Buick LaCrosse
I did have a problem with the serpentine belt squealing. The dealer fixed it (replaced the belt), said that there was a service bulleting.
I have noticed this problem on the following cars I have owned:
1982 Century - moderate.
1983 Century - severe.
1998 Regal - moderate.
2000 Regal - none.
2003 Regal - moderate.
2005 Allure - mild.
The last time I checked there was not an easy way to adjust the bearings other than to remove the rack and pinion and tighten the retaining nut on the bench.
Gord.
Norm
Gord.
It's important to drain and fill the fluid often, about every 50k miles if you want the tranny to last long. Synthetic is nice and I feel it is worth it, but I wouldn't switch to synthetic and then "forget about it".
So far so good, but it has only 56k miles. The ATF was changed at 32k or 33k miles.
Dealer technician overfilled it about 1.25 inch above the top mark, and I noticed it only two years later. The ATF was bubbling a bit, but did not degrade. I believe that a standard ATF would degrade.
That's is to say, it is not very responsive to the gas pedal. I hit the gas pedal and feel it takes a while to move, although it is very short, I can still feel it. This is the similar feeling as in the old Volvo S70 or '07 Passat. But Chevy Impala and many other midsize sedans including Fusion, Aura, Altima, Camry, Mazda and Honda are not like that. Is Buick intentionally designed to be like this? I have been seriously considering a Lacrosse but this 'problem' might make me walk away from it. Thanks for any inputs!
that's probably why. I test-drove a Lacrosse CXL today
and got the same feeling. I probably should have tried
a CXS.
Front Side Rollover
2005 5/5 3/3 4
2006 5/5 unrated 4
2007 5/5 1/3 4
Makes on wonder why the different results arose in the 2005 and 2007 models and why NHTSA didn't do side tests on 2006 model. Also would like to know if GM changed the design specs for the sides of the passenger compartment of the LaCrosse between 2005 and 2007.
However for '07 they added side air bags to the seats (not available before) so they had to retest. Testing is awful unpredictable and strange results can happen. They added seat mounted airbags (on top of the already standard curtain air bags) and the rating went from 3 to 1. The tests are not exactly exact or real world!! GM tested with the same procedures and did not have a problem.
To get back to a 3 they made a minor change to the door trim. Nothing really wrong with all those '07's w/ airbags. Just did not do well on the one test. Tehse test are often not that repeatable.
Interesting to note that the NHTSA side crash test results for the 2006 Impala were better than the LaCrosse results with 5/4 for front and rear passenger areas. Yet both vehicles use the same body-in-white structure and are built at the same GM plant in Oshawa.
the Impala was brought out a cuople years after the LaCrosse and even though on the same architecture changes could be made to the body to increase the stars on the test.
http://www.edmunds.com/insideline/do/FVDP/Preview/styleId=100704034
Since I own a '99 Regal GS, and love performance cars, this is great news for me and I'm sure other enthusiasts as well.
I think they are coming.
One thing we miss from our 2000 Regal GS are the electrolumincent mirrors.
I understand it is not available on the drivers outside mirror, but it is a option for the inside rearview mirror.
Dealer says he will install for $200.00 USD. Vehicle also has On-Star in the mirror. Is this a good price?
Thanks for any input.
http://www.edmunds.com/insideline/do/AutoshowArticles/articleId=106457
I have tried the other mode of driving on the highway to a constant instant mpg reading with cruise control off. I find this can be a satisfying way to go if fuel economy is one's first priority.
I'm waiting for them to get in another 2005 and I'll test drive it. If that one does it well then maybe its something I'll have to get used to otherwise they need to fix mine. In the meantime I was wondering if anyone else has experienced the same thing?
Buick read their computer the first time and replaced the brake pads in the front and called it good. I took it back the second time and had them go with me so I could make sure they heard the noise. This time they replaced ceramic bushings holding the ABS to the drivers strut thingy. Still didn't fix it. I took it to my mechanic and dangerous as it may sound he opened the hood climbed in. He held the ABS and something else he thought might be the problem. I proceeded about 20 feet till it made the noise and his diagnoses was that the ABS needed to be replaced. He could not only hear the "groan" but could feel it happen.
Buick's comeback was that it's the ABS conducting a test cycle and that some units are noisier that others. Basically telling me to live with it.
Other than that the car rides well, gets good comparitive mileage (25 combo highway/city)and responds well. Other things I don't like is that the car seems noisy under certain road conditions, especially when water puddles splash up into the plastic wheel wells. I'm going to undercoat to solve that one.
Karen
Has anyone had any negative experience with the oil life monitor system on their Lacrosse/Allure?
Oil monitors work on duty cycle and environmental conditions and are very reliable. I usually get to about 8000 miles but I drive all city now.
you would have to find out how much longer synthetic is supposed to last than regular oil. If it is double then hit the reset at 0 and wait till it hits 0 again. Perhaps the oil monitor goes negative? No, it does not.
this is very typical of Buick "special" packages put out in the last few years. The LSE/GSE (Regal models with special content and discount) had the same number of choices. The Century "2000" and later special models and the LeSabre special models were the same way.
These are the colors the Buick guys think will be the highest sellers anyway. Let me guess: tint coat red, black, blue and white?
My sales rep said the same thing. They're guessing the most popular colors. BTW, the exterior colors are: Black Onyx, Platinum Metallic, Dark Mocha Metallic, and Red Jewel Tintcoat. The interior colors are: Cocoa and Titanium.
Also, my wife's car, a 2000 Regal GSE, is Bordeaux Red Pearl. And you're right. In 2000 they only offered four other exterior colors for the GSE.
I thought Blue was coming back as the trendy color? So Black, silver, brown and red? The Mocha probably looks great with the new Cocoa interior.
Gord. Toronto
