Labor hourly rate guide, anyone have one?
I had alot of maintence done by a shop and was wondering if anyone had a labor hourly rate guide for the following maintence procedures.
New spark plug wires
Transmission service (drop pan) and transmission service kit for a slow leak around the pan bolts
Valve cover gasket
PCV valve
Upper and lower radiator hoses replaced
Antifreeze flushed and filled
Valve cover gasket
PCV valve
92 mitsubishi Mirage 1.5 Liter SOHC
Timing belt
Water pump
Camshaft seals and any seals that should be replaced
tensioner
The serpentine belts (I think they are V ribbed-3 small belts)that are squealing pretty bad when the a/c is on or is very cold outside. Some are cracked when I took a look at them.
I inquired from the same shop said it would "take all day". When I asked how many labor hours, they stated over the phone they wouldn't know until they looked at it. any info is appreciated.
.5 for spark plugs, no time given for wires
.8 transaxle filter replace
.7 valve cover gasket
PCV valve, no charge if performing other repairs, otherwise .3
.7 cooling system flush
.9 both rad hoses
So, 3.6 hours but some services may overlap.
1992 Mitsubishi Mirage
(89-92)
1.5L eng.... 2.4
Additional time:
.2 where Air Cond interferes
.3 where Pwr Steer interferes
Combinations:
.1 Sprocket, camshaft R&R
.3 Sprocket, crankshaft R&R.
.1 Sprocket, balance shaft (each) R&R
.2 Seal, camshaft front
Tensioner (each) R&R
.1 camshaft belt
.1 balance shaft belt/chain
.1 Guide, balance shaft chain (each)
.2 Seal, balance shaft (each)
With changing everything remotely associated the maximum flat rate time is 4.1 hours
If they came with a good recommendation from a co-worker and you're happy with the work they've done so far, stick with them. Remember, it isn't always about total dollars spent but whether value is received for dollars spent.
