The sales manager came out to the parking lot to say they would accept our offer. It only took about 10 minutes from the time we made our written offer to the time they said they would accept it.
I would definitely go back there to buy a car. They were very friendly. However, like all successful dealers, they won't just give you a good price. Like E. F. Hutton, you have to earn it by being an informed buyer. Good luck.
Bob
Appointment scheduled next week for windshield creaking, loose drivers seat, erratic door chime when door is unlocked from outside (no key in ignition or lights on), now the phantom turn signal. Four new Hondas were never this way!!
That begs the question: is this a problem? Clearly it's a minor glitch to me, but my 2000 Accord never did it, and both cars have similar security/keyless entry systems.
Did you do anything about it on your Accord?
Johnny
Winter fuel mixtures do decrease MPG as does the cold temp. Further your driving style, traffic, et al all affect final numbers. Lastly, the EPA estimates are under optimum conditions. Give it some time and good luck.
Since then I've only averaged about 22.5 mpg @ 40% freeway, 60% city driving. To be perfectly fair, I've been driving the car pretty hard, constantly seeking out twisty roads.
I have a lot of trouble keeping my foot out of the throttle with this car. That said, I'm a little disappointed with the fuel economy.
I'm hopeful things will improve with spring fuel and as the engine breaks in. BTW, mine is the 6 sp MT version.
Johnny
I've only had the VSA system kick in a couple of times, usually on start off. It works like it should.
In ice, I think any car has to be drivien carefully, but FWD is always an advantage.
Johnny
Also, a creak on the passenger side of the console (basically where your left leg would be if you were sitting in the pass seat). You can hear a creak / pop upon giving it gas or braking. It creaks and then stops, I almost think it is the plastic just rubbing against itself, although there is a slight bulge in one spot where the plastic meets the carpet so that may be causing it.
Finally, I noticed that the car pulls a tad to the left sometimes but I have yet to take it to a parking lot or something where I can test it to make sure it isn't just an uneven road. I know this is a problem that occurs often and there is actually a nhsta note on it for the TSX.
I only have 300 miles so I am a bit paranoid but I can understand how there can be small glitches and hopefully I can have them look at it this weekend.
By the way, my car also pulls to the right upon stopping and starting. I heard the TL is having the same type of problem.
I love the look and feel of the Acura, but I think the one that I got has serious problems and is unreliable.
see NHTSA item # 10003102
SERVICE BULLETIN # 080103
[url]http://www-odi.nhtsa.dot.gov
This is how they faired on the warranty work:
Trunk Valet lock - They were able to unlock it but suggested I not lock it back. I need to come back because they have to order the part.
Wheel alignment - they said the tire pressure was off 40 lbs psi. They set it to 32psi. Funny, I set it to 32psi the day before as suggested by forum members but it really is the alignment. I drive home with the alignment still off.
Windshield Creak - They said it was the sunglass holder and nothing they can do about it. They must really think I'm so stupid to not be able to isolate where the creaks are coming from.
The part that blew my top off was the complimentary car wash. I specifically told the rep that I do not want them to wash my car. I am anal about my TSX and take my time detailing and washing with just a sponge. The car before today had no swirl marks or scratches whatsover. It looked brand new. Now after the car wash although clean, when gleaming under the sun, I see brush marks across the front door, back door and the roof. I also found 2 brush scratches on the trunk.
So what can I do now? I feel they've ruined my brand new car. Ugh... I feel my car was so violated.
As for the winshield creak, there have been some posts on tsx specific sites that it may have something to do with Y clips holding in the side gutters that run vertical along the winshield and the channel that runs horizontally across the bottom. Try applying pressure to all of these to make sure all of the clips are in place.
I just called the Service Manager and as expected, she can't do anything but to say take it in and we'll look at it. This whole thing is giving me a headache.
best,
jw
jw
i'm also debating when to get a small dent fixed that some [non-permissible content removed] made just a week after i got my car.
jw
The outside tmep gauge can be adjusted by holding the reset button & turning key to the II position (not start). Watch the temp guage countdown -3, -2, -1, 0, 1, 2, 3. If temp is too high (as in your case), say 3 degrees, then stop temp countdown on minus 3. If it is measuring too low, say 2 degrees, then stop countdown on 2.
jw
Anyone else? suggestions?
1) Stereo causes a slight vibration at the top of the driver's door at medium to high volumes.. is this just the stereo? I understand it is a relatively powerful stereo and I may just have to deal with it:) however this isn't the complaint that people have had about the car in the past about door rattle is it?
2) my car seems to be pulling to the left on certain roads. Although not consistent it does favor the left. and I do have the correct tire pressure. Should I have this checked out??
I thought my car was drifting too, but many highways are pitched just a bit to the sides for drainage purposes.
However they also said they would just align the car, to silence any concerns I have (I have been very impressed with my dealership)
I would suggest not waiting for your first service to have the car aligned unless you don't mind paying for it. Alignment is considered "maintenance" and not covered under the 4 year 50K warranty. If you just got the car and you are conserned about the alignment the maybe call now and work out what they want to do.
ALSO the vibration I mentioned in an earlier post isn't really a squeaking it is more of a vibration.. BUT I do have the stereo up pretty loud so it may just be the noise resonating in the car. In that case the solution is to turn the music down or wait until something other then the base guitar kicks in.
Also how many people out there live in a state that have front plates as a law? I really wish our tax dollars were spent in other places. TSX looks better without the plates. and I really don't like the braket against the bumper!
