Buick LaCrosse
The front end on the LaCrosse could use a little beefing up so I am all for it.
If you have a specific question about the LaCrosse, feel free to post it here. Welcome and good luck!
the engine is the series III which includes enhancments to make it quieter in the Buicks. It has a new aluminum structural oil pan which stiffens up the block for less frequency responses.
Still, for the money, I'd take a base Allure over a 4 banger Camry any day. Now if GM would just fix up the front end of the car a little..
CXS is the top of the line with a 240hp 3.6L.
Gordon
I was also getting inaccurate external temperature readings until the engine compartment warmed up
The problem may have been poor routing of the sensor wires which allowed them/sensor to get moisture contamination.
When the dealer ordered a new sensor, they ordered one with a new bracket. The new bracket is a much better mounting arrangement with the wires somewhat protected from water. I think the 2006 models have the new bracket but I do not know if it was a running modification during the 2005 model run,
Gordon
Maybe true but nothing official has been announced yet. I doubt it will have any effect on Lucerne sales. too much difference in size. Question is what will happen to the 3.6L. The V8 is cheap compared to the 3.6 but does not have the refinement of the 3.6L. Sad to say but unless they drop the price of the 3.6 model it will die. My opinion is to make the 3.6L standard in '08, raise the base price $1500 with the engine and required stuff (upgraded tranny, suspension, exhaust, etc.) Let the 3800 die then. Put the 3.6L as standard in the LuCerne also. Of course the financial thing to do is use the cheaper, but less refined, 3.9 in both as standard.
A really important thing is, to improve interrior volume. This car, along with the impala needs a new platform, or at least more competetive interrior space.
Portholes anyone? A v8 would be redundant.
Yep, new platforms are needed for the LaCrosse and Lucerne. Next model LaCrosse, if their is one, will be on something else.
Greg
Therefore, GM can put crazy stuff into a car like... leather! and wood! it looks real! and a hood ornament! must be people over there won't tear it off!
ok enough sarcasm. The point is, that is they make it for sale here it would have to be made in china or korea. Well, it could be made here, but either in a non-union southern plant (think honda and toyota) or with many compromises and sacrifices.
Still, I wish them well. They carry the flag with them in many ways.
Accelerator pedal has to be held down all the time, even going downhill. My old 1990 Olds has the V6 ancestor of the same engine and will drift down a sloping offramp with my foot completely off the accelerator.
Is that a function of drive by wire or what? I felt like I was forcing the LaCrosse all the time. Even checked to be sure the parking brake wasn't on.
Very strange. Going home, my old car felt like a hotrod compared to the LaCrosse.
In order to get stabilitrack, you have to get the top model with standard sunroof.
I guess that Buick thinks that tall people don't need stability control.
I am genuinely puzzled by this.
Same problem when I tried LaCrosse several months ago. Parking brake wasn't on. Salesman had no ideas.
Must be something about the accelerator spring. Does the car have drive by wire? That's probably it.
Felt like I was forcing the car all the time.
Most newer Japanese cars have stability control standard or as an option on all trim levels. Car and Driver, Consumer Reports, IIHS, and government think that it is useful for anyone.
Weird.
Same with side curtain airbags. Ford getting a terrible black eye on Fusion crash tests because curtain airbags are not standard. They have announced that they will be standard for 2007. What did they expect?
I just checked Corolla-I didn't find Stability control there. Did I overlook it?
I didn't find it on the 4-dr Accord. They have electronic brake force distribution-whatever that is.
Asian companies think that stability control is for everyone
Camry - optional on all models
Accord - standard on higher trim level
Acura - standard on all models
Hyundai Sonata - standard
US companies think that stability control is only for SUVs and sport models
Ford 500/Montego - not available
Ford Fusion/Milan/Zephyr - not available
Cad CTS - not available
For instance the current old CTS will not get it but its 2008 replacement will. The new Camry does have it available on all models but not standard. On Accord it is not available on all models just like GM.
This feature is in transition. It is expensive. Older cars will not get it because of the develoopment costs. More expensive vehicles will get it as they come out as new. GM trucks all have it because it is a safety feature much needed on top heavy trucks. All manufacturers are phasing it in.
This is a LaCrosse forum. the LaCrosse came out 2 years ago. At that time few cars below $28,000 had stability control as even an option.
I checked some Japanese cars.
>Is Corolla a competitor to the LaCrosse?
Nothing was said about only competitor cars for LaCrosse.
It's BA, not A-B
Brake Assist, known as BA, is another electronic braking system and is often partnered with EBD.
BA monitors a driver's braking and if it detects that a driver is in an emergency braking maneuver, it automatically supplements the driver's attempt to stop quickly by boosting brake power to the maximum. BA stops working immediately after the driver lifts up on the brake pedal.
Unlike ABS, BA can help improve vehicle stopping distances. Research has shown the system even helps pro drivers stop more effectively.
this is what I meant.
Stabilitrak is available on the CTS and standard on some models. Where are you getting your info from?
The owner of the dealership where I purchase my cars has driven a V8 version, with displacement on demand, and is impressed.
Just got a new allure last week. Very happy with the car... except:
I'm noticing that the odometer is giving me some "funny readings"... basically numbers that don't make much sense (but are not too far off), and sometimes displays digits that aren't even numbers. The trip setting seems to give realistic readings though, just the odo is off. And, no I'm not being confused between imperial/metric.
I'll probably take it to the dealer to look at this weekend, but was wondering if anyone here has heard of similar problems on this model, or could give some advice. Nothing like ghost electrical problems on a brand new car!
if anyone's interested, sample readings (in km):
odo: 318, 397, 387, 494
trip: 0, 19, 69, 125
if the initial 318 on the odo was right when I set the trip, the rest of the readings should be: 337, 387, 443.. only the 387 matches up...
